PollyMobiles Rebuild
i looked inside the inlet ports and no sign of leaking inlet valve stem seals. drained some oil till its at 3/4.
started her cold and still no good. first 15sec the exhaust is clear, then the blue mist slowly builds till its a mix of blue mist n steam, garage is full of blue mist for 3mins then it becomes a white steamy mist of water from the cat.
i'm at a loss here. once again something in the engine has gone wrong and burning oil before ed tunes it, not ideal.
i tried uploading the stock map with the turbo MAF & injectors and it idles lean n lumpy at 15.8afr but revs 3k at round 14.7 with help of the o2 sensor
turbine seal? how do i find out? maybe take the gtir elbow off n see if the turbine is damp?
i doesn't smoke from cranking to 15secs, so its not pooling oil. nor smoke at all under full power or vac or idle once the exhausts heated up.
it just seems like the oils too thin when cold like when i was using the 5w50 on her.
should another flush with new 10w40 maybe get rid of the old 5w50 incase some remained?
Blue smokes not good, pull the air filter off and check for play in the turbo
I guess it's not smoking for first 15 as engines not hot enough to get oil to turbo seals to start leaking
Me personally I'd stick with 10w 40w as that's what it was designed for by nissan
I bet as much as you love your turbo do you sometimes get the hump and think if the convenience of NA?
If you remove the turbo from the exhaust and run the engine to see if the smoke comes from the ports then that rules out the turbo, also check the oil drain is free from blockages
gonna check for play in abit
yeah it takes afew secs to build enough oil pressure to the turbo
anything other than stock exhaust is bound to cause an issue. just gotta stick at it
neighbours won't be impressed at the noise of running without a manifold :/
would a blocked turbo drain not cause it to smoke when warm and at high load/vac too?
daren't risk it. i'll just loosen the filter to let the trapped oil out.
stani i think ur right.
while draining i saw this
apart from the bad drain seal i prev tried to fix with several copper washers, the turbine housing now has an oil leak which could be a damaged turbine seal = turbo overhaul:down: and would explain the burning smoke n smell from the engine bay this morning and maybe the awful emissions?
i doubt i could get the turbo rebuild kit in time so a thicker oil is my only option. unless someone knows where i can physically buy the kit to fit before monday?
hang on i found a kit on ebay for £45, txting them if i could pay & collect the kit if i drive over fri night after work
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120776948612
or blackpool
http://www.ebay.co.uk/itm/Turbo-Reb...arts_Vehicles_CarParts_SM&hash=item5adec29f80
changed to 15w40 last night. this morning same story.
start engine and clear for 5sec, then theres steam for 15sec which turns to blue'ish steam that hangs about for 1min then back to white steam, maybe its the pool of residue left from the 10w40. driving down road still has a burning oil smell when stationary from the burnt residue on the turbo casing.
driving to work might've burnt off the last residue. if the thicker oil has worked it shouldn't smoke as much when i restart her this lunchtime.
still smoking from cold.
tried to drive over to blackpool at lunch to get turbo seal kit but A1 was shut n diverted prob cos of a crash. whole things a car park and nav said couldn't make it in time so had to ring the guy n ordered the t2 turbo rebuild kit and also added a staggered rear oil seal ring cos decatting may cause a normal one to blow, all sent next day for £75
http://www.ebay.co.uk/itm/390284353408?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
http://www.ebay.co.uk/itm/Garrett-T...arts_Vehicles_CarParts_SM&hash=item4aa8ed537d
well turbo's out
bit of oil vapour from the breather, need to sort that out
inside the exhaust ports are dry n normal so not burning oil from there
turbo exit coated from that octane booster
video of the amount of bearing play
turbine looks fine
and inside the turbine housings dry
blades n shaft marked
the compressor nut was very tight. stuck the turbine nut on a hex socket and had to buy an 8mm o-spanner to undo the retaining nut clockwise. and then the compressor fan was a fairly tight fit to the shaft, after alota twisting n pullin n wd40 it came off
remove circlip
this plate was tricky to remove. had to fiddle with some thin flatheads to carefully pry it out
the 3 torx bolts are really! tight, bent my soft £ shop torx key. gonna have to buy a harder torx bit from hardware store
turbine shaft slides out with a light tap
signs of burnt oil deposit?
quite thick
maybe burnt deposits were building up and the rear seals failing. how do you remove & fit the rings?
any seal leakage would travel down here would it not paul ?
the compressor side was slightly oily cos the rocker breather was plumbed straight to the inlet with no catch can. i'll need to clean out the intercooler from oil. the pipes from the IC, through the GTIR MAF and into the TB isn't oily so think the mist just stays down the intercooler.
the rear of the housing shows more signs of light oil burning and some radial oil spray on the turbine backface.
at idle the turbo doesn't move so maybe when its cool the rear seal tolerances are too great, not helped by the slightly worn bushes, and as oil pressure builds after 15secs its forced out through the stationary rear seal gap and burnt. once the turbo's heated enough after 2min the gaps close up.
your oil pressure will be at its highest while the engine is cold eh paul, (1st minute ?) then the pressure will drop as the oil warms up/thins down i guess
well tday i need a mini circlip plier to remove the bushes and a hard torx bit to remove the thrust bearing and i'm also awaiting the important delivery of the turbo service kit.
if i go with me sister to buy the tools i could miss the delivery and not service the turbo in time. so she goes to get the tools while i wait at home.
