Tnx bro <3Hi, try 8986 or 0986
Hi try 2662 or 0662.........Can someone help me with a radio code for my new car as it didn’t come with oneBP3349 4 7250641
Nissan MM CDK
7 643 349 318
BLAUPUNKT-WERKE GMBH
Hi try 3046 or 1046............Hi, could someone help me with my radio code:
BP538461726761
7645384318
Nissan MMR CD-G
Yipeeeeee! Thanks a million! Your a life saver!!!Hi try 2662 or 0662.........
Hi John, Happy new year to youHi, try 4139 or 0139.............
See my previous answer above....
I've managed to get my serial number now but my 53plate radio now says "wait 1hr" and many an hour has passed...lol
Anyway, I think I can figure that bit out eventually, just thought I'd ask...
So, here it is :
BP234631977546
(fingers crossed and breath held)
Thanks so much in advance!
Ps. Sorry I think I posted to wrong thread or something (I'm new to forums)
Hi, try 7238 or 1238 ..............As for the wait one hour, you have to have the radio turned on and the ignition turned on.......Hi John, Happy new year to you
So, here it is :
BP234631977546
THANK YOU SO MUCH FOR YOUR HELP.Hi, try 7238 or 1238 ..............As for the wait one hour, you have to have the radio turned on and the ignition turned on.......
Hi, no problems, 1696 should solve your questHi All, I'm looking for a code for a radio in a Nissan Micra, serial number BP538471201977. Cold weather finally killed the battery. Thanks in advance and Happy New year!
Perfect, worked OK thank you!Hi, no problems, 1696 should solve your quest![]()
Hi, try 4185 or 0185......Hi need a code if any one can help!! Just bought the car and the stereo was on a side. I installed it and now it's asking for a code.
BP234756422513
Sorry not enough information....Hi john_D..
can you help me?
55610036754
Well the 'BP' serial number should have 12 numbers after it not 11, please post the correct number for an unlock code.....Can anyone help me i need a radio code for my Nissan
BP73838781340
7 647 383 318
Thanx
BP738387813440Well the 'BP' serial number should have 12 numbers after it not 11, please post the correct number for an unlock code.....
That's betterBP738387813440
Part Number: 7 647 383 318
No problems, try 9753 or 1753........Hi.... hope you can help.... had clutch replaced on my micra S. lost my radio code ..... BP538771225442 part no 7645387318.... Hope you can help ....thanks
Yes ..... great first code worked... Thank you so much .... mrs will be happy now , Thanks again your a top man ....No problems, try 9753 or 1753........
I need a part number, starting with 'BP' followed by 12 numbers (or numbers/letters) to decode the radio.....Hi, i have Nissan Micra Accenta 2010, radio Bosch (part number 7612830021) Nissan Part Number 75915BH10A
Could someone kindly provide the radio code, new battery fitted last week![]()
Hi, try 7199 or 1199.......HI , would be so kind to help me with a radio code
BP538469511492
Thanx John_D it works....???That's betterTry 8935 or 0935....
Top job work greatHi, try 7199 or 1199.......
This should really earn you some 'brownie points' the code that you need to restore your mum's sounds is 1311.....Hi, can anyone help me with a radio code for my Mam’s 55 plate micra - BP536556439308 - she’s been driving around without a radio for over a year and I didn’t know ?
Thanks! 5202 worked!
Hi, try 9941 or 1941...........Hi John D.
Is there any chance you could provide a code for BP5384 5 8815405?
Hi, try 8061 or 0061......Hi there John D.
Thanks to a dead battery, I need the radiocode for my Micra. I would appreciate it if you could help me on this one.
BP5384 6 1727480
Thanks in advance.
Hi, try 4948 or 0948.............Hi! Can you help me? My battery is changed.
BP538469510463
7645384318
Than you buddy! It’s work!Hi, try 4948 or 0948.............
Hi, try 6828 or 0828.......Heya could use your help.
My serial number is BP3349 3 6345960
Many thanks
John you are amazing. The first number worked. Thank you so so muchHi, try 6828 or 0828.......
Will let you know how I get on![]()
