Theres no point, just sr20 it if your thinking of putting another 1.3 in lol same amount of workso quite a bit thenreckon you could fit a glanza engine in a k11 easy nuf?
true will have to wait thoTheres no point, just sr20 it if your thinking of putting another 1.3 in lol same amount of work
Well done DougWell i passed my driving test today!
as long as its not megga tight eh (as long as the ratchet is on the same tooth as before you removed the tensioner)
and about time btwand well done
nice one dougyWell i passed my driving test today!
leon said:wdid? well yesterday morning i changed my exhaust system to a ummmmm........... peter lloyd rally woooohaha sounds mint, and then went to work
then on way home at half 1O doing 8Omph on m4 the car decided to go left
i had no steering or anything just left, so go to the hard shoulder and got under to find out the cv joint i fitted brand new like 2/3weeks ago had shattered
so had to phone mr rac and had trouble getting my car on the trailor for a toe home coz its so low!haha LOWNESS FTW!!!
, so im not to happy that a cv joint has gone in 2/3weeks :/ but on a good note my car sounds lush!haha
Where did you get the joint from? May be able to return under warrentywdid? well yesterday morning i changed my exhaust system to a ummmmm........... peter lloyd rally woooohaha sounds mint, and then went to work
i wantttttt it!!!Ummm well I started laying down the base layers of paint on the cam cover before I can attack it with the air brush.
I got this far before giving up
The masking tape I was used started to peel up at the edges which means it's got to get rubbed down and then start again :'(
ummmm.. i do no how to repair a cv joint :/, ive done plenty :/never had a problem before, ..... its just that one! last time i buy one off ebay!,
not that long if you add all the time up but its been done over a few days
a few hours rubbing it down to clean metal
hour spraying light coats of primer
next day the white
today the red
but as said its gone wrong (cheap masking tape) so tomorrow if i get chance ill rub it down and sorce some better tape. the paint is normal automotive paint. although the cam cover gets hot most paints can cope with it
wing as in front wing/wheel arch?Went and priced a new wing for noddie, i knew they would be exspensive from a dealer but. At £152.18 a piece id rather not :/, any one know anywhere else i could get one?
Yes wing as in where side indicator is mounted as its rusted around the arch ill take a pic tomorrowwing as in front wing/wheel arch?
Nope normal car paint. Most paints can deal with the temps the cam covers reachdid you use specific paint? like heat proof or something? wanna do mine but not sure what paint to get!
That's not bad ill have to take a lookCool, i ordered them and turned out one was going to take longer so i went to the scrappy and got a good condition one incase the new one wasnt here intime for the respray. There are some good ones out there and it was only £20
Look what came today...
Whiteline 22mm front and adjustable rear roll bars and a Janspeed group a 4-2-1 manifold![]()
what links do you want ....
Thats incredibly dangerous. If you're not sure how to repair something, get someone who does.
Sent from my GT-I9100 using Forum Runner
altered the side exit 50mm system (with a very effective primera diesel silencer) and fitted a boot release lever/cable etc (what a f/kin mission that was !)
