On my list over DIY modifications i have done, with this level in the Maxi Micra set up, the inlet manifold and high-compression pistons can be checked out.
Inlet manifold =
more capacity
FINISHED DIY
Pistons =
Higher compression / lighter.
FINISHEDDIY
Camshafts = DIY
More lift.
Cylinderhead = DIY
-more capacity
-valvelifte modification , shimless
-valvespring , harder
-valves , bigger
Ex-manifold
-more capacity
So next thing on my list is DIY camshaft modification.
The original camshafts in such a 1,3 engine works great for everyday driving but they are a bit lazy when you want to stretch the legs even further , specially if you want even more punch in the upper range of the rpm aerea like I want to.
Here is a OEM 1,3 camshaft and its profile
This engine is not a low rpm grinder and with its small volume I have to take advantage of more rpms to get things going.
What i want is more lift out to the valves for better breathing in conjunction with a upcoming DIY cylinderhead that the MAxi is going to abuse.
Sacrifize some low end grunt is no problemos for me as long as i get a payback at the top end.
When I started this journey with the Maxi Micra it had its Hp peak at 5400 rpm and its torque peak at 2900 rpm.
Much to wimpy for me !
So i will make this machine reaching its potentional power at the 7000 + rpm aerea for the power and hopefully get away with a 3500-3600 rpm torque peak.
Gear changes at 7700-8200rpm range so I need power all the way up to 7000 rpm+
How will i go about doing this then ?
As everything else in this project , full DIY attack and make them myself (Y)
A camshaft has a given lift and so called duration that defines the wildness of a engine.
The 1,3 cams are not to bad but they need more lift and of course more duration would have been nice to. Maybe also a little alteration of when the cams starts to open in relative to eachother and so on. Well ,not all is possible but I will get more lift that’s for sure.
Here we can se one of the lift-ramps of a OEM 1,3 camshaft.
It gives the engine flexibility to take granny to the shop and commute to work,,nice and well.
The Maxi Micra is going to do all that as well as screaming down the tracks like a wild devil from h….
Buying new cams via ” card-code-enter ” is not a option for me so that leaves me with doing it my way !
Lets have a look at the OEM camshafts lift
Here we can se the 0-lift aerea on the bottom of the cam-lobe where the measuring gauge is zeroed.
Look at the next picture and we now see how much lift it has as we turn the camshafts to it full lift position
Pretty exactly 7,9 mm that leads out to these little fellows
Then , as you can see , there is a large aerea that doesn’t give any lift , called the base-radius ( o lift ) and we have a lift ramp that leads us all the way to max lift , as here 7,9 mm.
The valves are open all around from the base-radius stops , lift ramp begins and back to lift ramp end.
All I want to do first is to get more lift ,at as long as possible at the lift ramp and I have calculated a bit and 1,6 mm more lift will serve me just fine to get some more push in the system.
Ok , lets have a look at how this crazy Micra fan will do that.
First to do is to arrange some simple markings at the cam-lobes
Brush on some machinist-blue stuff and then it is a piece of cake to mark them as needed.
These markings are sat on specific points at the lobes , on the exact same location with a degree wheel so that I will get correct reference points for my future work on the cams.
If you want to find out how this end,,,then pop in a little bit later….
