PollyMobiles Rebuild Blog Index
Jan 2010
Diagnose Sticking Rear Hub
Trakrite Wheel Alignment Gauge
Replace Rear ABS Hub
Assess Tyre Wear
Feb 2010
Replace Rear Left Caliper
Skim Rear Brake Discs
Rebuild Rear Caliper Handbrake Mechanism
Clean Fuel Gauge Sensor
Replace Rear Left Handbrake
Fixed Sticking Rear Brake Calipers
Rear Brake Caliper Mount Measurement
Mar 2010
Research into Rota Grid Alloy Wheels
Replace Outer CV Boot
Replace Fuel Tank Breather Pipe
Fix Sticking Fuel Gauge Needle
Upgrade to Pulsar Gti-R Brakes (AD22VF)
Upgrade to 15" Rota Grid Racing Alloys & Toyo T1R
Insurance Issue
Vinyl Sun Strip
Replace Missing Front Alloy Cap
Upgrade to Grooved Pulsar Discs
Center Pulsar Disc on K11 Hub
Clean & Store Old 13” Nissan Ronal Alloy Wheels
Apr 2010
Upgrade to Goodridge Braided Brake Hoses
New Rear Brake Disc
Upgrade Gear Selector Linkage Bush with Ball Bearings
Overhaul Sun Roof
Replace Clutch Pedal with Bi-Stable Spring Type
Install Electric Sun Roof
Underseal the Front Cross Member
Replace Gear Selector Linkage
Repaint & Refit Nissan Badge
May 2010
Mega UK Trip
Painted Toyo Tyres
June 2010
Reinforce Clutch Cable End Bracket
Upgrade to Black Diamond Fast Track Front Pads
July 2010
Skim & Machined Front Grooved Discs
Cold Air Intake Pipe v4.0
Upgrade to Black Diamond Fast Road Rear Pads
Repair Blown Head Gasket
Refine Cold Air Intake Pipe
August 2010
Rockingham Speedway Track Day
Repaint Rear Sway Bar
Repair Door Card
Fit Sparco Clutch Pedal Cover
Prepare for Oulton Park Track Day
Sept 2010
How to Replace Handbrake Cable
Replace Front Wishbone
Research into Coilover Suspensions
Win complete CG13DE Turbo Kit on Ebay
Assess & Overhaul Turbo Setup
Dismantle Turbo Kit Engine
Wash & Overhaul Engine
Swap from Janspeed to Stock Manifold for MOT
Test Fit Turbo
Compare Standard, Janspeed & Turbo ECU Maps
Overhaul Gearbox
Disassemble Distributor
October 2010
Stiffen Stock Engine Mount with PU Sealant
Receive & Fit BC Racing V1 Coilovers
Coilover Covers v1.0
Removed Rattling Boot Lock Rod
Replace Punctured Rear Right Tyre
November 2010
Straighten Intercooler Fins
December 2010
Replace Damaged Front Registration Plate
Jan 2011
Find Rusting Sill Holes
Assembling Turbo Setup
Research into Dry Cell Battery
Make Loom Extension Adapter for Gti-R MAF Sensor
New Stick Welder
New Odyssey Battery
Innovate Wideband Kit
Research into Clutch Upgrade
Try Out Solarice’s Helix Paddle Clutch
DIY Copper Battery Terminals
Make Battery Casing
Relocate New Battery
Fix Faulty Battery Grounding
New Boost Gauge
Boost Gauge Pods
Test Motorbike Pod Air Filter
Feb 2011
Receive Gripper LSD v1.0
190mm Helix Organic Clutch Disc
Fit Intercooler
Modify Front Bumper
Guide How to Adjust Idle-Air-Control-Valve
Copper PAS Cooler v1.0
Coilover Covers v2.0
Fit Boost Pod Gauges
Service BC Coilover Top Mount Spherical Bearings
Fit Copper PAS Cooler v1.0
Research into 370cc Fuel Injectors
Mar 2011
Helix 180mm Paddle Clutch & Almera Pressure Plate
Receive Gripper LSD v2.0
Upgrade from Red 256cc to Purple 370cc Fuel Injectors
Fix Loose Clutch Pedal
Turbo Conversion Plan
Buy & Overhaul JE Forged Piston Engine from Noddie
Royal Purple Break-in Oil
Upgrade to Skyline GTS-T Fuel Pump
Upgrade to Universal Pod Air Filter
Paint Engine Cover
Replace Fuel Injector Nozzle Pintle
Fit New Gripper LSD v2.0
Apr 2011
Fit Boost Vacuum Pipe
Install Innovate Wideband
Remove Stock Engine
Swap Parts Over
Reinstall Forged Engine Assembly
Copper PAS Cooler v2.0
Modify Radiator Fan
Paint Dashboard Black
Bed-in Forged Piston Engine
Fit Turbo
New Down Pipe from AAS Exhaust
Replace Front & Rear Crank Seals
Attempt to Fix Turbo Oil Drain Leak
Programme Wideband Gauge
Weld Rear Silencer Hanger
Coilover Covers v3.0
Replace Front Left Wheel Bearing
Front Bumper Mesh
Replace Blown Headgasket
Remap Turbo with JE Forged Pistons at Fusion Motorsports
Dyno Graph of Turbocharged Forged Piston Engine
DIY Wheel Alignment
Replace Locking Wheel Nuts
Replace Front Crank Seal
Upgrade to Stiffer Competition Engine Mounts
DIY Oil Vapour Catch Can Test
May 2011
Swap Back to Janspeed Exhaust
JE Forged Piston Engine Leak Down Test
Assess Wet Piston Top
Fix Sticky Ignition Switch
New Engine Crane
Swap Over to Stock Engine
Tweak Nistune ECU Map
June 2011
Assess JE Forged Piston Engine
Overhaul Stock Front Calipers
Respray Front Right Wing
Turbo BOV Recirculation Pipe
Assess Gti-R MAF VQ Map
Wirebrush Wheel Nuts
Respray Bonnet
Japshow 2011
July 2011
Disassemble Washer Motor
Corner Balance Coilover Suspension
Teesside Autodrome Track Day
Paint & Fit Hub Dust Caps
New Toyo T1R
Road Trip to Scottish Islands
Aug 2011
Recirculating Engine Cover Breather Pipe
Fit Red Engine Cover
Disassemble O2 Sensor
New O2 Sensor
Fix Boost Leak & AFR Issue
New Spark Plugs
Compare Old & New O2 Warm Up Response
Fix Worn Windscreen Washer Pump Motor
Pulsar Gti-R AD22VF Caliper Wheel Clearance Measurement
Fix Loose RH Engine Mount
New Outer CV Boot
New Fuel Filter
New EBC Red Stuff Front Pads
Castle Combe Track Day
Inner Sill & Rear Floor Pan Rust
Walbro 255lph Fuel Pump
Castle Combe Onboard Footage
Machined Throttle Body Port Grooves for Silicone Hose
Replace Damaged Turbo Waste Gate Boost Line
Sept 2011
Welded Sill & Floor
Fill & Paint Sills
Fit New Boost T-Bolt Clamps
New Catalytic Converter
Research into Radiator Upgrade
6kg BC Coilover Front Springs
Rebuild Turbo
Remap Turbocharged Stock Engine at Fusion Motorsport
Tweak Turbo Map Timing for Stock Engine & Assess Timing Issue
Resolve Turbo Timing Map Issue
Compare Dyno Graphs of Turbo Remaps for Forged & Stock Engine
Swap to Stock Exhaust for MOT
De-cat
Replace Rear Brake Lines for MOT
Oct 2011
New Wheel Nuts
New Alternator Belt
Fit 6kg BC Coilover Springs
Send JE Forged Piston Engine & Spare Engine to Cousin for Machining
Ordered 200mm Helix Clutch
Clean & Send 3-Piece Standard Flywheel to Cousin
Oil Vapour Catch Can v1.0
Dec 2011
Fixing Rear Demister
Change Gripper LSD Oil
Wideband Copper Heat Sink
Dizzy Cap Oxide & New Rotor
Manual Check-Valve Boost Controller
Research into Electronic Boost Control
Plan Electronic Boost Control
Collect & Disassemble Machined JE Forged Engine
Disassemble JE Forged Engine Bottom End
Assess Balanced Crank & Rebuild Bottom End of JE Forged Engine
Wash & Wirebrush Cylinder Head
