here's the rebuilt LSD for the 2nd time
but hold on, that wasn't like that before
gArgh someone at gripper needs a good bollucking cos it's obviously been dropped and dinged a section of the 1mm thick bearing cage
further thinking, maybe it could've been dropped badly during parcel transit? wasn't labelled Fragile
I can't straighten it up with pliers but don't think its a major issue and it'll still roll but certainly won't help cos the once straight edges of the cage now bends in slightly at the edge of the roller bearings and could wear it out abnormally?, especially since I push it on track. that'll bug me
before servicing, lets check the preload torque. insert the spare driveshafts, secure one end on a breaker bar and my electronic torque wrench on the other.
slowly increase torque till it slips and the wrench shows the peak torque the preload provides is 55Nm (in future I can lift one wheel and use the wrench to monitor the preload torque monthly against this reference and spot if it fails again)
to undo the cover, I insert the cogs and engage multiple gears to bind/lock/hold the diff before loosening the bolts in a diagonal progressive manner to prevent warping the parts
the new preload ring
the previous rebuilt ring on page 51 had a heavily copper coated appearance, while this new one looks abit darker so maybe a new batch?
old preload ring was 2.6mm thick with a conical offset of 1.2mm
this new one is a slightly thicker 2.66mm and a conical offset of 1.04mm
now lets measure the plates and see whats been replaced or swapped (before -> after rebuild)
Outer Plate 1 (1.89 - 1.90) same
Inner Plate 1 (1.74 - 1.73) same
Outer Plate 2 (1.10 - 1.54) swapped outer plate 4 to outer plate 2
Inner Plate 2 (1.54 - 1.53) same
Outer Plate 3 (0.95 - 0.94) same
Inner Plate 3 (1.53 - 1.53) same
Outer Plate 4 (1.55 - 1.34) new plate
Inner Plate 4 (1.55 - 1.53) same
previously the total plate thickness was approx 11.85mm with a 2.6mm thick preload ring and 1.2mm offset = total 15.65mm free length
tdays rebuilt diff has a total thickness of approx 12.04mm with a 2.66mm thick preload ring and 1.04mm offset = 15.74mm free length
given the distance between the planet driver surface and the LSD cover remains the same, the new preload ring seems to be squeezed tighter.
planet driver
before reassembly, always good practice to tap & clean all threads.
gripper technician clearly hasn't, even though the bolts been 'blue' thread locked upon arrival, cos here you can see the remains of the old 'red' thread lock on the thread tapper
(yes r-reg I sense you'll be commenting bout the Matrix-like 'red/blue pill' theme
this is why I tend to disassemble and reassemble stuff I've received/purchased, even if it's new, cos in most cases it's never built/assembled carefully to my level of quality attention to detail.
prob a mild form of mechanical ocd/perfectionism? but tis just piece of mind to know that I've triple checked the things been built correctly so it'll function efficiently and reliably (learned since old days of weekly overhauling my bicycles). if ya want stuff done proper, you do it yourself eh
now a long video of reassembling the LSD
rechecked the preload and it remains 55Nm.
