Seems to be a run on these today...I need help too, same happened to me, my serial number is BP234631963342
Hi try 4697 or 0697....Same story as most other people here, replaced battery and lost code.
serial number BP538471203502
part number 7 645 384 318 / Nissan MMR CD-G
Hope someone can help
Only one possible for this one... try 1157.....Hi, my daughter has lost the code for her radio, she is uni in York, we're in London, I don't want her to get ripped off by a dealer, I know the serial number is BP334936379506
Hoping John or somebody could help us out please.
Sent from my Redmi Note 6 Pro using Tapatalk
Hi, try 5197 or 1197.......Hi guys! I change my old battery to new, and so radio is locked. I don't find my radio code in a service book.. Can anyone help? Nissan Micra C+C 2006, MMR CD-G BP5384 5 4888468
Thanks in advance!
Vic
Fantastic first code worked a treat ....happy wifeHi try 4697 or 0697....
Hi, try 4874 or 0874........Hi,
Hoping someone can help me get a radio code as I recently bought a 2005 Nissan Micra Urbis with a flat battery and did not receive a radio code.
Serial Number: BP334958137874
Part Number: 8 635 123 392
Thanks in advance!
5197 works for me! Thank you John!Hi, try 5197 or 1197.......
Hi, try 7306 or 1306......Hi, I have a Nissan Micra 2005, with Serial: BP334958124298, and I really need the radio code. Any help would be appreciated.
John you are a starOnly one possible for this one... try 1157.....
Hi, try 7812 or 1812.....I would be most grateful if I could get a code for a friend's radio.
BP334936350864
Thank you.
Hi Tony, try 6067 or 0067....Hello Micra forum admins,
I recently had a battery issue which now requires me to enter a code for my radio.
Could you be so kind to provide me with the code?
The serial number is:
BP538463843623
Thank you so much!
Tony
Thank you so so much, John. It worked!Hi Tony, try 6067 or 0067....
Hi can anybody please help Nissan Micra 06 removed the radio but no serial number all I can see engraved on radio 863512354201 26jan 2006Hi Jason, only one possible code for your radio 0303
Need radio code for that. ThanksHi can anybody please help Nissan Micra 06 removed the radio but no serial number all I can see engraved on radio 863512354201 26jan 2006
K122104211
Is there an echo in here?...........Hi can anybody please help Nissan Micra 06 removed the radio but no serial number all I can see engraved on radio 863512354201 26jan 2006
K122104211
Thanks John but it’s not worked the number I wrote that engraved on the radio but I couldn’t find starting from Bp please have a look. ThanksIs there an echo in here?...........
Well you haven't posted a number starting with 'BP' but if the 12 digit serial number did actually start with 'BP' then the code you need is 0241, sorry if this doesn't work but is all I can do with the info supplied.....
Hi, try 3230 or 1230.....Hi I had a problem with my battery and now need to reset my radio but I have no code for it.
my serial and part numbers are BP334947231989 and 7643349318.
Can someone please help?![]()
hi my serial is pp3001mb-0034261 please help me to find my nisan m8cra radio code many thanksTry 5202 or 1202.....
No problems, try 4812 or 0812......Hey Radio Guru
Can you PLEASE find the code for BP5362 5 8421172
Hi, try 2799 or 0799.......Hi love my micro but can’t get radio to work
Bp 234732040854
53 plate
Any help would be helpful
I have tried it but do I use ta button or 5 to enter itHi, try 2799 or 0799.......
After inputting the code just try pushing buttons OTHER than the number ones, till the code is accepted....I have tried it but do I use ta button or 5 to enter it
All sort now and I forgot how good my system works thxAfter inputting the code just try pushing buttons OTHER than the number ones, till the code is accepted....
Hi, try 5293 or 1293....Hi, I'm after some help too please. My radio is BP3349 3 6354772. Many thanks,
Debbie x
Hi, try 9318 or 1318.....Hi my fuse had blown at back of radio, fitted new one now asking for a code radio number is
BP334947253255, can someone tell me the code please thanks
Thank you so much top drawHi, try 9318 or 1318.....