Jan 2012
Rebuild Top End of Forged Engine
Painted Engine
Research into Thicker Radiator
Pressure Switch for Boost Control
Install 200mm Helix Clutch
Boost Valve Solenoid
Electronic Boost Control Prototype
Test Electronic Boost Control
Crimp Throttle Body Coolant Pipes
Wirebrush & Paint Janspeed Manifold
New Bosch Wideband Sensor
Clean & Paint Gearbox
New Thicker Nissen Radiator for Automatic K11
Throttle WOT Switch for Boost Control
Install Electronic Boost Control
Weld Turbo Manifold Crack
Find Correct Fitting for Turbo Oil Return
Sand Flat Manifold Flange
New Clutch Release Bearing
Wideband Cooling Fin
Readjust Alternator from Shorting Out on Turbo
Plan Induction Pipe Fabrication
Practice Welding Pipes
Compare Mild vs Stainless Steel Plumbing Cost
Action Camera Research
Receive Stainless Pipes
Drift X170 Action Camera
Install 70mm Alloy Elbow on MAF/TB
Feb 2012
Ball Bearing Gear Selector Bushing
Rubbish Clarke Pipe Cutter
Mod Mitre Saw into Chop Saw
Weld 1st Stainless Pipe Section & Short Shifter
Fit Gear Short Shifter
Fabricate Camera Rig Beam
New Toyo T1R
Test X170 Camera Rig
Fix X170 Camera Mic
Fabricate Stainless Boost Pipe Work
Research into Rebuilding Gripper LSD
Remove Gearbox
Assess Glazed Paddle Clutch & Flywheel
Assess Damaged Gripper LSD
New Front Suspension Arms
Research into Inlet Manifold Insulating Spacers
Upgrade to Polyurethane Front Suspension Bush
Fit Machined 3-piece Flywheel & 200mm Helix Clutch
Wedge Rear Engine Mount
Research into Oil Vapour Catch Can
Make Teflon Inlet Manifold Insulating Spacers
Assess Rebuilt Gripper LSD
Install Teflon Inlet Manifold Insulating Spacers
200mm Helix Clutch Issue
Finish Welding BOV Port
Test New Clutch & Gripper LSD
New Oil Vapour Catch Can using Remote Oil Filter
Rear Chassis Cross Brace
Lengthen Clutch Mechanism Stroke
Testing New Camera Angles
March 2012
New Cabin Camera Mount
Fit New Toyo T1R
Refine Foot Well Camera
Check Gripper LSD Still Working
Oulton Park 2012 Trackday
New Helmet
Assess Car After Oulton Park, Cracked Front Brake Disc
Oulton Park Datalogs
Repaired Windscreen Chip
New Diamond Black Gti-R Grooved Front Discs
Helmet Cam Mount
Solid Rear Exhaust Silencer Hangers
Test Suspension Cam & Helmet Camera
Fit & Bed New Diamond Black Grooved Discs & Predator Fast Track Front Pads
Check Brake Pads & Fit Pad Shims
Pulsar Gti-R Brake Carrier Measurement
Attempt to Correct Turbo Map Timing Offset
Test Rear Suspension Camera
April 2012
Test Front Suspension Camera
Paint Helmet Black
Reset to Previous Turbo Map
Remove Sun Roof Cover
Assess Cold Start Flooding
Ducktape Sun Roof
Resolve Cold Start Flooding
Teesside Autodrome Trackday
Assess Engine Failure
Assess Brakes & Tyres
Remove Stock Engine
Resealed Turbo Drain Plug
May 2012
Swap Gearbox Input Shafts
New Pair of Predator Fast Track Pads
Fill Rear Engine Mount with Bodyfiller
Install New Forged Engine
Paint & Heat Wrap Exhaust
Start & Break-in New Engine
Replace Valve Stem Seal
Drift X170 Camera
Test Crankcase Pressure & Oil Ring Failure
Remove Forged Engine
Disassemble & Assess Forged Engine
Call JE for Piston Datasheet & New Rings
Inspect Rusty 1997 Vibe with Costa
Sourcing New JE Piston Rings
Overhauling Cylinder Head
Ordered XC7150 Piston Rings from Performance Unlimited
Check Oil Pump
Research into Oil Sump Baffles
Remove Front Hub Shroud Blocking Front Disc Vents
Assess & Cutting Off Standard Oil Sump Baffle
Design Custom Oil Baffle
Oil Baffle Design 1
Oil Baffle Design 2
Oil Baffle Design 3
Oil Baffle Design 4
Oil Baffle Design 5
Order New Oversized Main & Big End Bearings
June 2012
New Bore Gauge & Micro Meter
Oil Baffle Design 6
Fabricate Oil Baffle Design 6
Make Oil Pickup Jig
Prepare Oil Sump For Welding by Noddie
Issue with Piston Ring Order with Performance Unlimited
Test Old Torque Wrench Accuracy
Overhaul Old Torque Wrench
Windage Tray Design 1
New Sealey Electronic Angular Torque Wrench
Assess & Model Crank Girdle Cage
Cancelled Delayed Piston Ring Order from Performance Unlimited
Ordered Piston Rings from JE
Windage Tray Design 2
Collect Sump Welded by Noddie
Windage Tray Design 3
Issue with Obstruction on Standard Sump
Windage Tray Design 4
Cut & Patch Oil Sump Hump
Weld Oil Sump Patch
Windage Tray Design 5
Windage Tray Design 6
Receive New JE XC7150 Piston Rings
XC7150 Piston Ring Spec
Win x8 Toyo R888 on BMW BBS Alloys
July 2012
Test New Trap Door Oil Baffle on New Sump
Compare Using Wheel Spacers vs Machining BBS Alloys
Paper Mockup of Windage Tray 6
Updated Windage Tray 6
Ordered Extended Wheel Studs, Machine Wheel Spacers
Ordered New Gti-R Discs For Spacers
Buy Spare Gti-R Discs from Karl
Card Model of Windage Tray 6
Updated Windage Tray 7
Grinded Crank Girdle Cage
Card Model of Windage Tray 7
Cut Steel Pieces of Windage Tray 7
Construct Windage Tray
Bolt Windage Tray onto Girdle
Updated Windage Tray Gate
Test Windage Tray 7
Redesign Windage Tray 8 with Louvred Gates
Test Windage Tray 8
Aug 2012
New Engine Bearing Shell Issue
Cut 8mm Wheel Spacers from Old Gti-R Discs
Receive & Assess New Remachined Forged Engine
Measure Forged Engine
Grind Forged Engine Girdle Cage
Test Fit Windage Tray on JE Forged Engine
Measure Forged Piston Ring End Gaps
Issue with Remachined Engine Block
Lost Job
Confirmed with JE Engine Clearances Were Too Tight + Future Plan
Assess Damaged Stock Engine
Redesign Windage Tray 9 with Trap Doors
Fabricate Windage Tray 9
Test Windage Tray 9
Assemble Stock Engine with Windage Tray 9
Install Stock Engine
Test Fit BMW BBS Wheels
Rerouted Boost Control Feed & Final Car Assembly
Initial Start & Test of Turbocharged Stock Engine
Research into Insulating Boost Pipes
Cover Boost Pipes in Kitchen Foil & Test
Wrap Boost Pipes with Radiator Insulation Shield Foil
New Air Filter
Check Leak & Loose Rear Mount
Discover Loose Cam Shaft Sprocket Bolt & Damage
Repair Cam Shaft Bolt Thread
Paint Spare Engine Cover
Look Inside Engine Cover
Plan Roadtrip Holiday
Prepare Car for Road Trip
Deliver JE Forged Engine to Cousin for Machining
Tune Turbo ECU Map for MOT
Replace Damaged Air Filter
Assess Damage from Leaving Paper Leaflet in Air Filter
Replace Headgasket
Straighten Bent Turbo Compressor Blades
Flush Paper Debris Out of Intercooler
Sept 2012
Road Trip to Isle of Man
Replace Outer CV Boot & Clean Wheel Nuts
