pollyp
Mainly scattered within this blog. The shifter mount still needs refining imo cos the fasteners keep loosening up ?Do you have your 3d printed designs posted anywhere? I would love that shifter adjustment
hehe it's a tasty dining tablethought ya had a massive bag of smarties as well there paul![]()
Great work Paul. If you do bushes like that in future consider using 'Nylatron' instead of 'Nylon', it has far better wear properties..... https://www.mcam.com/en/products/shapes/engineering/nylatron-ertalonThe next thing to fix for the Porsche Spyder were some bushings for the gear selector shaft
there was surprisingly only 1 bushing per tube (one near the gear stick and the other underneath the engine) and they were seriously worn out
there's 2mm gap from the 18mm selector shaft!
ordered some nylon
cut to length
machined the outer groove & 18mm hole
2 new bushings fitted
now the shaft is supported with minimal play
removed the strut brace containing the PAS hoses
bit more room without all that plumbing
removed the tie-rods
disconnect the column joint
removing the bulky PAS rack required lots of wriggling
power steering rack vs manually converted rack
fitted the manual rack but frustratingly whilst turning the wheels on the ground, the pinion once again kept clunking up/down by 5mm & popping this plastic dist cap off.
I'm sure I welded the rotary valve in the right spot
but looking back, what I previous thought was just a dust cap turned out to be a load bearing threaded cap which keeps the ball bearing secured to the rack to resist the pinion shaft thrust forces
so I machined a new cap
screwed on and now it doesn't clunk anymore and feels solid & secure
aligning the steering joint to the pinion splines so the steering wheel has equal amount of turns lock-lock
tied the throttle cable & loose loom out the way, ready to test drive
during startup, the throttle cable was slightly sticky so I rerouted it better
steering was obviously very heavy under 5mph, especially when turning lock-lock out the garage, leaving T-junctions & going slowly at roundabouts where the LSD engages, requiring slight change in driving habit.
5-30mph the steering weight felt normal.
at high speed the weight feels light, very responsive feedback during turn-in (great on track) but during mid-corner the wheel starts to feel slightly heavy under the cornering forces, especially when accelerating & the LSD locks up.
she also feels rather nippy.
dunno if it's the conditions, placebo effect, reduced weight or less hydraulic drag from the deleted power steering pump providing more HP to the wheels
I'll be curious to see if this also improves mpg too.
thanks m8Thumbs up for all the info you have on the k11!
I would like to pick ur brain about something.. i have a bc racing br ra coilover set, saw you have the same one but with 5kg front 4kg back, how does this hold up against the v1 6kg front 3kg back?
I have a s20de+t swapped stripped k11 also with the br ra set currently on 7kg front spring and 5kg back springs with shorter back dampers this because i wanted to go low low, now that i am over that thinking of putting the original dampers back on , i would like some better handeling, in stead of doing just dragraces, what would you reckon with the heavier front and empty back for kind of springs to go to? i was thinking of getting the back to stock 3kg springs, but the front i am still thinkering about.. hope you could give me some insight on that since you do/did track days.
Sorry if something like this is allready asked but so many pages haha.
