pollyp
2024-05-27 Adjustable Gear Stick Ball Joint
Been noticing the gear stick tends to shake a lot whilst in 5th gear cos the ball joint was worn & too loose
I tried to print a tighter fitting insert but getting the tolerances right was a PITA and doesn't compensate for wear
So I redesigned a whole new 2-piece mount that can adjust how tight it fits around the ball joint
Printed & installed new mount
added rivnuts so the mount can be screwed on from the top rather than originally getting underneath
fitment is soo much better, precise & zero play.
gear shift is slightly more precise and doesn't shake around anymore