JAE 2012
Replace O2 Sensor
Cone Air Filter Shield
Found Damaged Fuel/Brake Lines Under Car
Turbo Fails MOT Emissions Again
Bargain New Dizzy
Swap Over to Stock Setup for MOT
Receive New Distributor
Oct 2012
Swap Back to Turbo Setup
Spark Gap Tool
Collect New Machined JE Forged Piston Engine from Cousin
Nov 2012
Measure Forged Engine Bores
Calculate Required Ring End Gaps
Assemble Forged Engine Block
Clean Coilover Suspension
Repair Creaking Clutch Cable End
Dec 2012
Research into Suspension Droop Limiters
New Toyo T1R
Measure Old Used Jun Flywheel & Helix Paddle Clutch
Nistune Fuel Map Editing
Wideband Free-Air Calibration Trick
Plan Tyre Infra-red Sensor
Jan 2013
Research into Infra-red Sensors
Tweak Turbo ECU Map
DIY Laser Alignment
DIY Lazy-Susan Swivel Plates
Design Custom Swivel Plates
Build DIY Uni-Directional Swivel Plates
DIY Laser Alignment Procedure Theory
Laser Align Wheels
Test Gripper LSD in Snow
Droop Limiter Strut Cover Test
Alternator Failing
Research into Ruggles Scales for Corner Balancing
Designing Custom Ruggles Scale
Feb 2013
New Windscreen Washer Motor
Build DIY Ruggles Scale
Broken Ring Land Misfire
New Alternator
Assess Engine
Clean & Lap Valves
MPG Analysis of NA vs Turbo Setups
Mar 2013
Replace Rear Main Crank Seal
Replace Oil Gallery Copper Seal
Replace Gear Selector Rod Boot
Straighten Bent Side Bearing Cage
Sand Rusty Brake Discs
New Gripper LSD Preload Readings
Engine Still Misfiring
Clean Old 13” Nissan Ronal Alloys to be Sold
Plan Piston Ring Grinder
Build DIY Piston Ring Grinder
Grind Piston Ring End Gaps
April 2013
Assemble JE Forged Engine
New Oil Vapour Catch Can Filter
Remove Broken Stock Engine
Paint Forged Engine
Swap Bits to Forged Engine
Stiffen Engine Mounts with Bodyfiller
Paint Crossmember
Fit JE Forged Engine
Sand Rusty Brake Discs & Secure Battery
May 2013
Forged Engine Initial Start & Engine Failure
Discover Loose Big End Bearings
New Battery
New Big End Bearings
Assess Damaged Big End Bearings
Clean Oil Sump
Oily Smoky Piston & Oil Leak Issue
Initial Engine Break-in
Broken Alternator Mount & Electrical Fault
New Battery Fuses
June 2013
Straighten Sump Edge
Repair Alternator Bracket
Discover Oil Catch Can was Plumbed Backwards
Reduced Oil Leak/Smoke & Break-in Status
Temporary Oil Catch Can
Loose Timing Cover Bolts
Assess Engine After 100m Break-in
Test Without PCV, Alternator Bracket Fractured
Reinforced Alternator Bracket
Editing Fuel Map Raw Values in Nistune
Replace Stem Seals
Adjust Valve Clearance Shims
DIY Valve Stem Seal Extraction Tool
Resume Break-in, Testing Smoke & Compression
New Exhaust Manifold Gasket
Inspect Bores with Borescope
Driving Through Yorkshire Moors
Kitchen Foil Cone Filter Heatshield
Plumb PCV & Crankcase Breather into Bottles
Smoking Exhaust after Prolonged Idle
Upload Original Remap for JE Forged Turbo Setup
Laser Align Wheels
July 2013
Refine Cold Start Enrichment
Repair Puncture
Measure Stock Engine Condition
Compare Spare Engines 1 & 2
Repaint Hub Cap & Nuts
Replace Wideband Sensor Copper Heat Sink
Overhaul Rear Sway Bar & Drop Links
Disassemble Belt Tensioners
Replace Belt Tensioner Bearings
July 2013
Repair Puncture
Aug 2013
Purchase Spare Set of Rota Grid Wheels for Trackdays
Replace Belts
Test JE Forged Engine Compression & Disassemble
Measure Clutch & Flywheel Offset from Bell Housing
Assess Gripper LSD
Receive Spare Rota Grid Wheels
Trying to Stretch Forged Piston Oil Ring Expander
Measure Forged Piston Ring Drag with Digital Scale
Damaged Oil Ring
Measure JE Forged Piston Ring End Gaps
Assess JE Forged Pistons, Bores & Bearings
Receive New JE XC7200 Rings plus Wrongly Posted Forged Piston Set
Assess New Rings
Issue Returning Wrongly Posted JE Pistons
Sept 2013
Reassemble Forged Engine with New Oil Ring Expanders
Reinstall Engine
Start Rebuilt JE Forged Engine
Check Inside Rebuilt Forged Engine
Air Filter Shield
JAE 2013
Research into Hotter Thermostat
Install Hotter 91C Thermostat
Datalog with Hotter Thermostat
Replace Side Indicators & Check Inside Forged Engine
Try Thinner 0w30 & Pistons are Still Wet
Relocate Turbo Exhaust Catalyst Position
Oct 2013
Pass MOT
Check Engine after 0w30 Oil
History of JE Forged Engine Piston Appearance
Victor Reinz Headgasket
Dec 2013
Digital Scales
Laser Level for Corner Balancing
300kg Digital Scales for Corner Balancing
Corner Balancing App Idea
New Fuel Filter
Remove Turbo Elbow Exhaust Studs
Fit Turbo
Weld Exhaust Mid-Support
Correcting Mis-aligned Exhaust
Replace Leaking Dizzy O-ring
Clean Seized Rear Caliper Carrier
Clean Rear Coilover Spring
Correcting Mis-aligned Exhaust & Rear Bump Stop
Overhaul Seized Rear Calliper
Overhaul Front Struts
Jan 2014
Corner Balance Coilovers
Clean Steering Arm Threads
Fit Spare Wheels to Resolve Steering Pull
New Predator Fast Track Pads
Leaking Tyre Valve
Make Adjustable Wheel Platforms
Cut Inside a Fuel Filter
Rebalance & Realign Suspension
Reinforce Rear Parcel Shelf
Leaking Radiator
Fix Leaking Radiator
Received Fake Ebay Radiator
Change to Alloy Oil Catch Can Mount
Trim Rattling Bonnet
Elvington Airfield Trackday
Elvington Airfield Lap Times
Engine Cover Oil Leak
Inspect Cylinder After Trackday, Reseal Dizzy, Replace Brake Pads
Feb 2014
Tighten Loose Boot Latch Rivet
Rear Suspension Knock
Edit Cold Start Enrichment
Compare Cold Start Settings
Convert Gear Selector to Ball Bearing
Mar 2014
New Trailing Arm Bolts
Compare Insurance Quotes
Replace Trailing Arm Bolts
Replace Air Filter
Apr 2014
Replace Spark Plug, Random Misfire
Swap Fuel Injectors
Assess Oil Consumption
Reseal Engine Cover
Reattach Heater Diverter Cable
Heater Diverter Operation
Remove Front Wings for Painting
Clean & Paint Engine Bay Top
Repaint Crossmember
Repaint Front End
Tighten Bonnet Hinge
Replace Wiper Linkages
Trim Wing Panel
May 2014
Repaint Front Wings
Repaint Bonnet
Replace Track Rod End Cover
Swap & Repaint Tyres, Puncture
Repaint Strut Brace
Replace Left Outer CV boot
Adjust Rear Boot
Test Raised Bonnet Aerodynamics
June 2014
Cadwell Park Trackday
Make Wheel Spacers from Old Rear Disc
Nistune ECU Map Comparisons
Fix Gear Stick Return Spring
Engine Compression History
Oil Consumption History
Corner Balance & Align Suspension
Rusted Sills
July 2014
Weld Sills & Corner Balance Suspension
