Hi,Hi John I’ve just pulled the radio from my GF 2004 micra and the code is BP334947316931
Try code . . 7976
Hi, try 7976 or 1976....., Oops beaten to it...Hi John I’ve just pulled the radio from my GF 2004 micra and the code is BP334947316931
Hi,Hi,
Please may you help with radio code
BP 3349 3635 9976
Part number
7643 3493 18
Thanks in advance,
G
Hey,Hey guys I new in this forum but if anyone can help then that would be really good for me.
My serial no- BP538753301985
Thank you very much
Hello,Hello,
My S/N is BP234732031985
Can you please check pin for my radio?
Thanks very much in advance!
Cheers,
Raf
Hi John, could you help with mine too please? The serial number is BP538471191528.Hi, try 7358 or 1358......
Hello,Hi John, could you help with mine too please? The serial number is BP538471191528.
Thanks!
Hi,Hi all
Recently got a Nissan Micra have issue with radio showing wait 1 hour, have read posts on here But now require radio code if anyone could help please.
BP536556438665
Thanks in advance.
Many Thanks just input and works you're a Star.Hi,
Code is . . 0467 ==> Click here Thanks
De code die je nodig hebt is 2372 of 0372....Wie kan mij helpen, radio nissan micra uit 2006 vraagt om code.
BP5384 6 9492449.
avast bedankt
Dankjewel! Hij doet het weer ?De code die je nodig hebt is 2372 of 0372....
Hi, your code is 7743Hi.. looking for radio code for 2006 K12 micra, same story took out battery and it requires code..
S/N: BP536258436443
Thanks in advance!
Brilliant thanks ?? That workedHi, your code is 7743
Hi, 6847 or 0847 should solve your problem...Hi folks just bought a k12 that was destined for the scrappy so picked it up for a steal numerous things wrong all sorted mot’d now except the radio is screaming for a 4digit code it’s BP3349 3 6371485 it’s a Blaupunkt unit 7 643 349 318 would be much appreciated if anyone can assist cheers
Cheers John much appreciated first number sorted the problem mate thank you very much??Hi, 6847 or 0847 should solve your problem...![]()
Any help with Nissan micra radio code? Serial no is BP334947254435Hi, your code is 4308
Hi, your code is 7976Hi John I’ve just pulled the radio from my GF 2004 micra and the code is BP334947316931
Hi zarzol!Hi, your code is
8946
No problems, 0411 should do the trick.......Hi there,
Any chance someone could help with sourcing my code?
BP 5384 7 1220053
Many thanks
Hi, it is not possible to obtain this code for free, however you can get it at this site: https://radiocodeford.com/nissan-radio-codeCan you help with a code for the following please?
Serial DW5BN01421
Devise 28185 3HN4C
Date 15.11.11
Any help much appreciated ?
The battery recently went flat on my 2007 Nissan Micra. I have removed the radio to get the serial number:
Blaupunkt-Werke-GMBH
BP5384 7 1220171
And nissan MMR CD-C
7645384318
It would be amazing if someone could send me the code for this!
Many thanks
Siamak
Hi could I get the radio code for this vin number please SINEBAK1202198286 Nissan micra 07 plateHi John I’ve just pulled the radio from my GF 2004 micra and the code is BP334947316931
Hi, this one can't be retrieved for free. You can try https://radiocodeford.com/nissan-radio-code (it's around 14 eur)Hi,
Could someone please help with the radio code for a Micra 2010
Serial number: 3138119
Device number: 7612830023
date: 10.04.29
Felix
Try 7976. If not working, check the serial twice and generate yourself at https://fordradiocodes.net/ (it says it's for Ford but actually working with all Blaupunkt units)Hi John I’ve just pulled the radio from my GF 2004 micra and the code is BP334947316931
Hi, your code is 0305Hi is it possible to provide the radio unlock code for BP234732046046 please
Hi, for this kind of code there are only paid solutions. You can try https://radiocodeford.com/nissan-radio-codeHi Experts, daughters 61 Micra requires a radio code following a flat battery.
SN: 9590459
Date: 10.09.10
Any help would make her day, thanks you.
"This is the official thread for K12 radio codes.Hi Experts, daughters 61 Micra requires a radio code following a flat battery.
SN: 9590459
Date: 10.09.10
