Thanks So Very Much John_DNo worries 0373 should solve the problem...
Your a Super Star for Getting back so very quick
Code worked an absolute Treat
Many Many Thanks
Hi, try 2306 or 0306......hi there,
can someone please help my battery went dead and i need radio code.
blaupunkt-werke gmbh
BP234632008317
7 642 346 318
any help would be most appreciated
Thanks John_D it was the first oneHi, try 2306 or 0306......
Ok thank youMain Dealer or a Decoding Service only for this code.
Try here => https://www.ebay.co.uk/itm/17458794631
Hi!Hi John_D
Thanks again for the radio code for my micra, i was wondering if you could help with another code for me. It's for one of our work vans which came back from the garage after having some work done and they must have disconnected the battery as we now have to enter the code(which we don't have). It's not a nissan but the stereo is a blaupunkt like my nissan.
The details are:-
blaupunkt gmbh
815bp730181898039
7 647 301 316
The stereo is from a citroen nemo, i would understand if you can not help with the code as this is a nissan forum but if you can help out once again i would be very grateful
Thanks Maxxy8 but I don't think that's the code as there's no way of entering the zeros. I can only enter numbers from 1 to 6.Hi!
Try this code : 4060
Shouldn't be a problem that it is a Citroen, the code you need is either 4060 or 0060, usually on Nissans the first code is the one but you may need to try the second one....Hi John_D
The details are:-
blaupunkt gmbh
815bp730181898039
7 647 301 316
You dont enter the code using the number buttons, it is done using one button and the amount of pushes on the button determines the number...Post a picture of the radio and I'll try and find out what is the correct button for the code input...Thanks Maxxy8 but I don't think that's the code as there's no way of entering the zeros. I can only enter numbers from 1 to 6.
Once again thanks anyway
Thanks John_DYou dont enter the code using the number buttons, it is done using one button and the amount of pushes on the button determines the number...Post a picture of the radio and I'll try and find out what is the correct button for the code input...
Just done a bit of research and it appears that my software is incompatible with your radio. As you say the code input is achieved using the pre-set buttons and only numbers between 1 and 6 can be in the correct code :0(Thanks John_D
I can tell you its a - 2250 mp3 te sb05 radio and when I went to put the code in you have to press the appropriate numbers in order ie- if code was 6543 you would press 6 first then 5 then 4 then 3.
Do you just want a picture of the front of radio or just the label or both?
Thanks John_D I really do appreciate you trying for me, thanks anyway for tryingJust done a bit of research and it appears that my software is incompatible with your radio. As you say the code input is achieved using the pre-set buttons and only numbers between 1 and 6 can be in the correct code :0(
Hi, no problems, try 6768 or 0768........Good morning John_D can you help me?
Nissan micra 2005
S/n : BP334947288425
8 635 123 392
Hi please can you help me with my code just got my first car and having the issue of it asking for the codeHi, try 8643 or 0643 then.. Just realised that the four extra digits are the correct code![]()
Confused by the quote in your message, but 7638 or 1638 should do the trick....Hi please can you help me with my code just got my first car and having the issue of it asking for the code
BP6340T3206242
Can anyone help pleasehi
I need the radio code
bp234732041762
Nissan mm cd-j
7 642347318
E1 022458
Hi, 1430 would appear to be the number that you crave...... ;0)Can anyone help please
That’s worked out. Thank you I are superstarHi, 1430 would appear to be the number that you crave...... ;0)
Hi, try 2044 or 0044.........bp334936375931
7643349318
Please help me
Hi, try 5786 or 1786.....Hello, could you please help me? Changed the battery and stereo needs the code.
BP234746094907
8 635 123 392 0
Thank you
Hi, try 9856 or 1856.....Hi hows things just wondering can you get a code for BP538458558973
Hi, try 7531 or 1531...Hi, do you have the code for BP7383 A 9421 629 please, thanks
Good morning? Well it's almost half past four in the afternoon here .......however, try 7833 or 1833....Good morning all, can you please help me with a code ?
Nissan micra 2003
S/n : BP234631991918
7 642 346 318
Many thanks
it worked, thank you very muchHi, try 7531 or 1531...
If that is a typo and 'bo' is really 'bp' then the number that you want is either 9968 or 1968.....Can someone give me a code for bo536158076998 thank you really in need for a code
Geen probleem, probeer 4408 of 0408............Hallo wie kan mij helpen met mijn radiocode
blaupunkt-werke GMBH
BP738398860710
nissan MMR#2 CD-G
7647383318
034173
Groeten joost
That would appear to be 0140............hi all can you please help me with the code for my nissan micra the radio serial is BP234756230477 thank you
Another simple to remember code, 1816, The year without a summer.....Hi could anyone help me with a code daughter bought nissan with radio asking for a code
BP234732021846
7642347318
Many thanks in advanced
Thank you so much for the speedy reply but no luck I'm afraid,it's an 03 micra K12 , I input the code followed by the up arrow on the search and it goes back to wait 1H so frustrating an hour waitAnother simple to remember code, 1816, The year without a summer.....
I've double checked the code for the serial number that you have supplied and it is definitely 1816........can you check that BP234732021846 is correct? What does the display read, before putting the code in and what does the display show, after inputting the code, and before you press the 'up arrow'?Thank you so much for the speedy reply but no luck I'm afraid,it's an 03 micra K12 , I input the code followed by the up arrow on the search and it goes back to wait 1H so frustrating an hour wait
Again thanks for your help
All codes correct, the number stays on display before pressing the up arrow, immediately after it goes back to waiting an hourI've double checked the code for the serial number that you have supplied and it is definitely 1816........can you check that BP234732021846 is correct? What does the display read, before putting the code in and what does the display show, after inputting the code, and before you press the 'up arrow'?
Only come across this once before and that was where someone had the radio recoded by a specialist, and then the factory code no longer worked.... :0(All codes correct, the number stays on display before pressing the up arrow, immediately after it goes back to waiting an hour
Once the timer has reset it says 'code' the 4 blank lines until you input the numbers '----'
Very odd
Well maybe of to a specialistOnly come across this once before and that was where someone had the radio recoded by a specialist, and then the factory code no longer worked.... :0(