Finish Welding Sills
Fit Rose-Jointed Drop Links
Remove Seized Rear Caliper Bolts
Rebuild Rear Calipers
2014 Mablethorpe District Motor Club Auto Triathlon
Worn Rose-Joint Drop Links
Test Fit Extended Wheel Studs, Remove Rear Brake Spash Plate
Aug 2014
Realign Wheels
2014 Cadwell Park Modified Live
Reinforce TB MAF Clamp
Rattling Brake Pedal
Modify E-Prance 1080p Dashcam
Sept 2014
Patch Torn Bucket Seat, Receive Federal 595RS-R
JAE 2014
Clutch Cable Failure
New Clutch Cable & Exhaust Gasket
Ratchet Spanners
Partially Seal Leaking Spark Leads
Leaking Exhaust Manifold
Remove Turbo
Cusco Lower Strut Brace Failure, Swap to Standard Setup
Compare Stock vs Turbo Setup Issues
Reinforce Clutch Pedal Bracket
Jan 2015
Replace Engine Cover Gasket
New 3D Printer
Disassemble Master Cylinder
Receive & Build 3D Printer
Repair/Replace 3D Printer Extruder Tensioner
Print HT Lead Clips
Assess Steering Drift Due to Uneven Tread Depth
RH Suspension Arm Failure
Remove & Assess RH Suspension Arm Failure
Fit New Drivers Suspension Arm
Feb 2015
Lube Clutch Cable, Fix Oil Cap
Redesign 3D Printer Extruder, Upgrade Hot End, Fit New Engine Cover Gasket
Print Oil Catch Can 9
Fix Punctures
Print Oil Catch Can 14
Print & Vapour Smooth & Test Catch Can 3
Puncture, Remove Old Catch Can, Worn Wiper Motor
Print Oil Catch Can V-band Clip
Test Oil Catch Can, Issue at Work
Print Wiper Spoilers
Mar 2015
Assess Oil Catch Can Result
Work Issue
Print Oil Catch Can 18
Disassemble Micra Master Cylinder & Primera Master Cylinder
Upgrade Master Cylinder
Disassemble Brake Servo & Fit Citreon C3 Master Cylinder
Print & Test Oil Catch Can 4
Assess Engine Compression & Gripper LSD Preload
Print Broken Glove Box Lock
OBP Brake Bias Adjuster & Dot 5.1 Fluid
Redesign Andys Celica Glove Box Hinge
Replace Bosch Wideband Sensor
Replace Cracked Windscreen
Plan Brake Lines Rerouting
Fit Citreon C3 Master Cylinder Servo, Trim Fuel Regulator Edge, Remove Old Brake Lines
Print Andys Celica Glove Box Hinge
Fit New Front Brake Lines
Remove ABS Unit
Install Brake Bias Adjuster & Internal Brake Lines
Remove Rear Washer Line, Fit Rear Brake Lines
Overhaul Rear Calipers & Clutch Cable
New Front Pads
Remove Old Fuel Lines
New Rear Brake Discs, Rear Caliper Rebuild Kit, Rebuild Fuel Lines
Apr 2015
Remove ABS Loom
Trim Caliper Bleed Screws, Test Drive New Brake System
Bleed Master Cylinder
Print Oil Catch Can 23
New Lower Strut Brace from Andy Gray
Assess Oil Catch Can Location
Blyton Park April 9th
Blyton Park April 11th
Micra Strut Tower Dimensions
Adjustable Throttle Pedal
Disassemble Old Rear Brake Load Compensator
Disassemble ABS Modulator
Turbo Manifold Jig
Assess Completely Worn Front Brake Pads
New Brake Pads, Assess Brake Wear
New Air Filter
Faulty Alternator Connection Driving to Cadwell Park
Remove ABS Sensor Cables, Rear Chassis Rust, Rear Left BC Coilover Damper Failure
Print Phone Holder
May 2015
Print Oil Catch Can 24
Oil Catch Can Mount Plate
Assess Oil Catch Can Operation
New OEM Pulsar Gti-R Front Discs
Repaint Wheel Nuts, Lower Brace & Locking Wheel Caps
Assess Engine Compression, Gripper LSD Preload & Oil Loss
Prepare Car for m8s Wedding
Refurbish Rota Grid Wheels
Trace Oil Leak with UV Oil Dye
Assess Worn BC Coilover Spherical Top Mount Bearing
Machined OEM Pulsar Gti-R Discs
Fit New OEM Gti-R Discs
Fix Broken Horn Wires, Bed Front Brakes
Personal Crisis, Depression
Replace Engine Cover Allen Screws, Turbo Manifold Jig
Replace BC V1 Coilover Spherical Top Mount
Weld Turbo Manifold, Fix Alternator Wire
Refine Upper Alternator Mount, Refine Alternator Wiring
Machined Open-End Wheel Nuts
Changed Power Steering Fluid
New Sports Seats
Visit Santa Pod
Extended Rear Wheel Studs & Spacers
June 2015
Weld Stainless Turbo Inlet Pipe, Custom Dipstick
Overhaul Lower Adjustable Trailing Arms
Compare Stock & 200mm Clutch Fitment on JUN Flywheel
Pedal Cam Mount & LED Light Strip
Dismantling a Reclining Sports Seat
Repaint Trackday Wheels
Insulated Turbo Inlet Pipe
Weld Sports Seat Sub-frame
Remove Gearbox & Clutch to Machine JUN Flywheel
T2 Turbo 10mm Turbo Flange, Fix Rear Engine Mount, Reinforce Clutch Cable Bracket
Weld Turbo Manifold with Thicker Flange
Relocate Oil Catch Can
Relocate Horns
New Oil Gallery Seal, New Rear BC V1 Dampers, Machined JUN Flywheel for 200mm Clutch
Fit New Rear Dampers, Catch Can Heat Shields
Fit Black Trackday Wheels
Oil Catch Can Test Flow Path
Tyre Wear Rate History
Blyton Park Eastern Circuit
July 2015
Change Engine & Gear Oil, Assess Brake Pad Wear
Assess Leaking Spark Plug Holes
Repair Stainless Turbo Inlet Pipe Mount
Reshape Sports Seat Foam Base, Pedal Foot Rest
Japshow 2015
Check Brake Pad Wear, Fit Exhaust Cat, Weld Lip on Boost Pipe, Stiffen Rear Engine Mount
USB Camera Power Supply, Organise Engine Bay Loom
Crimp & Repair Engine Bay Loom Wiring
Install Cameras & Power Supply
Reinforce Turbo Outlet Elbow
Blyton Park Trackday
Assess Exhaust Manifold Gasket Leak
Weld Turbo Manifold
Sand & Fit Turbo, Trim Alternator Backing
New Spark Plugs, Replace Drivers Outer CV Boot, Replace Brake Pads, Front Passenger Arm Failure
Assess Passenger Suspension Arm Failure
Brake Pad Wear History
Reinforce Lower Suspension Arms
Fit New Suspension Arm, Replace Headlight Bulbs, Replace Windscreen Washer Jets
Burn Out Old T1R Tyres
Fit New T1R Tyres
300W Power Inverter for Cameras
Aug 2015
2015 Nurburgring Road Trip
Nurburgring Sticker
Weld Steel 3D Printer Frame
Print Oil Catch Can 28
Print Oil Catch Can 35
Resolve Leaking Oil Return Port
Rippon Classic Car Show
Engine Cover Stainless Allen Screws, Print HT Lead Clips
Jan 2016
Print Alarm Remote Control Casing
Assess Engine Compression & LSD Preload
Loose Rear Mount Bolt
Assess Brake Pads, Loose Driveshaft & Change Gearbox Seal
3D Print Vacuum Cleaner Nozzle
3D Print Desolder Pump Nozzle
3D Print SSD Memory Casing
Stiffen 3D Printer Bed from 3-point to 4-point Mount
Feb 2016
3D Printer Bed Insulation & Replace Burnt Power Connector
Repair Broken Rear Door Handle
3D Print Starwars Models for Friends Funeral
Assess Oil Catch Can Gunk
Trim Rear Extended Wheel Studs
Seal Leaking Turbo Oil Drain with Epoxy
Mar 2016
3D Print Helmet Camera Casing
3D Print Glove Box Lock
Check Onboard Cameras & Smoking Exhaust
Assess Oil Catch Can & Loose Boost Pipe
