Hi could you please help with a radio code for my 2009 Nissan micra?Hi, try 7358 or 1358......
my radio serial number is PP3001MB0071334
I have this exact same problem - sticker looks like it's fallen off! grrrrI have looked but the only has the part number engraved, there is an outline where a sticker was but that has gone. ?
BP538471207329 = 1421Hi
Could someone help me with the radio code please for my Nissan Micra 2007 ?
BP5384 7 1207329
Thank you
Or just get it here free...... 1421 is what you need.... :0)Hi
BP5384 7 1207329
Thank you
Yeah, I also gave him free above the link.Or just get it here free...... 1421 is what you need.... :0)
Hi
BP5384 7 1207329
Thank you
NISSAN RADIO CODE 🔓
Get the 4-digit code used to activate a Nissan radio online and in minutes. All you need is the radio info displayed on screen. Read more.radiocodefinder.com
ATTENTION.!Yeah, I also gave him free above the link.
For what reason I'm dishonest? For giving the codes to the people?ATTENTION.!
This guy "zarzol" is a dishonest guy and with his link even MORE
ATTENTION.!
NISSAN RADIO CODE 🔓
The guys of your class are to be thrown from this forumFor what reason I'm dishonest? For giving the codes to the people?
If I left the link for these which can be interested I'm not worst than you which asking money in private.
Take it easy. That is going to be decided by the corresponding stuff, not you.The guys of your class are to be thrown from this forum
Your name is Nissanradiocode1 +90xxxxxxxxx SERVICE 7/24Take it easy. That is going to be decided by the corresponding stuff, not you.
Hello there, the code for BP234756225410 is 0486Hi guys,
I need help with my Micra 2005 radio code please.
BP234756225410
Would you kindly help me out please?
Many thanks guys
To obtain the particulars of your Nissan Touch Connect radio, such as the Serial number, Device number, and Date, follow the steps below:Hi guys, any ideas for the code for this radio?View attachment 87119
Serial number is: 7479957To obtain the particulars of your Nissan Touch Connect radio, such as the Serial number, Device number, and Date, follow the steps below:
Once you have the right info you can get the code online: https://radiocodeford.com/nissan-radio-code
- Begin by inputting the code "0000" into your device, doing so three times even though it's incorrect.
- After the third incorrect attempt, the radio will lock itself for an hour.
- Throughout this 60-minute locked phase, the necessary details will be shown on the screen, enabling you to note down the unlock info from your Nissan Touch Connect radio.
These are correct. You can use the service at the link I provided. Unfortunately these can't be retrieved as easy as the Blaupunkt units.Serial number is: 7479957
Model : 7612830091
Date: 11.10.11
Sat Nav
Thanks for your help, I’ll try thatThese are correct. You can use the service at the link I provided. Unfortunately these can't be retrieved as easy as the Blaupunkt units.
Hello,Hi I have a micra which has the following radio: serial # BP7383A9259254 part # 7647383318 can you please help with the code?
Thanks a lot. That worked wellHello,
Code is . . 1916
Hello,hi can you help me with my radio code please
serial number- BP538761146378
Part -7645387318
Hello,Hallo guys,
Can someone help me with radio code? Disconnected battery now I need code.
SN : BP234631997506
PN: 7642346318.
Thanks in advance.
HiHi John I’ve just pulled the radio from my GF 2004 micra and the code is BP334947316931