she came back first. the torx bit was able to removed the thrust plate but the pliers were for normal size circlips so had to dremel em abit
circlip off and bushes removed
using the pliers in reverse i could remove the seal rings
hear a van arrive and immediately opened the door before the guy could figure which house it is :p
turbo kits arrived
stepped rear seal ring
went to remove the front seal ring and Yikes it snaps:eek: if the new one snaps this easily i'll be doomed
was soooo nervous fitting the new ring. it required so much precision n steady hand to stretch it JUST enough to slip on, had to abort it several times but eventually got it on
stepped rear seal ring vs normal ring
fitted
new bushes fitted
new front plate
new thrust bearing appears to be brass while the original was prob aluminium
brass thrust bearing has T28 stamped
front plate fitted
the compressor wheel is such a tight fit on the shaft. had to turn n push it down hard almost cutting my fingers on the blades.
the shaft has much less play now
housings fitted
tried to get a new full width alternator belt of similar length but its too long
new manifold gasket
turbo on
cleaned the IC pipes from oil and reassembled everything.
started her up and the exhaust steams up once again after 15sec while it warms up, was hard to tell if its just a big ploom of water vapour from the cold exhaust pipes or a hint of oil smoke. engine bay smoking abit as the residue oil burns off.
but with near bearings n seals i noticed the turbo's now spinning at idle.
went for a drive to heat n burn off the oil stains. doesn't smoke at WOT or high vacuum or at warm idle. cooled for few minutes and still doesn't smoke after a warm start, so far so good.
see if it smokes tomorrow morning
added vid of the turbo shaft play.
cold started her this morning and it appears to be mainly alota steam coming out throughout 15mins of idling but the turbine housing is still leaking & burning abit of oil :/
uploading video
took her out for afew blasts to heat things up and no longer steams or leak from the turbine except for the usual drain pipe fitting, just like before.
leaking oil from the turbine housing is surely the rear seal eh?
Remap Turbocharged Standard Engine
feels like this car wants to die:(
such a crap week.
first the turbo seal blew,
then i almost had 3 accidents going to/from Ed,
then the crap newspaper manifold gasket blew during remapping,
then it failed the emissions test AGAIN with the same readings:wasntme:
now there's this serious over-rich flatspot at 3.5k on the new map,
then i coudn't do a full nistune datalog for Ed cos the consult kept disconnecting from interferance,
and finally this morning before work while trying to swap the old manifold gasket, but ran out of time, i forgot to fit the dipstick back so oil is spattered all over the front end :mad:
WHY! ffs
worst week ever. this turbo will prob never pass the mot.
gonna need to cool off before i could report back fully
ok i fitted the old manifold gasket back on and really tightened the turbo drain pipe to try stop it leakin.
here's the rubbish failed cardboard gasket
tested my previous turbo map and it works fine like before.
loaded up the new remap
fuel map
timing map
did some WOT datalogs in 1st, 2nd & 3rd gear
1st gear is fine, wheelspins at high rev
2nd gear fine, the issue sometimes happens
now in 3rd gear revs go upto 3k when suddenly it halts, boost is still 10psi and mixture goes 10AFR but you can see the timing just goes -21deg! (dizzy position was wayy off btw so that's prob -10deg) so no wonder it stopped making power
looking at the timing map it looks like the timing goes haywire once it enters the blue flagged section
then timing retards to -21degfwn
whats on earths goin on there?
a micra turbo does not need a cat test to pass an mot..
the mot testers flow chart for emmisions (doccument 7) states that if an exact match for the vehicle to be tested cannot be found in the database then a non cat test must be carried out"
and since a turbo micra never existed.... bajingo...... no cat test.
doing the same thing with the MR2. a 3.0 v6 mr2 never existed, so no cat test.... regardless of year as they have nothing to go on...
i mean a turbo micra is never going to pass the cat test for a non turbo one is it?
oh and the best bet for mani gasket is pressed from copper, then anealed under a flame and cooled to soften it, then use that.
it will hold much better than any paper style gasket and the soft copper will fill out any imperfections in the mating surfaces too.
i thought the mot guy i just went to said that they'd test my cars emission according to the reg so treats it as though its stock irregardless of its configuration. and yea its near impossible to get it to pass without leaning it out heavily and affect drivability.
i need to check up on that regulation
the old gaskets holding on for now. gonna try the new expensive nissan gasket.
how or where can i get a copper gasket made?
need to get summore thicker copper washers for the turbo drain fitting cos its still leaking tiny amounts
ok this morning i thought i'd try deactivating those blue flag cells in the timing map but couldn't just press O key like the o2 closed loop flags on the fuel map, had to go into raw data mode and saw the flagged area values shoot up from 20 to 150​
filtered values mode are
so copied those values into the raw data
tried it down motorway and it works
reason why this issue didn't affect the prev map was cos the rev scale was different. previously the scale only went up to 4k so i never reach the marked region of the timing map. now with the new map the rev scales up to 6.4k but the same cells are marked which means that at 3k i enter that cell region and so timing goes wack
/QUOTE]
Surely that's never going to fly as its just a modification to a stock micra therefore has to be tested as one?
/QUOTE]
yeh , the mot guy just types in whatever engine code is on the block and it comes up on his screen, the exact match thing is if they cant find an engine code anywhere
just went for another blast and yep the timing issues def fixed
wonder if the paddle clutch is glazing cos it slips if i upshift 1st to 2nd too early from standstill at wot
checking its not smoking on the morning before the remap
Ed remapping the turbo
this morning going to work the timing issue was still there when i got WOT at 0:09s
then at 5:20s i fixed the timing values and it accelerated no probs