Change Engine & LSD Oil
Mental Symptom Diagnosis
Awesome Mariah Carey Concert
Visit GP for Mental Diagnosis
Measure Cars Acoustic Loudness
3D Print Engine Mount Stiffeners v1.0
Apr 2016
3D Print Engine Mount Stiffeners v1.0 for Matt Endean
Weld Rusted Rear Chassis
New Clarke 135TE MIG Welder
Stick Welder Cable Management
Clarke 135TE Wire Feed Rate
Print Oil Catch Can 37
Sun Roof Rattle
Weld Raised Bonnet Hinge
Weld Rusty Front Wings
Welding Helmet LED
Repaint Front Wings
Repaint Sills
Print Sat Nav Mount v2.0
Japfest 2016
Change Coolant, Oil Smoke Issue
Smoking Exhaust
Swapped Back to Standard Setup
Inspect Leaking Turbo
Assess Turbo Oil Plumbing
May 2016
Check if Exhaust Still Smokes with Standard Setup
Order New Turbo AN Fittings
Turbo Technic Issue, Reorder New S116 Turbo from CGB Motorsport
Inspect New S116 Turbo
Prepare New Turbo
Receive New Turbo AN Fittings
Fix Turbo Oil Drain Fitting Issue
Print AN Fitting Jaws, Weld New AN Bung into Oil Sump
Install New Turbo
Repaint Engine Cover
Hammerite Smooth Red Issue
Install Turbo Oil Feed & Drain Hoses
Check if Turbo Stops Smoking & Inspect Turbo Oil Leak
Jap Day 2016
Test Solid Front Engine Mounts
Reseal Turbo Oil Fittings
Teesside Autodrome Trackday 2016
Check Brakes & Tyres
Teesside Autodrome Lap Time History
June 2016
Print Oil Catch Can 42
Convert Max Plestors Pulsar Short Shifter to Ball Bearing
Print Clutch Cable Extension Collar
Test Oil Catch Can Condensation
Print Sat Nav Mount v3.0
Relocate Oil Catch Cans Behind Headlight
Organise Engine Bay Fuse Box Loom
Print Oil Catch Can 43
Weld Engine Crane Valve Handle
Weld Seat Sub-frame
Rear Boot Vents
Tune Cold Start Enrichment
Install Standard 82C Thermostat
July 2016
Repaint Bumpers
Weld Tow Hook
Polish Rota Grid Wheels & Exhaust with Rubbing Compound
Japshow 2016
Tune Andys BMW & K11 1.4SE
New Mini Lathe
Machine Grinding Wheel Shaft
Mini Lathe Quick Change & Carbide Tips
Machine Tight Brass Collar for Loose LSD Driveshaft
Check Gripper LSD Preload
Check Mini Lathe Chuck
Machine Bicycle Chain Guide
Aug 2016
Machine Tight Steel Collar for Loose LSD Driveshaft
ECU Speed Sensor Toggle Switch
Ride Height & Tyre Size Comparisons
Refine Grinding Wheel Rest
Fix Drivers Engine Mount Bolt
Replace Front Brake Pads
Repaint Trackday Wheels Black
Oil Catch Can Enclosure
Machined Spigot for Brake Disc & Wheels
Pulsar Gti-R MAF Connector Clip
New Outer CV Joints
Weld Cracked Crossmember
Reinforce Engine Centre Beam
Replace Outer CV Joints
Petrol & Pistons Show 2016 at Croft
Inspect Brakes & Tyres & Suspension Geometry
Help Andy Dismantle K11 1.4SE
Detailed Comparison with Neil Jackson Nismo March G
Calculate Roll Centre
Fit Boot Gas Struts onto Bonnet
Sept 2016
New Polishing Machine
Weld New Exhaust Flexi Pipe
Grind New HSS Lathe Cutting Tool
Machine Spark Plug Tube Oil Seal Collars
JAE 2016
Overhaul Coilover Suspension
Repair Rusty Rear Spring Chassis Perch
New Coilover Covers
Machined Clutch Cable Extension Collar
Passed MOT
Dismantle Worn Rear Hub
New Rear Hub
Machined Wheel Studs & Wheel Nuts
New Fuel Filter
Print Engine Mount Stiffener Inserts
Oct 2016
UK Road Trip 2016
Repair Front Engine Mount
Print HT Lead Mounts for Neal Jacksons Nismo March
Machined End Caps for Ralph
Machined Oil Dip Stick
Miniature Helmet Camera
Print Oil Catch Can 44
Nov 2016
New Headlights
Machined Shaft for Ralph
Compare & Swap Headlight Parts
Make Inlet Manifold Insulating Spacers for Matthew Elliot
Print Oil Catch Can 45
Dec 2016
Tried a Few Therapists, Started a Part Time Job in Post Room During Xmas Season
Machining Threads on Lathe
Inside a CO2 Canister
Jan 2017
Assess Worn Alternator
LED Strip Interior Light
Feb 2017
Design Rear X-Brace
Corrupted 3D Printer Firmware
Fabricating Rear X-Brace
Reprogrammed 3D Printer Firmware
Find More Rust in the Rear & Paint X-Brace
Small Tweaks to 3D printer
Print Coilover Top Caps & Car Remote Casing
Weld Rusty Boot Floor
Teflon Inlet Spacer for Andy
Stiffer Rear Damper Top Mount
Checking if BC Coilover Spherical Bearing Fits on Suspension Arm
Printing Miniature Micra Model
Mar 2017
New Born Neice, Replace Peugeots Clutch, Metric Hub Upright Fasteners
New Insurance with Adrian Flux
Painted Onboard Cameras Black
Fix Trolley Jack Wheels, Weld Rear-Driver Corner
Testing Onboard Camera Sound Levels
Securing Camera USB Hub Connector
Print USB Power Pack Casing for Cameras
Painted Trackday Wheels
Overhaul Trolley Jack
Fix Loose Seat Rail
Foot Pump from Screwfix
Apr 2017
Visiting Sophie & Abi/Jonny
Seatbelt Restraint
Prepping for Trackday
Machining Titanium Pins for Ralph
Teesside Autodrome Trackday, Broken Gearbox
Assess Damaged Gearbox
Assess Gripper LSD
New Gearbox
Print Gift for Chloe
Etching Wheel Nuts
Creaking Clutch Pedal
Repair Steering Clock-Spring
May 2017
Diagnose Abi K12 Throttle Issue
Japfest Silverstone 2017
Modified Live at Cadwell 2017
Measure Lower Arm Ball Joint
Design & Mod Lower Arm for Ball Joint Extension
Replace Open Wheel Nuts
Welding Lower Arm Extension Mods
June 2017
Replace Front Wheel Bearings, Machine Longer Front Wheel Studs
Measure Bump Steer, Machine 8mm Wheel Spacers
Replace Worn Steering Wheel, Correcting Bump Steer
Compare Suspension Before/After Correction
Swap Front/Rear Wheel Studs
Compare Cornering With/Without Sway Bars
Comparing Sway Bar Specs
Broken Rotary Laser Level
Repaired Rotary Laser Level
Repair Rusty Sills
July 2017
Scarborough Cruise Meet
Boot Release Handle Repair
Repair Rusty Scuttle Panel
Japshow Santapod 2017
Upgrade Andrews MAF, Fuel Injectors & Walbro Fuel Pump
Help Andy Gray Swap CG Head onto CGA Block
3D Print Impul Kit for Abi’s Bday Gift
Fit Black Bucket Seats for Joosh
Fit Standard Front Swaybar
New Trolley Jack
Scarborough Static Royals Car Meet
Windscreen Chip Repair
Swap Trolley Jack Parts
Repair Cracked Turbo Manifold
Weld Turbo Housing
Turbo Support Bracket
Aug 2017
Lengthen Exhaust Mid-Pipe
3D Modelling K11 SR for Garin
Cooling Shroud for 3D Printer
Add Cooling to 3D Printer Control Board
3D Print Nissan Badge with PLA
Print Oil Vapour Catch Can Screw Lid
Finish Modelling Garins K11 SR
Replace 3D Printer Power Supply
Burnt Out 3D Printer Board
Found Spare Makibox Printer Online
Print Garins K11 SR Model
JAE 2017
Croft Petrol & Pistons Show 2017
Pet Koi Fish Died ?
