Hi please can someone help. My serial number is DW3BN13767, the battery went flat and I’ve lost the radio! Thanks
Hi try 9631 or 1631.....Hello! Same story, radio locked after I disconnected it to connect up a grombt3.
Numbers are
BP538761147652
7645387318
Can you help?
Hi guys, new to the forum, came accross it is after fitting new battery my radio is asking for the code, can anyone help please?
BP234631978411
7 642 346 318
Well there has to be 12 numbers after 'BP' for me to decode it.Hi guys, new to the forum, came accross it is after fitting new battery my radio is asking for the code, can anyone help please?
BP23463197841
7 642 346 318
OK just seen this, ignore my initial reply, code should be 1023, no other alternative given.......Sorry missed a 1 off original post
Thanks for the reply, I had missed a 1 off the end, I have edited it now thanksWell there has to be 12 numbers after 'BP' for me to decode it.
IF the '7' at the start of the second line is the 12th number then the code is either 8179 or 0179, otherwise go back and check that you haven't left a number out..........
Worked straight away, thankyou very muchOK just seen this, ignore my initial reply, code should be 1023, no other alternative given.......
Thank you so much! Worked perfectly, so relieved not to be driving in silence anymore ?Hi, try 5869 or 1869......
Hi, try 3583 or 1583.........Hey guys, just bought a used Nissan Micra 2005, but the Radio is locked and needs a 4 digit passcode.
BLAUPUNKT-WERKE GMBH
BP3349 4 73291 48
Any help would be greatly appreciated![]()
You're amazing dude .... thanks a lotHi, try 3583 or 1583.........
Excellent! Thanks so much!Hi try 9631 or 1631.....
Hi, try 9337 or 1337........Hi. I need help.
Can anyone get the code for
BP536258422586
Hi, try 9194 or 1194.....Hi! I found only this number on my radio BP334958143191. On some sites they need also serial number but I couldnt find. Can anyone help me ?
Hi, try 7722 or 1722......Hi can anyone please help me with the code for my radio the sn is BP334947346883
Thank you in advance
Jason
Not sure if this one will work as the BP number starts with zero...however try 3097 or 1097.....Been locked out of my radio for half a year now, only just managed to get into it and find a serial number....
My serial number is bp086083326140. Any help with unlocking my radio would be greatly appreciated! Thanks!
Hi, try 6008 or 0008........Battery replacement on a second-hand Micra. No manual with the car.
I would surely appreciate some help with this! Thanks.
BP5384 6 1724902
7 645 384 318
Hi, try 3875 or 1875......Hello, After some work at the garage, i've got the same.
BP536556020515
Would be truly grateful for a code!
Thanks in advance![]()
Hi, try 2963 or 0963........Hi, I bought a Micra but the seller didn't have the radio code any more. Can you please tell me what the code would be for:
BP5387 7 1234993
7645 387 318
Thank you!
Hi, the number that you need appears to be 0210.........hi can i have a code for my nissan micra k12 2007?
BP538471220111
7 645384318
THANK YOU VERY MUCH
it worked. thank you very much!!!!!Hi, the number that you need appears to be 0210.........
Please read earlier posts in this thread to see what information is needed to be supplied to get an unlock code. As has been stated several times already only a Nissan Main Dealer can supply a code from the VIN number (at a significant cost!). When you have found the necessary information post it back on here and, if I can, I will get the code for you...Hiya,
Can anyone help with getting the radio code for my Nissan Micra please!
SJNFBAK12U3081920
545347
Thank you!!
I can't see the picture that you posted, apparently I don't have permission....Hi
View media item 1115
I try 6616 , but is didn’t work , can you help me, and I try to find the serial code, but I couldn’t found it.
Grace
Hi, no problem at all, try 5191 or 1191...........Hi all, new to this forum but on others, I was wondering if it would be possible to try and get a code for my daughters car I've just bought, using buttons 1 and 4 combo to make it work apparently is a pain.. Nissan aren't exactly forthcoming either.. Yor help much appreciated... Finally got stereo out as well... Serial No BP538469485090 7645384318.
TY.
Many thanks I'll give it a go shortly, much appreciated ???Hi, no problem at all, try 5191 or 1191...........
looks to be correct. Are you pressing the correct button, after entering the code, to accept it?Hi
Sorry about that , can you see that one?
https://drive.google.com/file/d/13BLIllbauuU4csomYim3dQVJqmopz8AD/view?usp=drivesdk
Thanks very much John, first one was correct... Now a very happy daughter... And dad... Lol, ???Hi, no problem at all, try 5191 or 1191...........
