Now the Maxi Micra has got a integrated rev counter in the instrument cluster and it was easy peasy to do.
Absolutely a bolt on and straight forward thing to do !
First you just remove the cover over the cluster of dials
2 screws is all that i needed to get it off
3 more screws and the cluster itself is loose from the dash
Now all that is neede to do is to unclip the speedo cable and the 3 cable connections
The speedo that Frank got for me is in mph and my old is km/h so i just switch the speedo itself back til km/h into the new housing and that is done by removing these 4 screws
Everything is back on and of course it had to be tested for function
The rev counter and the speedo show quite correct numbers as well being tested with different stuff afterwards.
Again a big THANKS to Frank that got this little avid Micra fan a real threat for Christmas
Jihaaa , now I can watch the needle go past by the scale again , again and again,,,every day.
But now I have to get myself to finish the presentation of the engine stuff as Santa Claus is soon to arrive …
