Hi, try 5729 or 1729........does anyone know the code for this one: BP3349 4 7300446
Turn the radio on and drive the car around for an hour and the message should change to 'code' or leave the car somewhere 'safe' with the radio turned on and the ignition in the accessory position (radio showing powered up)hi, it’s been saying wait 1 hour for the last 5 hours do you know how to stop this? thanks for the reply
Hi, try 5175 or 1175..........Hey guys, so my car battery went flat in the freezing cold this winter and has reset the radio, can anyone help me with my radio code?
its a BLAUPUNKT-WERKE GMBH
SERIAL = BP3349 4 7299468
i took a pic of the back as well if you need anything else, thanks in advance
car radio back
Hi, 1596 would appear to be the number that you need........Usual story, changed the battery and no code!
Serial = BP334958128912
Would REALLY appreciate your help!
No trouble Jim, the code appears to be 0236......Hi John
I have just found this site - I have a number of niggles I am hoping to address, most of them stem from an electrical issue that means my battery drains while parked up.
I need to disconnect the battery every time I finish using the car!
Please can you find the unlock code for the following radio;
BP 334958147728
Thanks for your help.
Jim
Hi, try 4429 or 0429.......Hello,
The battery recently went flat on my 2003 Nissan Micra. I have removed the radio to get the serial number:
Blaupunkt-Werke-GMBH
BP234732025129
It would be amazing if someone could send me the code for this!
Many thanks
Hi, try 3400 or 1400........Hello
My battery has removed a few days ago and I need too a "little" help to find my radio code.
Can you give me an advice?
Thanks...
BP 234756231209
7642347318
Thanks a lot for your supportHi, try 3400 or 1400........
Hi, try 5297 or 1297......Hi . The cold weather seen the death of many batteries I bet mine included ... any chance of radio code for
BP234631953484
7 642 346 318
You need to take it out, the number required to de-code it will be on the back or side somewhere....Hi
I’m wondering if anyone could help? I have a 2007 Nissan Micra Acenta which had a battery changed today. My radio asked for the code but I’ve never had one. It’s a BP radio and the only model number I can find on the front is CY00E. Thanks in advance
Oh I see. No I have no way of taking it out I’m afraid. Thanks anyway ??You need to take it out, the number required to de-code it will be on the back or side somewhere....
Well the good news is that it is the serial number, but the bad news it's not a BlauPunkt unit but Fujitsu I think and I haven't got software to decode those...Actually, try this
PP3001MB0069319
Hi, only one possible for this one coming up, and nice and easy to remember, try 1701Can you please help our daughter she is stuck
Bp334936397384
Thank you in advance
Hi, not enough numbers above . The 'BP' serial number has to have 12 numbers (or numbers and sometimes a letter in the middle), after'BP' for me to decode it........Hi guys,
Can you help me please with this one: BP7647383318
I've searched on internet to no avail, how do you usually find them?
Thank you
Petru
That looks to be the right information, 1140 appears to be the unlock code that you need..............Sorry about that,
Don't know a lot about these things. I've found this one:
BP 738398782959
Hi, as it is a BlauPunkt manufactured unit as explained, about a dozen post earlier and numerous other times as wellHello
Would you be able to help me too please?
My serial number is: BP536556020696
Many thanks.
Hi try 2994 or 0994.....Could anyone help with the code for my daughters car?
BP334936348536
7643349318
Thank you.
The CD changer/radio in my K12 only had the BP number actually engraved on the side/back of the unit, not on any stickers or labels on it, have another look..........Hi,
We had the battery changed and now can't find the code for the stereo. I removed the unit to find the serial number but I didn't find any number starting with BP. The only one I got is a bar code from the front of the cd player which is 55610168357. I'd appreciate any help! Thanks!
Thanks! I'll have another look then.The CD changer/radio in my K12 only had the BP number actually engraved on the side/back of the unit, not on any stickers or labels on it, have another look..........
Hi John.Hi, as it is a BlauPunkt manufactured unit as explained, about a dozen post earlier and numerous other times as well, no problems at all, try 4573 or 0573
Hi, try 4442 or 0442....hi guys, i was hoping somebody can help me. i recently bought a micra 05 reg, however after a flat battery the radio is asking for a code. unfortunately i don’t have this nor the manual. i was wondering if somebody could help me with this please. ref is BP334958143536 thanks
1165 seems to be the only option for you.....Hi,
Finally found the number...it is BP334947335486
Thanks for the help!
