@alexzaki
There will be magic moments in any engine regarding AFR.
some engine react different then others of where the best afr throughout the entire rpm range is to be found.
Micras will perform all day long in the 15:1 range in everyday driving and on power demand situations.
They will not produce peak power at this range , rather at 12,4-12,8 :1 , as a normally aspirated angine , depending on where you are about in choice of ignition profile , camshaft set up , compression ratio etc.
When you fiddle around with camshaft timing and ignition timing you will discover many different combinations of them and afr used giving multiple differences in power curves.
That is why i use the DYNAPACK as this gives me incredible repetabillity and accuracy in minute details to sort all these changes out in best possible and compromiseable way.
You could basically say that for economy go higher number and for power slightly lower.
14,7 :1 is only a teoretical number , not a untouchable bastion in realtime.