Sept 2017
Replace 3D Printer Board
2017 Forge Show at Castle Combe
3D model CG Headgasket
Print Catch Can Lid & Star Wars Model for m8s Bday
Local Car Meet
Repair Trolley Jack Defect
New Brake Pads
Refine 3D Printer Power Supply
Fix Rattling Gear Linkage
Local Dragonville Car Meet
Replace Catalyst Gasket, Print Model for Sophie
Visit Sophie, Suspension Arm Snapped While Visiting Abi
Santapod Japshow Finale
Oct 2017
Replaced Arm to Drive Home
Analyse Suspension Arm Failure
Repair Broken Suspension Arm
Assess Spare Suspension Arm
Pass MOT
Replace Suspension Spherical Bearings
Compare Suspension Spherical Bearings
Weld Peugeot Rusty Exhaust Silencer
Replace Fuel Filter, Static Royal Car Meet
Stainless Trailer Pins for Ralph
Visiting Malton with Abi & Jonny
Compare & Upgrade Headlight Bulbs
Overhaul Rear Axle
Nov 2017
Rusty Fuel Filler Pipe
Machine Panhard Rod Bushing
Weld Rear Left Wheel Arch
Replace Fuel Filler Pipe
New Wilko Angle Grinder & Power Drill
Sand & Paint Rear Arch
Cruising Through Pennines & Lake District
Fabricate Boot Release Handle
Free Boost Gauges, Overhaul Angle Grinder & Power Drill
Inspect Bosch LSU 4.2 Wideband O2 Sensor
Static Royal Wet Car Meet
Drill Bit Sharpening Jig
Rigid Drivers Bucket Seat Subframe
Castrol GTX Ultra-clean Oil
Dec 2017
Overhaul Lathe Tail Stock
Machine Clutch Cable Collar
Solid Passenger Bucket Seat Subframe
Fit Impul Supercharger on Abi’s K12
Faulty IGN Switch
Mar 2018
Meet LetsTorqueCars, Replace Outer CV Boot
LetsTorqueCars Filming
Fresh Pair of Semi Slicks, Car Meet at Dragonville & Scarborough
Replace & Machine New Inner Tie Rod Ends
First LetsTorqueCars Video
Apr 2018
Darlington Car Meet
Assess Tyres & Brakes
Rattling Rear Caliper Guide Pins, Replace Semi-Slick Tyres
Rattling Panhard Rod Bushing
CCS Drive Through Yorkshire Moors
Kuruma Car Meet at Dragonville
Yorkshire Dales Cruise & Dragonville Car Meet
Underseal Sills
Great North Air Ambulance Show
May 2018
Replace Fuel Filter
Fit De-cat
Car Meet at Local Marina
NE Autoshow in Sedgefield
Weld Front Crossmember
Painted Front Wings
E85 Car Meet at Teesside Airport
Weld Peugeot Cracked Down Pipe
Morton Park Car Meet
June 2018
Print Oil Vapour Catch Can Lid
New Rear Reg Plate
LetsTorqueCars Photoshoot & Filming
Reinforce Clutch Cable Ends
Replace Alternator Belt
Kuruma Car Meet in Sunderland
Reinforced Throttle Pedal
Test Misting Windscreen Wash Jets
Car Meet at Dragonville & The Café
Lathe Overhang Support Bracket
Lathe Hand Crank
Machine Catch Can Screw Threads on Lathe
Oyster Sauce Air Filter Heat Shield
July 2018
Cumbria Auto Show
LED Reverse Lights
Fabricate Steel Oil Vapour Catch Cans
E85 Car Meet
Local Car Meets & Machine De-soldering Nozzle
LED Rear Reg Plate Light
LetsTorqueCars Trackday Video
Volkspower Car Show
Remove Boot Wiring, LED Boot Light
Dairy Barn Classic Car Show
LED Bonnet Light
LED Lighting Switch, Boot Lid Bungs
Relocate Oil Vapour Catch Cans Behind Front Grill
Aug 2018
Reroute Bonnet Cable
Print Shower Sliding Door Support
Oil Vapour Catch Can Conduit Hose
Adjustable Dump Valve
Weld Seat Subframe for Lewis’s Lupo
Machine LED Torch Casing
MIG Torch LED
Test Adjustable Exhaust Resonator
New Delivery Driver Job
Replace Spark Plugs, Fuel Filter, Clutch Cable
Machine Gear Selecter Solid Bushings
Dyno Remaps Day with CCS Club
Sept 2018
Inspect Old Power Steering Pump
New Front Panel
Local Car Meet with Micras
New Exhaust Resonator
Start New Work Place
Rotate Tyres
Foam Boot Floor
Reroute Boot Release Cable
Prepping New Front Chassis Panel
Finding Concentric Clutch Cylinders for Gearbox
Strip Interior, Weld Rusty Floor Pan
Interior Insulation
Visit LetsTorqueCars & New Purple K11
Replace Front Chassis Panel
Oct 2018
Replace Down Pipe Flexi & MOT
Forged Piston Engine Blown Up
Assess Forged Piston Engine Damage
Assess Broken Gripper LSD
Fit Quick Release Steering for LetsTorqueCars
Dismantle Power Steering Rack
Gripper LSD Rebuild Kit
Preface vs Face-Lift Power Steering Rack
Rebuild Gripper LSD Diff
Replace Front Grill
Lockwire Gripper LSD Screws
Jan 2019
Assembled & Fire Up New Engine, Machine Restrictor for Enlarged TB Bore
Feb 2019
Weld MR2 Exhaust
Fuel Cap Release
Reinforced Upper Strut Brace
LED Bonnet Light, New Huawei P20 Pro Phone
Mar 2019
Epoxy Turbo Drain, Change Gear Oil, Ducktape Sun Strip
Soy Sauce Oil Vapour Catch Can
Spare Onboard Camera, Leaking Intercooler
Machining Thinner Wheel Spacers
Custom Stainless Exhaust for Octavia
Diagnosing & Replacing Cracked Piston Ring Land & Damaged Turbo
Replace Gel Battery with Lead Acid Battery
New Intercooler
MAF Air Leak
Collect& Assess Spare CG13 Engine
DynoRemaps Day
Kenco Oil Cap
Apr 2019
Refine LH Engine Loom
Electrical Breakdown / Corroded Fuse Box
Replaced ECU / Remove NATS
Rewire Nistune
Sunroof Delete v1.0
Omex 600 Standalone ECU, Machine Trigger Wheel on Crank Pulley
Malton Car Meet
Rigid Seat Belt Mount
May 2019
Rebuild Powerflow Exhaust Pipes
NE Auto Show
Cracked Ring Land 1 / Collapsed Fuel Filter
Datalog R33 Skyline / Given Spare GT15 Turbo
Machine Carbon Fibre Motor Casing for Ralph
Assess Broken Engine
Spare Engines from Andy Gray
June 2019
Rebuild Engine
Broken Gripper LSD Cover Plate
Panhard Rod Adjuster
Cold Air Intake
Puncture, Polish Wheels
Loose Gear Selector Linkages
Yorkshire Modified Show
Repacking Powerflow Silencer
Remove Door Strips
OEM Gti-R Discs & Pads
Turbocharge Lukes Corrado
Machine BBS Wheels to Fit
Monkey Polly
Service Heater Fan
Ormesby Hall Car Show
July 2019
Cumbria Auto Show
Rebuilt Turbotechnic S116
Aug 2019
Sun Roof Delete v2.0
Correcting Turbo Log Manifold from Andy
Repair Rusty Windscreen
New Alarm
Sept 2019
Rebuild Sills & Floor
Oct 2019
Peugeot 307 Gear Selector Cables
Fit Corsa B Coilovers on Jamie’s Micra
Nov 2019
Setup Corsa B Coilovers
Coilover Spare Helper Springs
3D Printer Cooling Duct
Fit Pneumatic Exhaust Valve on Matthew’s Octavia
Weld Rusty Scuttle Panel
Drill Bit Sharpener v1
