The tyre shape was more of a give-away than the chain
Its all good getting this data, but you need to be able to have the ability to adjust to accomodate for it.
First of all would be corner weighting, you'll need to be able to adjust that accurately to make use of the data. As you'll need to adjust load before you adjust alignment (camber, caster & toe).
Load will be adjusted by preload, which at the minute is what you're using for crossweight
Free up those height adjusters to achieve the 50/50 crossweight, then we can use preload to adjust the tyres load whilst on track
Then we'll have to find a way of adjusting your caster angle. For example if the camber angle we have is perfect for our handling needs but we need to reduce it due to tyre temp. Then we can increase caster to reduce our camber angle. But if we've no caster adjustment?
Like I say, logging data is one thing, making use of it is another
