Sorry, radio is made by Daewoo, so can't decode it. You may get lucky and find someone on eBay that can supply you with a code for £1 or so, otherwise it's the 'Main Stealer' I'm afraidHello,
I have jump started my neighbours car and been locked out of my radio as a result! Nissan dont have a code and the dealership is claiming it'll cost £42 to fix.
This is what displays on the lock screen:
serial#: DW47N03128
Part#: 28185 3HN4B7
Prod Date#: 14 07 09
Any help would be greatly appreciated! Thank you in advance![]()
Hi Try 4185 or 0185.....Hi John,
We were finally able to get the serial number of our radio. (Thank you for all your guidance btw)
BP536556441185
Could you please help us to get the code?
Many thanks and have a nice evening!
No worries and thank you for the reply! You're doing god's workSorry, radio is made by Daewoo, so can't decode it. You may get lucky and find someone on eBay that can supply you with a code for £1 or so, otherwise it's the 'Main Stealer' I'm afraid![]()
Hi, only one possible for this 1919.........Hi there!
Can some please give me a radio code
My model/serial : Bp 5362 58414451
Thank you so much!
No problems, try 7186 or 1186.......Hello, I just had the battery replaced and don't have the code as the car was second hand. Could not get any info from the display as it keeps saying wait 1h and then goes to 0000. Took the stereo out and the serial no is BP234631981520. Can anyone suggest what code to use please?
You were lucky that I was at my computer when the message came up that one of the threads that I monitor had been posted on..........definitely the exception rather than the rule...... ?Wow, that was so quick!!! Thank you so much.
Hi, try 7156 or 1156.....Hi I lost the radio code can you help me?
BP234620851326
7642346318
Thank you John a lotHi, try 7156 or 1156.....
Hi,
I recently bought a 2006 Micra, I entered the service mode to get the code and it reads as follows, hopefully in the right order;
5524A 6.0 62409288 X 1 1A
Can I get a radio code off of this?
Thanks,
Anthony
Hi, try 8355 or 0355.....Hi I have changed the battery on my daughters car and now I need a code for the radio - sadly the code has long been lost. Can you help please?
The radio code is BP738398445503.
Hi, 1840 should unlock your acquisitionBought me a 'new' 2and hand radio for my nissan note.
Can you supply me with a radio code please?
Many thanks in advance.
Matthew.
BP7383 8 7810434
Blaupunkt Nissan MMR#2 CD-G
Hi, 1840 should unlock your acquisition......
Thanks a lot John_D. Will try the code when the radio is delivered.
Kind regards
Hi, 1193 should solve your problems...Can you supply me with a radio code please? thank you in advance!
BP334958140478
7643349318
They are not referred to as 'Main Stealers' for nothing!Anyone help with a stereo code just bought the car for my daughter and have everything but the stereo code nissan want £70 quid and think it would be easier to chuck a cheap aftermarket stereo in.
Bp334947233238
85351233920
M5x6mm
These are all the numbers I can see.
Thanks.
Thanks just waiting for the 1h to end. Really appreciate your help will make the driving lessons a little less tense for meThey are not referred to as 'Main Stealers' for nothing!. Try 9231 or 1231, probably the first one will do.....
No worries, 1541 should solve your problems.....Any chance of a radio code? Thanks in advance!
BP7383 9 8783618
7647383318
E1034173
thanks a lot!!Hi, 1193 should solve your problems...
Id appreciate help to unlock the radio on my 2016 MICRA
DW5CN05077
Part 281853HN4C
Date 16 01 04
Hi, only one code possible for this one....0783......Any chance of a radio code? Thanks in advance!
BP7383 A 9407011
7647383318
E1034173
Given the requirements posted many times before..........no...Hello,
Thanks for all you time!
Would you be able to get me a code with these numbers?
PB 3349 4 7301 471
7 643 349 318
022458
Best regards,
Ruud
The significant requirements are that the radio was manufactured by BlauPunkt and that the serial number starts with 'BP' followed by 12 numbers (though sometimes the fifth number is a letter) Your radio, with the serial number starting with 'PP' denotes that it was made by Clarion..... my software cannot decode it...... All this has been stated numerous times, in the currently live, code request threads....Hello,
Sorry, I can not find the requirements, is it possible to note them in the opening post?
What do you need more?
I can not find more numbers on the radio.
Sorry if this has been asked many times before, I am new to Nissan Micra's
This one seems to have slipped through the net for some reason.......belatedly try 2480 or 0480.....Hi, I’ve recently bought a 2005 Nissan Micra as my first car and a code is needed to unlock the radio
BP436258405633
That is the serial number
Any help will be much appreciated
