Try 5202 or 1202.....Hello,
The battery recently went flat on my 2006 Nissan Micra. I have removed the radio to get the serial number:
Blaupunkt-Werke-GMBH
BP5387 6 9679245
It would be amazing if someone could send me the code for this!
Many thanks
G
Thanks! 5202 worked!Try 5202 or 1202.....
Hi, try 5904 or 1904...Would you be able to help me too please? My serial number is: BP3349 3 6378088
Too many number, should only be 12 after the 'BP'. If the '2005' has crept into the middle by accident, then the code associated with what's left (BP 234639598643) is 9946 or 1946. Repost the code if this is not the case.....Hi
Can someone help me need a radio code for the following serial number for my Nissan Micra
Bp2346320059598643
Hi, try 8643 or 0643 then.. Just realised that the four extra digits are the correct codeThanks the 8643 need to be removed from the end then as the 12 numbers after the bp include the 2005
Hi, try 8643 or 0643 then.. Just realised that the four extra digits are the correct code![]()
Hi, try 8658, or if that doesn't work, 0658....Love my Micra! However I have had to buy a replacement radio as mine stopped working, there was no code supplied though. Any help is greatly appreciated.
BP334936384350
7643349318
Hi, try 9628 or 1628Hi guys
Can I ask if anyone could please give me a code?
BP234631961468
7642346318
Thanks!
Hi, try 2182 or 0182Hello
My serial number is: BP334947330911
Try 3193 or if that fails 1193Previous was 2 lady owners and volumes of paperwork - just no Radiopass
BP 5385 65045247
TYVMIA
Hi try 7655 or if that doesn't work 1655Just purchased my Micra... like many others no radio code. Could someone help?
BP 53655 6440962
Many thanks!
No problems, try 6558, or in the unlikely event of that not working, 0558....Hi guys,
We’ve recently had a new battery and the dealership never wrote the code in the service manual. Could you please help?
Blaupunkt
BP538962402863
Nissan MMR CD-G
7645389318
Tom
You have already got the unlock code, confirm that it is 3110...Would you help me to unlock my radio?
BP3349 - typ/model
47310518 - serial №
3110 - safety №
28185AX613
Thank you!
Hi, the code is 6423 or 0423Had a flat battery and need to reset my radio. Can anyone help please?
Blaupunkt
BP5384 6 9509529
Nissan MMR CD-G
7 645 384 318
Thank you!!
Hi, try 5375 or failing that, 1375Hello! I’ve recently had a new battery fitted and need the code for my Micra. If anyon can help??
BP538469483882
Blaupunkt 7645384318
TIA x
Just checked and from the numbers you have sent I get the same codes. check that you haven't transposed a number when you wrote the BP number down, never had a failure yet, so suspect that you have a number wrong oryou aren't inputting the code correctly.... Does this help?Hi!
They didn’t work![]()
Still comes up with the same codes. When you press the 'up' button to accept the code that you have put in the radio what happens?Hi,![]()
I’ve tried both using the method but not workingI took a picture incase I’ve transcribed the numbers wrong. See attached
Can you post a picture of the front of the radio if it looks different to the one in the video as some radios use a different button to accept the code.
I'm thinking that the button isn't working/sticky. I'd try inputting the first code and then try really pressing the button hard several times to see if a momentary contact would accept the code...It’s the same radio but I will post. Nothing happens when I press up it just stays on. Tried pressing others too :/![]()
And today's super quick response is .....4374hi unfortunately i lost my 2005 micra 1.2 visia s radiopass coz of batery changemy serial number is BP234746090134...anyone to help me???
Hi Keith, try 8932 or if that fails 0932Hi John
Same for me! wait 1 hour always and no code. Battery died so did the radio!!
I have the code on my Micra but its a no go!! Tried it twice!
The serial number I have is: BP3349 47266544
Keith
Hi Jason, only one possible code for your radio 0303Hi All can you please help me with the code for my micra the radio serial number is BP536556442477
Thank you in advance
Jason
