Marty, do me a favour would you please. When your panhard rod gets to you and before it gets fitted measure its length between the centres of the mountings at its shortest adjustment and longest adjustment please. Cheers Matey.
hi mate, its here and on!!absolute foooking joke, the bolts seize on to the rubber bushes and they have to be cut off,
i can measure from bolt to bolt (centre of eyelet on each end) but it woul need to be at same ride height to work
measure from your arch to bottom of your 13 inch wheel lip, i will do the same, this may require you lower the rear more to get the right measurement
at first with the car jacked up it doesnt look like it would fit but i must stress lower the car slowly until its almost at normal ride height and the axel will move into place and hey presto the bolts in, looks mint from the rear
sorry just re read your posts, i need to fit an m12 bolt as angle grinded mine of so only has an m10 in to hold whilst it gets rolled in and out of garage, when i fit this ill wind it out to get full length but you wont want it longer,just shorter mate
found a great way to get my paint of the roof and back of car
[video=google;-2761827359587052722]http://video.google.com/videoplay?docid=-2761827359587052722#[/video]
ive ordred them and have recieved them today
just tried on out, wow awesome bit of kit, no damage whatsoever to the metal work, not even a burring mark, ill 240 wet and dry all over them epoxy or zinc primer and im ready to go
is it really that bad with white cans then matey?
my boss sprayed his drifty bumper and wings but these look mint from up close
200sx far right, his mates ps on the left
can get the paint (properpaint) with thinners/harderner/bits for around 70 quid, everything to do a full car with except compressor and gun so not sure yet, body shops still want 400 + to blow it over even if i get it delivered all primered up and masked? thought with cans would be fine if flat and block it?
for me to go that low i would need
arch roller
165/55 13's or 175/50;s
front negative camber
coilovers
would love to but still need to save
yeah i had the white super s but sold it like a mug
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
would love it bakc but i sold it for alot so would have to pay alot back to get it!!
cheers
