Hi, try 5943 or 1943.......Hi, does anyone here can help me to find code for this one: BP3349 3 6351518.
Thank you so much, first code working.Hi, try 5943 or 1943.......
that you very much for this i will try and let you know how i got on.Hi, try 4442 or 0442....
Hi, try 6780 or 0780.......Hi all need radio code for BP536258441241 please . Your help is very much appreciated. ☺
Hi, try either 2960 or 0960..........Hi there! Please, can you give me the radio code for BP3349 3 6363840? The other number is 7 643 349 318. The battery died after a couple of months nobody used the car, and the first owner never wrote the code down in the manual/service book
Thank you I will try and I'll let you know .Hi, try 6780 or 0780.......
It worked! Thanks a lot!1165 seems to be the only option for you.....
Ps. Sorry I think I posted to wrong thread or something (I'm new to forums)
Hi John, worked a treat, many thanks.Hi, as it is a BlauPunkt manufactured unit as explained, about a dozen post earlier and numerous other times as well , no problems at all, try 4573 or 0573
Try reading back through this thread and the other radio codes threads, it's been explained numerous times....Where do I find the number for the radio please
Hi, try 2865 or 0865......Hi guys I need a bit of help with a radio code if possible. The number on the radio is
BP234631951637. Thanks in advance.
Thank you very much, you're a lifesaver!Hi, try either 2960 or 0960..........
Hi, try 5485 or 1485.......Hi my serial code is BP234632013926; please help me!!
Hiya could you help me with my code pls ? 2014 micra serial DW3CN16189 part: 281853HN4BTry 5202 or 1202.....
The codes are specific for that radio serial number NOT for year of manufacture....Hi
I can't get my Nissan Micra radio serial no - without removing radio. I saw elsewhere s.o. give radio codes for 2008 model (wh. I *think* I am) as 2549 or 0549 in reply to a particular BP serial no.
My main question is: are there are only 2 codes for a given year, as above? or are there loads of codes, depending on the BP radios? (If only 2, I could try entering them).
2nd question - are above - 2549 - and -0549 - right?
Many thx for any help
Thx for replyThe codes are specific for that radio serial number NOT for year of manufacture....
Sorry can only decode BlauPunkt units, think 'PP' prefix means that it was made by Fujitsu an 'DW' means it was made by Daewoo.....Found my details - can you help with code?
Details from radio case of my Nissan Micra:
S/N: PP3001MB0042854
PART NO; 28185 BG10A
MODEL NO: PP-3001M
(s/n def "PP" not "BP")
Many thx
And to add to my post immediately above, a serial number beginning with 'CL' means it was made by 'Clarion' so again, as it is NOT a Blaupunkt unit, I can not supply an unlock code for it..............Nissan micra model- PP 3001M-B. Nissan part no 28185 BG10A. Serial no CL081690086649 code please
Hi, try 3975 or 1975.........Hi, can anyone help me get my radio code please?
BP536258425809
Many thanks
Great, IT works. Very much appreciated!Hi, try 3975 or 1975.........
Hi, 1781 would appear to be the answer to your prayersHi there,
Can you please let me know the code for BP 334936368019?
Thanks,
Can somwbody help me for radio codeTry 5202 or 1202.....
H, try 2412 or 0412........Can somwbody help me for radio code
BP 536258038551
Hi, try 8621 or 9621.........Can someone please help me with this code bp538761141217
Hi, only one possible for this, 1405........Help needed on my 2006 Nissan Micra. serial number:
Blaupunkt-Werke-GMBH
BP5384 6 1726858
Legend !Hi, only one possible for this, 1405........
Hi, try 9267 or 1267......Hello,
Can someone help me, need a radio code for the following serial number for my Nissan Micra
BP738387814646
Its also constantly says wait 1hour ((Hiya,
Where do i find the radio serial number please??
Read through some of the code request threads already posted on here, both of your questions have been answered many times. When you have done this come back here and post the radio serial number that you have found and as long as it starts with 'BP' I'll give you the unlock code. ...............Its also constantly says wait 1hour ((
Hi, try 5869 or 1869......Hi there, was hoping somebody might be able to help! I changed my battery and the radio is now locked out. The serial number is BP334947234752, any help would be greatly appreciated.
Thanks in advance ?
Thanks JohnHi, try 9267 or 1267......
