@sleeper ss
i have 4 other cars that i play with.
1 Micra + 1 micra ( have 5 Micras in my family though )
1 Toyota Starlet rwd
1 vw beach buggy
The picture is from my Toyota Starlet that i want to finish before next " season " starts.
But here is some more stuff on the Evo cylinderhead build :
Before i can do the last work on the head i need to take care of some minor details with some control measurements and adjustments.
Now that I have more lift at the valves I have to check the clearance between the valveseal and the lock groove etc. Just as a precaution to be safe.
Using this little gizmo
Tapping it lightly to rest on the valve guide
Open the valve to the new lift = 9.5 mm
From underneath one can see how much that lift is at the valve
Checking clearance
Next to do is to fix some more pressure at the valvesprings as I am going to operate the Maxi Micra at a little bit more rpms than Nissans engineers intended it to be run at.
Measuring the OEM spring in this tool here. Measure pressure at set height,
52 kg at set height
Looking in here , parts from a Almera , and I will fin a solution to increase pressure with about 20 % which is my requirement.
It has got this thickness
Just adding a shim underneath the OEM spring.
The Micra and the Almera share the same shims so in it goes like this
Measuring the set up now,,,,and voila 65 kg at set height,,,perfect !
A touch over my wanted 20 % increased pressure.
No more valve float here in the future for the Maxi Micra
Need I say it,,,more to come…