Gear Stick Adapter for Matthew
Front Wing Repairs & Aerial Delete
Drill Bit Sharpener v2
Dec 2019
Install Alarm
Body Fill A-Pillar Gauges
Mod Scissor Jack Head
Vinyl Roof Wrap
Rubber Floor Mat Interior
Pass MOT, Falken ZE310 Tyres
Pressure Washer, LED Key Barrel Light
Enlarge Micra Exhaust Manifold
Jan 2020
New Hand Brake Cables, Sun Strip
Glove Box Lock
Steering Wheel Rattle
Change Oil & Filter
Check Simons Damaged Headlights
Air Intake Support Beam
Wynyard Cars & Coffee
Test Spare Blue Headlight Bulbs, Check Pad Wear, Weld Power Steering Line to Strut Brace
PAS Hose Leak
Replace Rear Disc & Pads
Feb 2020
LED Side Lights
Paint Exhaust Manifold, Fit Falken Tyres, Air Intake Support Beam, Test Audio Recorder
Compare Toyo & Falken Tyre Patch Area
Osram Night Breaker Headlight Bulbs
Emptying Oil Catch Can, Cruise Control
Collect Spare Wing Panels from Max Plextor, Replace Wideband Sensor, 70mm Throttle Body Elbow
Stereo External Audio Mic, Overhaul Adjustable Trailing Arms
Spare Parts from Dillan
BC Coilover 5kg Rear Spring
Inspect Spare MIG Welder
Overhaul BC V1 Coilover Suspension
Mar 2020
Extend Front Control Arm
Eye Injury
Black Bucket Seats & DAB Sony Head Unit, Coilover Covers
Setup Rebuilt BC V1 Coilover Suspension
Install Stiffer Rear Springs, Inverted Spring Adjusters
Install New Sony Head Unit, Fit New Black Bucket Seats
Repair Electric Window Mechanism
Repair Rear Arch Rust
Tweak Janspeed ECU Map
Test Digital Scale Accuracy
Install DAB Antennae
Testing Fake Onboard Cameras
Rebalance & Swap Wheels
Testing New Camera/Audio Setup
External Mic Cable Shielding
Extended Aluminium Wheel Nuts
Extended Steel Wheel Nuts
Correcting MIG Welder Chart
Remove Coilover Helper Spring, Machine Bump Stop Spacer
Apr 2020
Redesign Trolley Jack Frame, Mod Current Trolley Jack Higher
Weld Rear Spring Locating Cup
Remove Seized Trailing Arm, Machine Rear Spring Adjustment Collar
Repair Rear Chassis Rust
Weld Rear Spring Adjuster Mount
Exhaust Silencer Support
Spare Piston from SirChris, Install Overhauled Rear Suspension
Corner Balance New Suspension
Replace Alternator
Fit Normal A-Pillar Trim
May 2020
Vertical Throttle Cable Conversion
Paint A-Pillars Black, Painted Red Engine Cover
Paint Front Grill, Print Pressurised Brake Bleeder Cap
Overhaul Brake Calipers
Bleed New Brakes, Replace Alternator Rectifier
Walk Around Video of Kassandra
Blown Rear Speakers
Test Solid Gear Selector Mount
Testing Head Unit RMS Voltages
Roller Bearing Gear Selector Bushings
New Kenwood KFC-S1766 Rear Speakers
Stainless V-Band Decat Pipe
June 2020
Inspect Seat Belt Mechanism
Worn IGN Switch, Thicker Rear Speaker Wiring
Print IGN Switch Connector
Fit New Front Speakers
Weld Onboard Camera Support Frame
Diagnose Mohammeds NSX Fuel Pump Fault
Paint Rear Speaker Grill Black
Install Magnum Solid Bucket Seat
Compare Pre-Face & Face-Lift Seat Belts, Locating Rattles
Repair Rusty Rear Passenger Corner
Repair Garage Roof Lining
Compare Bucket Seat to Sports Seat, Trackday Prep
Jan 2021
Replace Rusted Rear Damper Turret
Driveshaft Nyloc Nuts, Mod 3dr Seat Belt to Fit 5dr
Fabricate Gas Cooker Burner, CAD Exhaust Flange for Paul Evans
Organise Box of Fasteners
Testing LED Brake Light Strip Location, Rear Speaker Cover
Feb 2021
Inspect Spare CG13 Engine
Refine Gas Cooker Burner
Replace 075 Battery
Replace Peugeot 307 Rear Caliper
Replace & Assess Fuel Filters
Fit Normal Oil Sump
Replace Tie Rod Ends
Mar 2021
Print Solid Steering Rack Mount
Install LED Brake Light Strip Under Spoiler
Paint Rear Seats Black
Windscreen Sunstrip
Door Pocket Cup Holder
Fit 307 Timing Kit
Extend Front Suspension Arm Bolt Head
Down Pipe Rubber Bobbin Exhaust Support
Convert Power Steering Rack into Manual Steering Rack
Shorten Wheel Nuts
Apr 2021
Creality Ender 3 v2 3D Printer
Organise Dashboard Wiring
Inspect Craigs Skyline Rusty Sills
LED Dashboard Backlight
Convert Power Steering Pump into Idle Pulley
Install Manual Steering Rack Conversion
3D Printer Fan Blade for Shaun
Test Drive Footage & Finding Rattles
Test Drive Through the Pennines
Digital Oscilliscope
Replace Power Steering Pump
Service Sisters Ford Focus
Azzam SR20 MAF Adapter
New Solid Steering Rack Mount, Power Steering Pump Leak
May 2021
White LED Dash Lights with Dimmer
Replace Sisters Ford Focus Rear Drop Links
Help Craig with Filming
Rear Bumper Damage
Decat
Fix Lathe Motor
Fix Leaky Tap
Fix Daniels Audi TT Spoiler Fitment
Tyre Camera
June 2021
Replace Bonnet
Fit Daniels Audi Gel Battery
Stanhope Printed Steering Wheel Holder
Repair Door Rust
Weld Daniels Audi Boost Pipe
Stripping Body Panels Off
Weld Doors
Respray Body Panels
Polycarbonate Rear Door Windows
Polish New Paint
Respray 2nd Attempt
New BC Racing BR Coilovers
July 2021
Cumbria Autoshow
Polish New Paint
Visit Stefan for Nissen Auto Radiator, CG13 Gearbox, CG13 Head & Gti-R MAF
Daniels Audi Meth Injection
Repaint Door Mirrors
Respray New Rear Bumper
Respray Front Bumper
Aug 2021
Vibe Edge EDB10A Subwoofer
Last JAE 2021
Crimp Battery Lug Terminal
Replace Cracked RH Headlight
Leather Parcel Shelf Cover
Sept 2021
Japfest Silverstone
Refine Subwoofer Wiring
Readjust Coilover Height
Fix Worn Clutch Pedal
Install LED Underglow Lighting
Scuttle Panel Rivnut
Oct 2021
Replace Damaged Airbag Light
Replace Starter Ground Lead
Battery Terminal Stud
Denso K16TT Spark Plugs
Halloween Car Meet
Nov 2021
Scissor Jack Hex Head
Machine Vac Cleaner Nozzle
Extended Tie Rods
Jan 2022
Window Louvres for Zafira
Print Pillar Drill Switch Cover
4 Jaw Lathe Chuck
Front Wing Cold Air Intake
Alcoholic Decat Pipe
Lathe Dremel Mount, Straighten 4 Jaw Chuck Teeth
Comparing Spare Front Bumpers
Alu Hose Cold Intake Ducting
GoPro Cam Mount
Change Coolant & Air Filter
Feb 2022
Replace Bonnet Latch Bar
Cut GT15 Turbo Housing
Replace Wash Pump
Mar 2022
Relocate Fuse box, Refine Cold Air Intake Ducting
Refine Scissor Jack Head
Replace Coilover Covers
Apr 2022
