Fixed my throttle body for 6 quid! Runs like a dream now.
http://www.micra.org.uk/threads/2000-2002-throttle-body-problem-repaired-for-£6.50785/
it just shows that its no faster than the cammed 1311 when ragged TBH dave (similar 0 to 60 etc) you have loads of extra grunt lowdown for daily driving, but it really lacks the topend that you need for sprinting.What happened?
no rob, a bored out CGA with corsa pistonsAre they a straight swap frank? I presume thats a GA14?
no rob, a bored out CGA with corsa pistons![]()
13.5:1 c/r was a bit OTT mate lol, felt really pokey but sounded like a diesel lolHows this running Frank? well i hope
she only lowered the jacks, she was busy making dinner so i didnt want to take her away from that for too longma did,nt get her hands very dirty ed
WDID ? pulled the idle down to about 400rpm
Hmm poke
X2 i keep getting stopped and my rears are barely legal. you can get forced into a fresh MOT if the police have a bad day.well, the tyre tread is out of the arch which ilegal
None of the above... Camber!more stretch? arch flare? or bolt on?
Yeah but it wouldn't be so easy on the rears. and serious camber is actually awful for UK road use.None of the above... Camber!![]()
well either stretch or camber.I only have to worry if I get a twat of a copper the rears are fine but the fronts are borderline
That's what I did to my sr when I had the 7js. Killed the tyres thoughNone of the above... Camber!![]()
I want it! Nice workCleaned my cam cover with oven cleaner and then painted it
View attachment 20165View attachment 20166
Thanx i used metallic red VHT paint from halfords and just used a bit of sand paper to shine up the raised bits of writing.I want it! Nice work
so we,ve fitted that CGA crank into the 1367 corsa piston turbo engine, and gonna fit a CG13 crank to drop the c/r to a more sensible level![]()
That is fluking smart work there!Do you just unbolt it or is there a sequence to tightening the bolts back up? torqued or just done up tight?
yes mate, 2 links removed from the lower chain and 2.5mm blockskim, and 2mm headskim, but the head was weldfilled also, so ended up with a crazy c/r figure lol. (so shelving that engine till i get another head skimmed, and will fit a CG13 crank)Guess you dont know untill your try hey Frank! top work as always though... was that the engine with the link removed from the chain & skimmed right down?
Iv got a spare block i fancy a tinker with![]()
currently running a coilpack piston 11.5:1 @ 5 psi, but the 1367 turbo engine is now fully built and ready for fitting![]()
aye, it sounded exactly like a diesel engine daveI'd not noticed what you were shooting for Frank, it's hard to keep up with all the engines you have on the go13.5:1 sounds pretty mad on a 260 cam, I think we're around 1 compression point lower than that on a 'fairly big' <--
cam.
the 71mm CG liners i smashed out years ago were only 2mm thick, so i had a 72mm CGA block bored to the 72.5mm corsa pistons for the 1367Be good too see that in action mate, have you ever used cylinder liners in an aluminium block? or a CGA14 block with CG13 head and cams?
That turbo motor should see you into the 14s hey!!
the 71mm CG liners i smashed out years ago were only 2mm thick, so i had a 72mm CGA block bored to the 72.5mm corsa pistons for the 1367![]()
the gasket would fail even if you had sleeves fitted eh (CG/CGA h/g have 72mm fire rings)Cheers Frank, im guessing its not possible to bore it to take a 76mm GA16 piston(not much material left eh) im stuck in an up to 2000cc class at my local hillclimb!! need all the help i can get... an SR20 would be just too heavy
Just undo the 10 screws to remove but mine didn't to come off at first so just leaved it up a bit on the front left corner to brake the seal then it came off easy.Tightening sequence scanned from the service manual attached, (removal is just the reverse order).
Torque is 2.1 - 4.0 Nm
