What material did you make the new seal out of Paul? Hope it wont degrade/fail when in contact with pressurised hydraulic fluid.........ever since I brought this cheapo Halfords 2 ton trolley jack, the hydraulics have always struggled to hold up. I'd jack up the car and it slowly drops back down no matter how tight the relief valve is.
something ain't right so lets inspect it
removed the piston and straight away found the issue
it seems during manufacture, the piston wasn't assembled carefully which nipped & folded over a section of the plastic seal against the bore, making it leak
View attachment 55416 View attachment 55410 View attachment 55408
even after correcting the defect, it's still permenantly deformed and won't seal so I decided to machine a new seal on the lathe
it fits really snug, luv precision
reassembled and wow it now performs perfectly. job fixed
View attachment 55415 View attachment 55409
Wouldn't have thought that nylon was suitable in that application Paul... See HERE for some info on hydraulic seals/material..it was given to me as spare, think it's nylon
Well done for not just being part of the f*ck it and chuck it mindset, going out of your way to fix stuff and make it betterever since I brought this cheapo Halfords 2 ton trolley jack, the hydraulics have always struggled to hold up. I'd jack up the car and it slowly drops back down no matter how tight the relief valve is.
I do hope that you always use axle stands under the car when you use it then Paul, because if it does fail then it may well just collapse without warning......the old broken seal looked like hard beige plastic nylon. I don't care if it's the perfect suitable material tbh, all that matters is that it works, it maintains pressure and I can get on with stuff. it's not worth the extra time, money, effort to get it perfect.
there a fella over on retro rides polly thats into all this 3d printing stuff, built his own machine http://forum.retro-rides.org/thread/200068/3d-printing are ya not a member on there yet
You do understand how hot catalytic converters get Paul? Don't give much to your chances of your HG material gaskets lasting very long at all. You would have been better off making the gaskets out of copper sheet (old immersion heater tank?)with a better fitting lid, the catch can caught 100ml of vapour after 1100 miles
the gasket for the 2nd cat has been leaking abit
the inlet full of soot
while the outlet is ok
had some spare HG material so made a temporary gasket out of em. not exactly the right stuff for exhaust but it'll hold for the weekend of thrashing the car
View attachment 55480 View attachment 55479
washed & packed ready for japshow finale
made a little gift micra for a friend I'm seeing tomorrow
View attachment 55485 View attachment 55484 View attachment 55489 View attachment 55487 View attachment 55488
Take them with you Paul, just in case the HG material disintegrates.it's a decat, got no copper sheet and I've already got some new gasket to fit afterwards
Now that looks bettergonna fit em tomorrow morning before I set off.
so the local shop had these for the micra, from a modeo but the bolt holes are spaced 105-115mm whereas mine are 95mm
View attachment 55490 View attachment 55491
fixed with dremel
WTF like a nightmare ...Fri 29th
removed the decat and the thin gasket made from HG and although it just blow a tiny amount it held up fine
View attachment 55512 View attachment 55511
fitted the new exhaust gaskets with the cat ready for MOT next week and I can't hear it anymore now
went down to swindon to visit sophie. we went for a drive, kebab and some karting, was a good night
getting late near 10pm I had to set off through the night towards Abi in salisbury asap cos we got an early morning for japshow finale at santapod.
satnav took me through some weird pitch black quiet sweeping country B-roads, which was quite a blast in kasandra.
but near Wilcot going 40-50mph with full beams making the scenery appear bland/flat, I saw the slight left bend on satnav but it doesn't tell you about elevation bumps and I didn't spot the small bridge & bend warning sign.
going over the sudden bridge, I saw the casted shadow of the headlight over the hump and thought Oh a crest hump, followed by screaching of the front tyres going light & skidding as I braked, suspension droops down fully going over the bridge followed by a bang! and then the steering veers off to the right towards the bush/trees and the road curves left so I'm having to turn left 90deg to keep her straight (there's a slomo moment where I saw kasandra heading towards the trees and I thought ####! there's nothing I can do in time and this is gonna hurt )
but luckily I was able to steer back onto the road, steering at 90deg, tyres rubbing badly against the arch. was thinking did my welded balljoint fail?
Hmm yeah I can't exactly drive all the way to Abi like this so better pull over.
drivers wheel was pointing the other way. looked under and holy ####!
the arm had snapped off the front mount. crap, I can't mend this and ain't got breakdown cover.
phoned Abi that I'm in trouble and can't make it with a broken suspension. I was able to send her my location on this unknown road middle of nowhere and abi/jonny immediately came to my rescue.
we were 14miles away with some hilly & sweeping bumpy roads so it's gonna be tricky to nurse it back.
my battery is dying. leaving the headlights & hazards on to warn drivers in this creepy dark road, it quickly drained the power.
jump started from Jonnys car and left the car running to charge the battery.
