Edit ; thanks for the "thanks " guys
Here is next step in the Micro Micras adventure :
The throttle body itself is from Nissan a quite clever little thing.
Nissan has integrated several details of engine “ management “ into it and will be able to , in a small modified edition , support quite a raise of power output. _Not htat the totally stock OEM throttle body doesnt support more power , its just that it does so in a even better way with a slight surgical procedure
One little detail I found out when I was working on my flow-bench ( Superflow 130 M )is that I has a restriction inside in form of a way to big throttle blade axelshaft which is , when power starts to increase , a “speedbump “ that is unnecessary.
Testing many Micras on my Dynapack has shown a consistent increase in power with a small and swift surgery of its shaft area. Not so much with the subtle increments that the projects steps are into now but more later on as we go along.
This is how :
When we flip our throttle body and see underneath it you will find this:
After some small calculations and some work on the Flowbench i know there is room for improvement.
Look at the actual dimension of the axle shaft itself , framed in red :
This area is restricting the incoming air more than it has needs to and as being in the way of the incoming air-masses it will play a role of how much air that will pass at any given time.
In my works with the Micras I have found that there is small gains in almost whatever you do in the air-path before the throttle blade , in regards to different types of air-boxes , hoses , ducts etc.
Except from a proper inlet “ air-horn “ fed by cold air as shown earlier in the thread.
On the other hand , all the details you can incorporate that will make the incoming air`s work easier after the intake blade makes a huge difference.
Specially with some of the modifiactions that i will show later in the project.
At least if you compare the money spent versus power gained.
It is not uncommon that you would pay 50-100 pounds for something put on before the throttle-body and not getting anything back..
So what I do is simply to make this restriction a little smaller by machining it flatter with a simple die-grinder and you will end up with something like this :
Takes about 1 hours of work and now you can see the difference in available area for the air to pass through.
This is several CFM ( cubic foot pr minute ) more capacity then STD axle and if you want to push some buttons on the calculator, quite a few more square mm in percent of the original area available and that’s what we are after.
Bear in mind that at this level in the project im am only using the OEM throttle body and NOT a bigger one .
That is because i want to show that the OEM will , with this small modification, support substantional increase in power WITHOUT any negative feedback from the process.
After having done many such modified throttle bodies i know its worthwhile.
This modification in conjunction with this little thingy I am making here will be my next test object in the project :
ANYONE FANCY A GUESS OF WHAT IT IS ?
Will show the " thingy " soon and test results of them together soon
To be continued…
