Hi, try 7567 or 1567........Hi,have you the code for the following,thanks.
BP 3349 4 7226164
7 643 349 318
Thanks again
Thank you!Hi, try 7952 or 1952........
Hi Jhon, can you unblock this radio or i should buy one from scrappy?Hi! can you please help unblock my radio?
I just removed my ORIGINAL BLAUPUNKT radio and i notice that the sticker from behind is missing, but i found this codes attached.i have no clue what that mean, i tried the 4 digit code but it wont work.
I attach below the back codes.
28 185 AX613
HP-3123
And another codes are engraved on back radio frame:
8 635 123 393 0
>St SN<
Hi, try 5005 or 1005.........(probably the first number)Hello all...after my battery went flat my radio needs a code and I dont have it.
BP536258436354..
Please help me![]()
Thank you so much! It was the first number indeed. I had only one try left before the "wait 1 hour"...thank you againHi, try 5005 or 1005.........(probably the first number)
Hi, try 6607 or 0607.......Can anyone please help, code for Nissan Micra 2006, bp334947331381,
Hi John, just bought a Micra 1.2 08 Reg battery was flat so radio is looking for a code would ther be any chance you would have a code for ir.
Serial No would be PP3001MB 0016579. If you had it that would be great
Sound Job will try them on Monday and post results. ThanksMain Dealer or a Decoding Service only for this code.
Try here => https://www.ebay.co.uk/itm/174587946318
Hi.Hi,
Please help. I need the code for....
BP234631975834
7 642 346 318
Many thanks in advance
Cristian
Try : 9180Hello,
Same as many on here I’ve replaced my radio without realising I would need the code. Any chance anyone would know what code I need?
My serial number and product code are as follows.
Bp334936380224
7643349318
Hi.
Try : 5593
Try this one : 1593.Didnt work mate, thanks tho
If it dosent work maybe @John_D can find other codes. Good luck
Like the previous person that replied, I can confirm that the code for the serial number that you posted is either 5593 or 1593 (probably the first one). If it 'didn't work' then the reason is almost certainly that you have not used the correct button, after inputting the code, to confirm it.......Hi,
BP234631975834
7 642 346 318
Cristian
Yeah I think it was my issue. What is the button to confirm it please?Like the previous person that replied, I can confirm that the code for the serial number that you posted is either 5593 or 1593 (probably the first one). If it 'didn't work' then the reason is almost certainly that you have not used the correct button, after inputting the code, to confirm it.......
Been out in the car for an hour and a half and the radio still says "wait 1hr". HelpYeah I think it was my issue. What is the button to confirm it please?
Thanks for your response by the way.
Sorted! This guy sent the code within minutes, was right first time. Recommend to anyone who has this issue. Thank you!Main Dealer or a Decoding Service only for this code.
Date 09.30.2014 *Hey all! I’m looking for a radio code for a 2014 micra:
SW L0338
D.N. TEK352
Date 09.30.301
is this a main dealer job?
Hi, 0901 would appear to be the 'magic' number that you are seeking ;0)...........Hello everyone ... after my battery runs out my radio needs a code and I don't have it.
BP234746078141.
Please help me
Hi, try 6929 or 0929......Hello, is there someone who can help me with my radio code? The car is Nissan micra 2004. My BP is BP334947286038. Thank you in advance!!!![]()
It’s 6929. Thank you so, so much!!! ?Hi, try 6929 or 0929......
Hi, try 7737 or 1737....Hi,
The daughters 2003 micra has just dumped its radio code. No luck in the manuals can anyone help?
SN BP33493 6377969
TIA
Thank youHi, try 7737 or 1737....
Hello,Hi, 0901 would appear to be the 'magic' number that you are seeking ;0)...........
No worries 0373 should solve the problem...Hi I'm hoping you can Help Me too
Recharged Battery lost Radio and code with documentation doesn't work
Pulled Radio and has Different Barcode to Documentation
BP5387 8 9963794
7645387618
e1024199
Just Waiting for Wait 1 Hour (Sigh)
