PollyMobiles Rebuild
damn the colour coded words didn't come through, meh.
indeed it is scott :) like to be thorough n the colour coded tasks helps me reduce the # of times i move between under the car n over the car
yea took me few days to write this up Ed during time off work and over a holiday :p
but at least i could now follow how to do it all efficiently step by step.
ok i'll check out the status of the engine once i get there to pick it up and re-jig the prep & swapping stages of the project plan
There are specific oils for break-ins, but dont know brands, just know they must be rich in zinc and phosphorus. But its mineral oil, normal mineral oil should do just fine...
aye just looking back at me saved webpages on engine break-in they suggested only light grade good brand petroleum or mineral oil. dunno if the cheapo mineral halvoline down asda or mineral stuff in halfords would do for breaking-in, need to investigate
massive list well done and good luck dude :D
when you say depressureise system u dont just mean pull on fuel pipe and close eyes right?
No, I meant pull out the fuel pump fuse while engines running till it stalls to relieve pressure outa the fuel system
this is for you Zed
i was walkin to town and me naturally having a bad habit of micra spotting, spotted this one and thought ooh tis a nice clean one, looked round the back to see what reg n model it was. it was R-reg and thought of you when all of a sudden THUD! i walked straight into a lamp post soo hard i bruised above my eye and whacked the lamp ON:laugh: first time i ever done that
Pollyp, you eat, sleep, breathe Micra (Y)(Y)(Y)
Where do you find time for the rest :laugh:
Good luck with the plan!!!(Y)
Lol maybe when I'm on a mission and have a plan and a short given schedule, then I'll work on it till the end. But this turbo project has been quite a laid back pace to gather and plan stuff cos I had to wait till me insurance renews to change over. Come April when conversion begins, it'll be full steam ahead again
no persons have been injured during the production of this film??:laugh:
the SR looks very very clean--------sure you didnt spend an hour and half cleaning him to get me well and truly dazzled
mind yer head mate,,,,,was talking to shaun bout heads and lamposts not long ago:grinning:
it was well clean, hence the distracted double look and the inevitable comedy moment :p even the radiator fins were shiny n straight. had super s driving lights.
tis like some car ad, maybe micra? where the guys not distracted by the fine lass in the background but the micra in front :)
just estimated the scheduling for the conversion and according to my calcs if i was working flat out after finishing work at 6pm fri 1st april till midnight i would've taken dash out, wired up the boost & wideband gauge, removed minor bits.
saturday from 9am i would've removed, swapped and fitted the forged engine/lsd gearbox all ready for breakin-in after saturday midnight in country when traffics calm.
sunday 9am would've fitted the turbo, exhaust & rails by bout 4pm
then get exhaust welded on monday and Ed to tune on tues
i didn't think it could be done that fast but yeah seems like just a weekend job if everything goes smoothly, which it prob won't :)
Just to add, I remember hearing somewhere NOT to use fully synthetic oil for the first few thousand miles of a car's life. The oil doesn't allow the rings to bed into the bores properly :).
Paul came down yesterday to get the engine (yes, he drove the 6hours here, and he will be nearly home by now i guess!)
Was a pleasure to meet you mate! Looking forward to seeing that engine kicking out some serious power!!
Collect JE forged piston engine from Noddie
hey just got home with a aching numb bum after driving 6hrs 60mph non-stop to see how much mpg i could eek out of her.
good thing i decided to nap at noddies then drive home in daytime cos i can't imagine i'd endure the long trip back last night.
the results are fantastic. saturday morning filled up at asda and 1 tank just about got me there at 47mpg. filled up at some station in brighton for next day.
This morning i brimmed her up an extra 5L at BP to reset the milage test, station was on an incline so car is tilted right abit which prob allowed more fuel in. driving back home at 60 nonstop with an engine in the boot its done 53mpg! :eek: that's an all time record, must be a good batch.
Ed, lindsay n steward thanks soo much for all ur help n lettin me stay over :) well worth the long trip to have a try at TIG weldin, twas soo much easier n stable than arc or mig weldin. see ya soon
pics of the forged engine
head cover nicely held by some allen bolts
noticed there was alota dirt n grit gathered in the plug holes. don't want that falling into the freshly bored cylinders. so flipped engine upside down to blow it out
still some left round the spark plugs so taped a tube to a vac cleaner to suck it all out whilst engines on its side so no dirt could get in while plugs were taken out
coolent return pipe removed. noddie's takin it out once prob to get the block machined then put back on but o-ring will be replaced cos once they're disturbed they don't seal properly.
waterpumps fine and thermostat needs a flushing and testing
head cover off. ooh err nasty black gunk. gonna use the cleaned cover off the original turbo engine and clean up these bits.
valve train caked in old oil. i think i'll take the timing chain cover off to clean the parts thoroughly...actually thinking further. i could just swap all the parts off the turbo engine onto this forged engine since they're already sparkly cleaned, saves cleaning time.
rusty sump off
crank, rods n block are clean, just the other stuff that are caked
including the oil pump. so i think the general move is to replace all the gunked parts, except for the cams & buckets, with the shiny ones off the turbo engine
peak at the JE pistons
ok i'm a little confused as to what oil to use for breakin-in and for how long cos ppl on this forum say the royal purple break-in oil is only for initial startups till the engine's warmed up then change to non-synth to bed-in for afew hundred miles before goin synthetic?
http://www.d-series.org/forums/engine-building/133504-royal-purple-break-oil.html
my initial plan was to start the new engine & bed it in with royal purple, change to 2nd batch of royal purple oil & filter (get rid of initial debris) and more bedding in before finally changing to me normal castrol gtx 10w40 & filter. but now the above link is confusing me bout the procedures
You don't mess about mate!! I would be in bed sleeping the drive off haha, or down the pub :D
That head ain't that bad, blimey:) It looked in good nick when we checked it over and the tolerances will all be right as they are... personally I don't think you need to clean it, its just a bit of oil staining, but that's just my opinion...
