Hi, try 7873 or 1873....Hey there! By battery died and I cannot retrieve the code for the radio.
The serial number is BP23475642 35 54. 7642347318
Thanks in advance![]()
No problems, try 9943 or 1943.........Hey,
could somebody help me please.
I cannot retrieve my radio code after my battery change.
The radio code is BP 234621251030
Thanks in advance ?
Hi, try 4244 or 0244.........Hi! Very much in love with my first careven if she is a little old. But very boring driving without the radio. I finally found somebody to remove the radio. Now step 2: can I get a code?
BP334947232457
Thanks in advance! ❤
Thank you so much, this really made my day! I'll be driving home for Christmas next week with some good tunesHi, try 4244 or 0244.........
Hi, try 5982 or 1982..........Hello! I'm writing from Hungary. I'd like a nissan micra code. Battery was replaced but the code was lost. Thanks
BP334936385794
7643349318
? 7640349318
Hi try 7805 or 1805.......Hello hello everyone!
Could you help out getting a code for my Micra? Changing a battery after many days in lockdown found me with no radio
BP334936354584
CD-K 7643349318
Thank you so so much in advance!
The serial number will be engraved/stamped on the side and or back of the radio, starting with 'BP' followed by 12 numbers..... (that is assuming it is a BlauPunkt manufactured unit....)Hey John. Ive just got a 2008 micra SR. Cant see the serial number for the stereo. All I know is its the Bluetooth double din one? Any ideas on a code pls?
Hy John!
Please help.
BP334947269711
7643349318
Thanks in very advance!
Hi, 0457 appears to be your unlock code......Hy John!
Please help.
BP334947269711
7643349318
Hi, you can give the kennel back to the dog, either 9246 or 1246 should ensure that normal services are resumed........Hi guys,
Can someone help me, as like most I replaced the battery in the car and I don't know what the radio code is.
Currently in the dog house!
Bp7383A9257564
7647383318
Thanks worked a dream!Hi, you can give the kennel back to the dog, either 9246 or 1246 should ensure that normal services are resumed........
Hi Keith, try 8932 or if that fails 0932
Hi, try 7952 or 1952........Please may i get a code for the following:
BP5384 6 9472280
Many thanks
Hi, try 3253 or 1253.........Hi can I get a code please my serial number is bp738398784651
It's all been explained many times on here before ..........use the 'search' facility..... THIS is a starting point....how i get the radio code ?
the serial number top of my radio is : DW62N11602043HN4C , can u help ?It's all been explained many times on here before ..........use the 'search' facility..... THIS is a starting point....
Sadly no, I can only decode Blau Punkt manufactured radios, yours was made by Daiwoothe serial number top of my radio is : DW62N11602043HN4C , can u help ?
thanks for your replay ♥Sadly no, I can only decode Blau Punkt manufactured radios, yours was made by Daiwoo![]()
Hi John had already tried a few times before asking for help and the radio now says wait one hour I have disconnected the battery and even tried running the car for an hour but nothing seems to be working any ideas pleaseHi, try 3253 or 1253.........
Well I've double checked and 3253 or 1253 are the only possible codes for the radio with the serial number that you posted. I suggests that you have either made a typo in the serial number or you are putting in the code supplied wrongly. As far as getting rid of the 'wait for 1hour' message, the radio has to be turned on for the 1 hour period with the engine either running or the ignition left on. Best idea is to just drive, with the radio 'on', till the message changes to 'CODE'Hi John had already tried a few times before asking for help and the radio now says wait one hour I have disconnected the battery and even tried running the car for an hour but nothing seems to be working any ideas please
Sorry I didn't explain properly I haven't tried your codes yet I had tried some other codes but will try your suggestion about the one hour with the radio on thanks for all your help and hopefully tomorrow I will get it sorted ?Well I've double checked and 3253 or 1253 are the only possible codes for the radio with the serial number that you posted. I suggests that you have either made a typo in the serial number or you are putting in the code supplied wrongly. As far as getting rid of the 'wait for 1hour' message, the radio has to be turned on for the 1 hour period with the engine either running or the ignition left on. Best idea is to just drive, with the radio 'on', till the message changes to 'CODE'
Just to let you know the code worked a treat thanks for all your help ??Sorry I didn't explain properly I haven't tried your codes yet I had tried some other codes but will try your suggestion about the one hour with the radio on thanks for all your help and hopefully tomorrow I will get it sorted ?
No problems, try 6494 or 0494............apologies for the slight delay, but been out to have my first Covid jab todayMorning All,
Could one of you help with a code for my daughters car please ??
BP5389 6 2398926
Hope you can help
Thanks very much.
6494 worked a treat - one very happy daughter and a Dad with Brownie points !! Thanks very muchNo problems, try 6494 or 0494............apologies for the slight delay, but been out to have my first Covid jab today![]()