Install BC Racing BR Coilovers
Throttle Hand Control
GTIR Brakes for Trackdays
Clay Model of Kassandra for Bday
Japfest Silverstone
Correcting Lower Ball-Joint Angle
Replace Scratched Door Glass
Snapped Clutch Fork, Swap Gearbox
Replace Cracked Coolant Bottle
May 2022
Unity Show
Fit Boot Sticker
Fix Loose Bottom Ball Joint Rattle
Repair Broken Lathe Cog
Rotate Tyres
New Torque Wrench
Melbourne Powerfest 2022
Overhaul Gear Selector Roller Bearings
Rear Spigot Rings
Hooded Reaper Brake Cooling Duct
Replace Rear Bumper Beam
Onboard Camera Hardwire Power Supply
Damaged Exhaust Rubber Support, Wrong Spray Paint Colour
Repair Rusty Rear Wheel Arch
June 2022
Smoothing Rear Arch & Roof
Covid +ve
Respray Rear Arch
July 2022
Refurb Wheels
Jet Wash Engine Bay
Reseal Rear Lights
New Extended Wheel Nuts
Gravity Car Show
Replace Clutch Cable
Plywood Boot Floor & Subwoofer Mount
Doncaster Autoshow
Aug 2022
Replace Faulty Thermostat
Expensive Tyre Repair & Damaged Wheel
Front Grill Mount
Air Intake Pipe Mount
Pringles Intake
Camping with Friends
Replace Rear Wheel Bearing
Sept 2022
Air Filter Rattle, Refine Intake Ducting
Replace Fuel Hose
Oct 2022
Replace Bandsaw Bearings
New 3D Printer Fans
Polycarbonate & Steel Louvres for Zafira
Send Damaged LSD to Gripper, Replace Lower Ball Joints
Check Valve Clearance
Replace Fuel Tank Breather & Heat Shield
Adjust Valve Clearances
Nov 2022
Replace Alternator Loom Wiring
Inspect Spare Fuel Tank
Measuring Fuel Tank Levels
Replace Ignition Switch Wiring
NC500 Roadtrip
Gizfab Meet
Dec 2022
Gripper Returned Broken LSD, No Warranty
Replace Lathe Control Board
Passed MOT
Jan 2023
Ball Bearing Wiper Spindle
Mod Wiper Angle
Replace Wiper Arms
Drill Bit Sharpener v2.0
Feb 2023
Machine Janspeed Exhaust Flange
Battery Drain
Swap To Janspeed Exhaust
Cordless Grinder
Smashed Huawei Phone!
Bandsaw Guide Roller
Swap To Powerflow Exhaust
Mar 2023
Install 4in Exhaust Tip
Replace Falken ZE310 Tyres
Test Battery Drain
new GPS Tracker, Test Power Drain
Roadtrip
Replace Damaged Exhaust Bobbin
Rebalance Wheels, Replace Stainless Caliper Bleed Screws
Powerflow Silencer Issue
Apr 2023
Spare MAF Reading Issue
New Spigot Rings
Replace Mercedes E190 Brake Lines
Custom Suspension Spanner
Repair Cracked Downpipe
Found Front Left Rattle
Weld Mercedes E190 Rear Panels
Paint New Grill, Ducktape Windscreen
Jet Wash Engine Bay
Japfest Silverstone
May 2023
Unity Car Show
Swap TB & Cable Pulley
North East Autoshow
Relocating TB Elbow
Print MAF Mesh
Replace Damaged Gear Selector Roller Bearing
Damaged Front Brake Pad
Replace Nissen Radiator
Night Light Painting with Tripod
Test Weak Fuel Pump Voltage & Pressure
Repair Faulty Battery Connection
Light Painting
June 2023
Strip Dashboard, Reinforce Steering Column Support
200mm Clutch Replacement
Cooling Fan Override Switch
Reinstall Interior, Repair Cracked Crossmember
Finding Replacement Track Tyres
July 2023
Kulturschock Car Show
SayYouCan Fitness Programme
Redcar Fun Gala
Aug 2023
3D Model Primera Clutch Housing
Clutch Release Force Jig
DIY Tyre Repair Kit, New GoPro
Finish Welding Mercedes E190 Rear Panels
Replace Helix 200mm Clutch with Blueprint
Sept 2023
Rigid Radiator Return Pipe
Inspect Old Damaged Release Bearing
Repair Old Jet Wash Machine
Weld Peugeot 307 Sills
Print Manifold Jig Bends
Velour Roof Fabric
Oct 2023
Gizfab Meet
Straighten Door Frame
Replace Door Window Mechanism
Deep Socket Set Tool Holder
Superflex TIG Torch Hose
Replace Peugeot 307 Rear Suspension Bushing
Nov 2023
Bonnet Latch Bracket
Replace Horn
Roadtrip & Crash
Test Fit New Front Panels
Replace Door Hinges
Dec 2023
Replace Hazard Switch, Lower RH Ball Joint & Wipers
Weld Mercedes 190E Wheel Arches
Jan 2024
Replace Rear Brake Disc & Pads
Depression
Feb 2024
Print Stronger Cold Air Intake Duct
Top Mount Dust Covers
Replace Handbrake Cables
Jet Wash Engine Bay
Mar 2024
Inspect Speedo Pinion
Pipe Chamfering Tool
Lathe Tool Sharpener
Measure Fuel Level vs Gauge
Swap to Face-Lift Fuel Tank
Inspect Fuel Tank Parts
Insurance Renewal Drama & Mental Illness
Look Inside Fuel Tank
Replace Window Glass Clips
Planning Gripper LSD New Cover Plate
Blind Hole Drill Bit
Wideband Gauge Mount
Lathe Ball Turning Jig
Replace Bonnet Gas Struts
Replace Rear Speakers
Overhaul Door Mirrors
Gear Stick Heat Shield
Apr 2024
HSS Grinding Wheel, Organising Micra Spares
New Bench Grinder
Test Underglow Battery Life
Replace Door Seal
Bucket Dirt Guard
Japfest Silverstone
Clutch Pedal Roller Bearing
Repair Stainless Powerflow Silencer
Inspect Rattling Clutch Disc, Inspect old Helix Clutch Disc
Repair Impact Wrench Wiring
May 2024
Swap to Powerflow Exhaust
PS2 Roadtrip Adventure Game with Micra
Fix Door Frame Rattle
Overhaul BC V1 Coilovers
Print Focus ST Headlight Washer Jet Covers
Strip Front Doors to Stop Rattling
Paint Oil Sump
Adjustable Gear Stick Ball Joint
Door Card Fabric Cushion
Passenger Seat Rigid Support Frame
Weld Rattling Door Stopper
Window Motor Support Bracket
2nd Cordless Grinder
June 2024
Replace Scuttle Panel Rivnuts & Alu Screws
Clean BC BR Top Mounts
Compact Alternator Bracket
Replace Lathe Motor Cog
Machining Gripper LSD Cover Plate
Replaced Auxilary & Alternator Belts
White LED Light Wand Night Painting
LSD Bearing Separator
DIY Hydraulic Press
Gizfab Meet
July 2024
Inspect Spare Gearboxes
LSD Side Bearing Puller Tool
RGB LED Light Wand Night Painting
Raise Engine Crane Wheels
Mini Torque Wrench
Remove Gearbox
Rebuild & Install LSD
Weld Rattling Clutch Disc
Test Drive New LSD
Brake Pedal Roller Bearing
August 2024
Ultimate Show Car 2024 at Santapod
Assess Broken N/S Driveshaft
Repair Porche 550 Spyder Gear Shifter
Spare CG13 Driveshafts
New Thicker N/S Driveshaft
Porsche 550 Spyder Gear Selector Bushings
Compare Driveshaft Splines
Engine Gasket Kits
Weld Rotary Valve Back onto Steering Rack
Print Gear Stick Pivot Mount
Unity Car Show 2024
Install Converted Manual Steering Rack
