Judging your braking force by locking up wheels is still daft. That just means you can stop the wheels from rotating, so that's too much force for the unsprung weight (lighter wheels easier lock up). When the aim of the brakes is to bring the entire vehicles weight to a stop... that's why using wheel lock up as a guide is daft.I'm not saying that, I'm saying if you can lock up your brakes your braking force is adaquate already. Larger brakes will brake more efficiently yes but there is a balance between extra rotating mass and braking effort. Rally tyres are also probably a much softer compound, and I bet 185 is a gravel tyre and you'd use much wider tyres on a tarmac stage.
What I'm saying is the size is a compromise and I personally don't believe the extra diameter is worth the reduction in acceleration but thats my opinion. Personally I won't be going bigger than my 247's because I think they're more than enough as is.
@pollyp yeah been reading through, i dont know if you gave up with them. Or if anyone knows if the sunny, pulsar and the 100nx all used the same ones. figured you would be the best person to know this #### lol. I need pads and rotors soon, can you reccomend any?
also did you get any good pads and disks for the rear?
I've been using it ever since fitted back in 2010.
all the required info is indexed through my blog, suppose I have to summerise it for everyone.
Calipers
here I rebuild the calipers
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-3#post-395713
Pedals
it can be used with standard master cylinder but the longer pedal travel will require a slight readjustment of the pedals so the throttle pedal is as low as possible and the brake pedal rests as high as it safely can.
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-3#post-396172
Discs
the GTIR disc hub is 60.5mm while the k11 is 58.8mm
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-3#post-396604
so I layered some ducktap on the hub to take up the slack and keep the disc centered and reduce vibration
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-4#post-396800
currently using the black diamond grooved discs
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-53#post-514095
they require machining down to 253mm to clear the calipers
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-53#post-515275
Pads
I'm using black diamond fast track predator pads. great bite during cold normal driving and when hot on track it really tares ur face.
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-6#post-407583
with standard rear discs I'm using black diamond fast road rear pads
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-7#post-409127
Paul you make me feel guilty everytime I talk to you on another thread.... you love showing off ur build threads.. dont lieI am only giving you a vent for your info
@pollyp. whats your opinion on this all. AND btw i did read through your blog before you commented. I just didnt know if you had changed since, or missed it,
Drilled/grooved discs only have an advantage in rally tbh where they're constantly covered in water/mud/dirt etc and it needs somewhere to escape
Ah yesagree. look good though![]()
The double pumping in my eyes is a safety issue, I don't know why, I just don't feel comfortable pumping for brakesconclude it all works fine for normal street driving.
dunno how much performance advantage grooved discs are on track compared to solid vented discs but they really chew up my pads on track so tbh next time I'd get some normal vented discs for durability.
rear brakes don't do much work so just stock pads will do imo.
would be nice to upgrade the master cyl cos the travel increases with temp on trackdays but I can't be bothered and just settle with double pumping the pedal for more firmness.
in normal driving, the bite point of the cooler brakes is shorter so it works fine.
Drilled is hit and miss. Good drilled discs are fine (they can still crack dont get me wrong). My brother has run black diamond drilled/grooved discs on his rx7 for 3 years now (still only on one set of discs) they have lasted many track days and spirited road driving with no cracks so far.Drilled and grooved to look lovely. Drilled scare me, rust and cracking.
He also doesn't drive it very often? Could that be a factor, possibly less wet weather seen?Drilled is hit and miss. Good drilled discs are fine (they can still crack dont get me wrong). My brother has run black diamond drilled/grooved discs on his rx7 for 3 years now (still only on one set of discs) they have lasted many track days and spirited road driving with no cracks so far.
I will always swear by black diamond.
It was a daily car from 2008ish-2013. He has just got a new daily car so he doesnt have to waste fuel driving an rx7 around.He also doesn't drive it very often? Could that be a factor, possibly less wet weather seen?
Hmm so it has seen daily wear. Must be manufacture then. I just see it as drilling would allow more rust and possibly odd expansion under heat.It was a daily car from 2008ish-2013. He has just got a new daily car so he doesnt have to waste fuel driving an rx7 around.
Suppose. I think with Polly's experiance of brake wear and pads wearing fast I may stick solid. Cause if it wears for him I dread to think what my driving style would do to them lol.Instant cooling is what cracks em but a rarity.
You'll be fine with drilled. If not I'd go dimpled
Thats it mate. Going from a hot braking situation then going through a deep old puddle. Crack. They say that if you get discs that are cast with the holes in that they are alot less likly to crask as discs which are drilled get hair line fractures in the drilling process.Instant cooling is what cracks em but a rarity.
Yeah the going through puddles thing lolInstant cooling is what cracks em but a rarity.
The grooves are there to deglaze padsSuppose. I think with Polly's experiance of brake wear and pads wearing fast I may stick solid. Cause if it wears for him I dread to think what my driving style would do to them lol.
Yes and no. Its not how the holes are made that's the issue. Its the fact the hole is a small stress point on the discThats it mate. Going from a hot braking situation then going through a deep old puddle. Crack. They say that if you get discs that are cast with the holes in that they are alot less likly to crask as discs which are drilled get hair line fractures in the drilling process.
Gotta be a good deep oneYeah the going through puddles thing lol
The double pumping in my eyes is a safety issue, I don't know why, I just don't feel comfortable pumping for brakes![]()
A bigger master cylinder will cure the double pump issue.
Brakesyep but imo cba to spend anymore time n money n work in upgrading minor things and just adapt to it![]()
Standard brakes? :/
Minor... Paul.. That is pure bollocks. You are the king of minor and everything which follows after lolyep but imo cba to spend anymore time n money n work in upgrading minor things and just adapt to it![]()
u bled the brakes and raised the pedal resting point and lowered the throttle resting point?Its doing it now
Bled and fresh. Nah next on listu bled the brakes and raised the pedal resting point and lowered the throttle resting point?
Minor... Paul.. That is pure bollocks. You ate the king of minor and everything which follows after lol
I've got a skyline gtst master cylinder, no double pumping required![]()
Only 2 I'm afraid on the side. You can get 4 port ones but they're more expensiveis it a 4-output ABS version like on mine?
straight fit onto bulkhead & pedals and slight change of plumbing?
one day when I have the engine out and the time n money, I may consider changing the braking system to finally resolve it![]()
Both already designed for bigger piston'd / multi piston'd brakes so they work a treatHmmmm this is something I need in my life. so I here primera and skyline gtst Master Cylinders...
Please xxxxIf you want one Chris I have a spare kicking about somewhere
Almera too iirc![]()
Wouldn't this require a lot of work with perhaps master cylinder etc?I want my brakes to have an instant grab within a cm of pedal pushed.
Yes but we still need to renew the brake fluid on da Vic. That will makes Huge differenceWouldn't this require a lot of work with perhaps master cylinder etc?
I've got vented 283mm discs on the 'Vic and tbh they feel less responsive than my K11!
