Enuo
Glorified Electrician
Probably a more scientific way of doing it, just more expensive.shall I work up the grade progressively? 15w40 semi - 20w50 semi
or fully synth
or you recommend sumthing? have no idea what the ideal oil is
or fully synth
mind was thinking am I allowed/covered, what if? and before mentally answering thought ah fookit
sit in, seat was fixed so had to adapted position like when I once drove the oversized-kart ariel atom. what a privilege to experience such extreme experimental beast from the skunkworks of frankville
That's correct but the oil doesn't change once warm its still there. Its an equal mix, for example 10w40, you'll have 1 parts 10sae with 1 part 15sae etc up to 40sae. The w refers to performance in colder ambient temperatures where oil thickens in the cold so you'll need thinner oilandy n andy, according to wiki the first number ahead of W is the cold start viscos and the 2nd number is the hot viscos?
went to halfords to see if there's any thick synthetics and nearest I found are some 5w50 synth (5w when cold maybe too thin for a very slack forged piston? ran it before with the new bore/used ring setup and made no difference to oily piston), and 10w60 mobil1 (hot grade tis prob as thick as it gets and tis fully synth too)
you think that'll run in the cg13de ok with +10C thermo and slack pistons and ok'ish new bearings?
if this doesn't work then nothing else at all will
this is cutting edge cocking about
increasing oil thickness is literally the only last thing I could do now short of a complete unfeasible expensive rebuild or bin it.
suppose when I swap back to stock, even if the pistons only slightly oily, I'll pop it through some emissions machine (local garage or my cousins) to see if the oil burning is actually enough to fail the mot
Register your car over here mate instead im sure there would be problems with insurance etc with you being across unfortunately
Neither is the gap between rods n shells, ring gaps n piston to bore clearance but any small increase should be accountableP*ssing in the wind honestly. The difference in viscosity between a 40 and 50 oil isn't much, you're talking 5cst based on average grade values
It'll give you a definitive answer at least
P*ssing in the wind honestly. The difference in viscosity between a 40 and 50 oil isn't much, you're talking 5cst based on average grade values. A heavy classic grade like 20w70 may make a dent but it's sadly only a bandaid to a larger underlying issue :, (
It's bite the bullet and get an engine builder time surely?
you was having more fun out the stock engine,this ones dodgy from the start i recon,other wise they'd have used it themself ??? maybe maybe not.
What's the dimensions of the pistons Paul?
Trying to find you some wiggle room.. but you none really... have you looked at the pistons once theyre warm? Or took a temperature reading of them?
Maybe an idea? See what temp they're getting too and compare that to the JE Specs?I've videoed the pistons with the scope and they appear the same oilyness hot or cold. not measured the piston tops with IR yet
Thicker oil has worsened it10w20? 0w20? 10w30?
I wouldn't suggest going too low. Maybe 0w30 as your lowest grade
Could well be but you've had them all out recently and were clean. You could be right there could be a fault with the oil rings themselves.do you think all these symptoms I'm having is similar to clogged oil ring drain back holes? stuck oil rings?
ie. as if these JE piston oil holes are too little too few?
ok I'll try 0w30 synthetic tomorrow
the different oil weights have done sweet F/A really paul, the oil control rings are the key factor imo, the consumption/smoke issues have only reduced when you increased the pressure of those rings really
You've had them out re-spec'd them and still getting the issue :/
Do they suggest a certain oil grade? I'd say oil grade is vital to such a fine a tolerance as this setup is
Aye I'm with you on that one. Had a thought last night a thicker oil will have/need a higher pressure to move it around.I meant could the restrictive oil drain back hole design flaw show a similar symptom to stuck/clogged oil rings?
rings when fresh we're gapped perfectly.
after bed-in they've worn in slightly wider due to the smoothed larger bore but still within spec.
no mention of oil, temps etc etc on their sheet, just the clearances
Dont give up. Take a break and come back another day
With the amount of time, money and effort that has gone into this project I feel I speak for everyone when I say how sorry and sad I am that this is how this chapter ends :'(
Sometimes, as hard as it is, the right decision can be to just cut your losses and walk away.
Paul, you are an inspiration to us all and your willingness to share your experiences and r&d with other members is to be admired.
Whichever direction this project now takes I hope you don't lose your mojo and you come back stronger than ever to keep us educated and entertained.
Good luck Paul and thank you, whatever happens
thank you micrAde
well that was an expensive lesson ain't it
First of all, just Ade please Paul
And second of all that sounds like marriage lol
At least with a stock engine you can continue to enjoy the wonders of boost