I tried attaching the front mount with the only zip ties I had, I moved 3 inches and it suddenly broke all the zip tie notches.
tried even more zip ties along with a length of electrical cable from my hand drill and again it didn't hold
things are getting desperate. some ppl on Abis FB offered help with trailers but never arrived.
abi rang AA, RAC, etc for quotes on getting it recovered back to her place and they quoted either £115 with £15/mth annual subscription (£300) and some said £350!
I was really considering just abandon her to the side and come back in morning with new arms to fix her.
abi was given numbers to afew smaller local private recovery places and was quoted £205, I was concerned about kasandras safety being left here and thought fook it, pay the premium and at least she'll be safely home to be fixed.
it was a long cold wait in the car and we were all tired at 3am
the flashing recovery flatbed soon arrived, guy inspected the damage and getting it onboard would be tricky.
he attached the winch to the LH arm and pulled the car towards the flat bed but the drivers wheel began to veer off outwards Woah woah stop stop!!
it could collapse and pop the driveshaft out spill all the LSD oil.
without any stronger zip ties or metal wires available I was clueless what else to do
could we just leave it here? guy said ppl could report it to police as obstruction and they'd end up calling the same recovery guy to get it off the road by any means (even if it rips the wheels off) and I'd lose the whole car so I was in a difficult spot and time was ticking away.
I wanted to reattach the arm and try again slowly, guy was ok with that cos it's his last job of the night.
he got a ratchet strap and decided to ratchet both arms together and it worked
we pulled the car on the trailer intact and got it back to Abi, we're saved.
paid the guy and now wallet's empty
Well Paul, you have very effectively high lighted the high stress points on the K11 wishbones!wirebrushed the damaged wishbone to analyse how it failed. notice how the damage had twisted how the tube sits on the arm
looking at how the crack propegated it looks like it started here where it wasn't welded all the way and left a hollow undercut at the corner making it a stress riser
a view of one side of the crack on the bushing.
the twisting damage had torn abit of the arm, circled.
view of the other side of the crack on the arm
the shocking discovery was that I fitted these cheap ebay arms back in early 2015
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-122#post-711708
and in the photo's the welds appear exactly the same which means this was a manufacturing defect and not caused by my welding.
which is scary.
so here back in 2015 it appeared to be barely tack welded
but looking now it's actually a cold-weld with zero penetration!
another look at the bottom weld from 2015
and that hollow undercut in the weld started a crack
View attachment 55542 View attachment 55543
with the arm literally hanging by the last few mm of metal here, it ripped the metal in afew places. I'm not sure about welding up & reusing this compromised arm?
John_D, what's ur thoughts?
I'm thinking I should scrap this damaged arm,
use the newer arm, adding reinforcements to both arms and I'll have to remachine some spherical bearing mounting cups once again to weld onto the new arms.
it'll take more time & cost to start all over but after this scare, it's necessary.
I'm preparing myself for potential breakages in the coming weeks Paul, once I see what this new turbo puts out
Looking good Paulremoved the new spare arm (bottom) and ready to fit the repaired arm (top)
the £39 arm from eurocarparts made by Starline 615700249 has a much better quality control than the cheapo £25 ebay arms that broke
notice every single weld has been inspected via the green dots
View attachment 55557 View attachment 55556 View attachment 55559
the front welding is more complete & smooth
View attachment 55561 View attachment 55558
fitted the repaired arm ready for it's MOT on saturday. gonna fit swaybar & check the other arm after MOT cos I don't have the time.
Looking good Paul
I did something very similar Paul. Did some work on the front brakes on my daughter's Primera P12, did one side, got back in the car to turn the steering straight again, put the key in the ignition and it wouldn't turn/unlock the steering. Tried it about three times before I realised I was using the Micra key on my bunch of keys and not the Primera key, on her bunch, which was in the same pocketgetting ready for MOT tday, I connected the battery, IGN on and the engine light was flashing?
eh what's going on kasandra? crank, and doesn't fire up. oh wtf not now
checked for fault codes in datascan and shows "error code E1 & E6 after 2 starts"
sensors say the injectors simply not firing, Oh come on! there's no faults with any connectors, injectors, ecu etc etc
was almost about to abort the MOT when I then realised I've inserted the spare key when I was fixing the suspension
the master key was still in my pocket, used the proper key and wahey it fired up! Doh
