It's taken me all night to get to this point.
-marking and centre punching and drilling the 2mm holes on the tray.
-position the tray on the engine.
-mark the holes location on the girdle cage with the 2mm bit through the predrilled tray holes.
-take off the cage.
-spirit level the drill press.
-prop the girdle on the drill base with some wood till the tapered surface i'm drilling is level and square to the drill.
-drill through starting with a small 2mm bit to maintain accuracy then gradually enlarge.
had a brief scare here cos i was drilling the first hole and when i thought the drillbit was abit blunt i pressed abit harder, heard the bit stutter and then ping, it snapped inside the hole
worst nightmare. but to my luck it happened just as it was about to come out the other end (the girdle main bolt holes) so got a small nail and hammered the broken drill bit through and out the other end n carried on with a bigger drill. note to self, NEVER force those small drilll bits or they will snap and cause a major issue.
-what i first did was try to drill the holes on the girdle cage and tray seperately and hope they match, which didn't work.
-so what i did and should've done was clamp the tray into position on the girdle and drill & tap all the holes in one go.
tray bolted on
bolts angled square to the surface
will need trimming shorter
