Hi, try 4139 or 0139.............Hi all I also need a code for my Micra serial number is BP538761129280
many thanks
many thanks
It's the right code(s), for the serial number that you gave me (just re-checked it), either there is a typo in the number, or more likely you are not pushing the correct button to confirm the code after entering it......Hi John,
Do you maybe have another code?
The code you gave me doesn't work.
Serial number: BP 5384 6 4184629
7 645 384 318
Sorry, while the Nissan main dealer can probably retrieve the code from the VIN I need the BP serial number from the back and/or side of the radio. You need to extract the radio from the dash to get it. Google 'Removing Micra radio' to find a selection of you tube videos that will show you how to remove your particular unit....Hi john, i live in sweden and i have a nissan micra 2003 but it says model year 2004, i dont know what the BP number are but i can my identification/VIN nr is : SJNFCAK12U1120158. Can you try to help me with this please, best regards from sweden
See my previous answer above....Hi there!
I had the same issue - battery died, need to get radio code for my Micra 2003 - would really appreciate it if anyone could help (even though he's an ol' timer! Lol)
VIN is SJNEBAKIZU1058349 (do I need reg? YN53 NJE just in case).
THANKS VERY MUCH & HAPPY HOLIDAYS ALL![]()
Hi, try 4035 or 0035.......Hello John_D,
I have similar issue with Nissan Micra K12 radio code like others. I'm at least third owner of my car, so pin code is lost somewhere in the past.
BLAUPUNKT-WERKE GMBH
Made in Portugal
BP234746067340
Nissan MM CD-J
7 642 347 318
E1 022458
Thank you in advance!
Hi, try 9850 or 1850.........Hey could anyone help me out with the radio code for my stereo please,
The details are
BP338947299468
Thank you! You are #1!Hi, try 4035 or 0035.......
Hi, try 9298 or 1298............Hi there,
My car battery died today and has been replaced. My radio needs a code and I cannot find it anywhere in the manual.
Can anyone help me find the code I need?
BP538971335156
7645389318
Thanks in advance!
Hi, try 7391 or 1391.........Hi
Can you help me with a long missing code for my radio?
BP538464180657
7645384318
024173
Hi can someone help, my serial code is DW47N0181007 3HN4B
Sadly, eitherway I can't help as the radio was made by Daewoo and not BlauPunkt....Actually it’s not it’s DW46N13179 !!!
Hi, try 7721 or 1721.........Hello!
Can you help me with my radio code?
BP 5387 6 1125145
7645387318
Thanks a bunch!!
Hi,your code would appear to be 1265..........Any chance you can help me get my code too?
BP3349 58115351
Thank you!!
Sorry can only supply codes for BlauPunkt units......Hi john,
Please can you help had to change battery now radio asking for code.
Serial, DDB0600412
Nissan number, 28188AX000AU
Fujitsu ten, 123001-1040A151
You've been sold a pup, correct code is either 8984 or 0984.........Hi I bought a code online for my stereo. Tried to input and pressed the up station to accept and now says Wait 1H again. Can someone save my sanity and confirm if my code is right. My radio serial number is BP234732018443 and the code bought is 5658. Is this right? on the radio which is the accept code button? top left is AF is it the TA/PTY button at the bottom. Bought the car second hand with no books. Can super John help me pleeease? I've been waiting weeks seeing Wait 1H. Bought a code, input it and as soon as i pressed up arrow WAIT 1H appeared again. ARGH!
Thank you for the quick reply John. You're a star. Is the TA/PTY button to accept code or should up station work? I'd be gutted to Wait 1H again. ThanksYou've been sold a pup, correct code is either 8984 or 0984.........
Which ever one got you to the 'Wait One Hour' message before. The wrong 'accept code' button won't trigger the 'Wait One Hour' again, it just won't do anything till the correct button is pushed.....Thank you for the quick reply John. You're a star. Is the TA/PTY button to accept code or should up station work? I'd be gutted to Wait 1H again. Thanks![]()
Thanks for the info John. Very much appreciated. Will try to camp out for an hour in the car again to hope it works this time. Have a good ChristmasWhich ever one got you to the 'Wait One Hour' message before. The wrong 'accept code' button won't trigger the 'Wait One Hour' again, it just won't do anything till the correct button is pushed.....
wahoo! code worked. John you lifesaver ?Thanks for the info John. Very much appreciated. Will try to camp out for an hour in the car again to hope it works this time. Have a good Christmas![]()
Hi Fleur, try 8779 or 0779.......Hi John,
I’m having the same trouble, had a new battery and now I’m locked out!
Micra spirita 07’ BP538461726725
Please help ??
Fleur
Hi, the code that you need would appear to be 0775......Hi , can anyone help me with my micra radio code.
BP334947228097
Sorry can only supply codes for BlauPunkt manufactured units, where the serial number starts with 'BP'Hi Jon, any chance you could help with PP3001MB0043542 please?
Sorry can only supply codes for BlauPunkt manufactured units, where the serial number starts with 'BP'![]()
Hi, try 4762 or 0762.......hi
need radio code for blaupunkt with
serial BP 5383 6 9341518
PART NO 7 645 383 318
any chance to find it?
Thanks alotHi, try 4762 or 0762.......
Hi, try 8986 or 0986Hello guys .. I have a problem with radio code for Nissan Micra 2003.
help someone?
BP234732032109
nissan mm cd-j 7 642 347 318
Tnx![]()
Just realised that I missed this one...... try 7342 or 1342.....Hi there!
I had the issue. Battery died, need to get radio code for my Micra 2004
Bp234746056629
8 635 123 392.0