If you are going to change anything over it should be the pneumatic chain tensioner as that was the only bit we put back on that looked a little worn (still fine, but not perfect).
Sorry about the dirt in the plug holes:( did give them a blow out with the air line but obviously not enough...
Hi Pollyp
All the engines i have ever built or seen others build or seen new from the factory got straight forward engine oil then changed at 500miles for whatever oil and filter you prefer.
Malc
I think I figured the 53mpg might be a glitch caused by the way I filled up at the BP station in Brighton.
Now normally the car is brimmed up on a flat level fuel station and I divide the miles covered by how much it took to brim the tank to calc the mpg.
The micro fuel tank I last noticed has an issue with air being trapped in the centre raised part so when filling on a level ground the tank is never 100% full, more like 95%.
When I filled up at BP with the car inclined to the right, the trapped air is allowed to travel across to the breather port which means more fuel than normal can enter before the nozzles overflow cutoff sensor is triggered. When the cars level again the fuel brim height is actually higher than normal.
Therefore when I fill up back at home on a level ground it takes alot less fuel to brim relative to the distance travelled hence appears the mpg has shot up.
At the BP station I filled up by an extra 4.41l after travellin 7miles from noddies house to the station. I know the car normally does 35-37mpg urban so prob just used bout 0.9l in the 7miles which means that the tank was overfilled by 3.5l and could make the mpg result go up from 47 to 53mpg.
Naa not tired after havin me tea and being on a mission to get this engine ready n prepped. I'm sure the tolerances are fine, just personally prefer to fit the cleaned bits off the turbo engine since i spent so long cleaning em and logically I may as well put the best bits on this forged engine.
The dirt in plugs could've came from anywhere during storage. Was just precaution to clean all ports before takin plugs out
Hi Pollyp
Malc
Damn I already just brought 5quarts of the royal purple stuff off ebay. Shall I email em to double check if it's only for startup or for beddin in? Or return the stuff
Will you not have to re shim the cams and whatnot when you swap them? but its up to you mate.
are your cleaned up bits in good condition too then? I would go for condition rather than cleanliness if I were you as they will soon get dirty again eh:)
i'm not swappin the cams n shims so they'll stay in spec, just gonna clean em up.
the turbo engine bits were in good condition, not much worn at 60k. i'll compare the the tensioners n chain n spocket between both engines n pick the healthiest one.
picked up a new coolant return pipe o-ring for £3. nissan guy wondered if i was interested in this door sill protector sticker thats originally for the k12 but may fit mine, tis brushed metal with micra written on it like this one
http://cgi.ebay.co.uk/Nissan-Micra-...312180&cguid=15efca981280a0aad46098b0ff57671d
said he could discount it to bout £30, no thanks don't think my sill are that important and a can of grey paint is only few quid
Those sill protectors are if im remebering correctly about twice the price of the original K11 ones. Chances are the K11 ones would still be available. (includes two doors and boot trim)
As you've said though, depends if you think they are needed...I only know as i ordered some for Whiteknights K11 in Australia.
Looks like you're working hard on the project. Keep at it haha.
taking the turbo & forged engine apart
engine covers & turbo removed
sump, timing cover & valvetrain removed
the cleaned turbo engine valvetrain parts on the left
the mucky forged engine valvetrain parts on the right coated in sludge. some bolts were well sticky to remove
years of missed oil changes
head is sludged but the block n crank are fine
tomorrow will clean up the parts and reassemble the clean turbo bits over to the forged engine block
haha i still have to wait till april to fit and may as well prep it perfectly beforehand with bits i already cleaned. only get one chance with this engine so may as well do it to the best of my ability. nah i luv takin things apart really :p
royal purple oil came tday
back label
bottle is 0.946L each so only have 4.73L. not enough for 2 break-ins. maybe either buy another 1quart bottle so i could do 2 oil changes with the stuff or change my break-in method to just 1 break-in session using royal purple then change filter and oil to normal mineral 10w40 from the remaining 1k miles before eventually moving back to my usual castrol gtx 10w40
hmm just figured that AAS exhaust where i'll get my exhaust welded actually sells royal purple so i could pick up a bottle then i'll be able to run the two break-in sessions.
btw castrol gtx says its part-synth, is that 50/50 mineral/synth or just mineral cos i heard of a legal thing in US bout oil terminology? i can't use this oil till its broken-in right?
na just figured i should actually bond em on with PU sealant cos its tough n strong since the plastic pillar cover bends n flexes during removal
block & head cleaned, everything re-oiled with royal purple (the stuff seems thinner than normal oil, like baby oil), timing chain fitted
cams from forged engine & clean cam bearings from turbo engine fitted
bottom cleaned to fit sump
almost there. just need to wirebrush whole thing, paint n retap all threads
Awesome what's the lph rating Paul? Not long now eh mate :)
Not sure what flow the gts-t pump is, one thread said bout 245?
Aye the days are ticking and I need to get bum into gear sorting all the small bits left, book exhaust weldin and remapping and get this damn gearbox garage to fit new bearings on my LSD which he's having issues waiting for from his supplier.
before i could go wire brushing the forged engine i need to reassemble the turbo engine together otherwise all the bits left out will be coated in grit.
so block cleaned
timing cover on
nissan HG on
head & cams
forged engine left, turbo engine right
ripped the pods off the piller. hot glue stuck tightly onto pods so put em in freezer for couple hrs before smashin the brittle glue off
