h701micra
Deactivated Account
There's one for sale for £100 something round hereNeed to save up for a lathe
They did a distributor for me a while ago. Worked really well. I'd probably go as far to recommending them myself
Your welcomeThanks for the reply mate.
Il have to get in touch with them to see exactly whats in the kit / how it works! Some ignition advance would be nice
they,re near to dougy paul have you checked what sort of spark curve you have atm ? (usb lead or ecutalk etc)Does anyone have experience with http://www.h-h-ignitionsolutions.co.uk/ ?
I notice they are used by a few of the space framed autograss guys that run carbs but they arn't on the forum much any more...
It's usually 3D so ign vs load vs RPMNoob Q Frank but spark curve being rpm vs ignition advance?
looks bang-on to me paul you are compromising about 10hp without any load correction tho (like vacuum advance, but more sophisticated )
paul (polly) posted his spark maps up to compare yours with eh
also, bear in mind those are just the figures programmed into the ecu paul the "true" figures will depend on where you set the dizzy ehWell guys finally I've got a bit of data from an Ecu, my first infact!
Here are the rpm/ignition advance (first thing to tweaks the dizzy as its 1 degree out on idle)
1000rpm. 16deg
1500rpm. 26deg
2000rpm. 31deg
2500rpm. 37deg
3000rpm. 39deg
3500rpm. 40deg
4000rpm. 41deg
4500rpm. 41deg
5000rpm. 41deg
5500rpm. 42deg
6000rpm. 42deg
6500rpm. 42deg
Any feedback would be very much appreciated
Thanks Frank il have a good look through Paul's maps!
10bhp is a lot to be loosing on such a little engine, is its TPS that gives the Ecu the load?
Think it's time for some mapable ignition!
and if you could get those carbs to idle @ 650 paul i think it would probably read about 5 deg
I'm a bit lost with what you setup is now are you running carbs and stock ecu to do ignition?
a t/p/s would be easy to rig up eh, and praps mount the maf on only 1 cylinder, but you would need some trial and error in sizing the venturi around the maf, to give the same signal @ a 1/4 of the airflow.
it seems daft to spend £300 on a spark only ecu for n/a personally, quad t/b and full stand-alone ftw paul
a plenum defeats the object of quads to some extent ehWouldnt having a plenum made up be beneficial?
Constant reading even at low rpm? No pulsing
but with no vacuum advance, paul is having to run a lot of retard throughout tho dave.For a car that will spend most of it's time at WOT, the gains will have to be worth it in any respect. Daily drivers where part throttle and transient conditions play a significant part are a different story. Currently you're as good as the default spark map and thus limited by max output at any given point, (usually an average since DET is not an issue).
if the map was correct for the WOT that he is running most of the time, then it would pink like mad when he was accelerating through the gears
I have seen logs of both from the same session and they are surprisingly similar.i would have thought maf would be more suitable for n/a personally, because the vacuum signal is,nt linear to the load surely ? (you can have zero vacuum @ wot for most of the rev/power range eh)
some basic tps and 1 cylinder maf input will be far better in terms of sparkmap than just disconnecting them, but a 1 cyl maf signal will be very pulsed at low rpm tho
have you checked with a strobe yet paul ?
because if you,re running at around 0 deg base timing @ 650rpm, then your top-end/wot will be about 10hp down
no mate, but if you,re running 15 deg it must feel very rough when accelerating from lift !
i,ll do a strobe vid tonight paul, to try and show the amount of retard when you blip the throttle
Thats what I'm doing gsxr ITB's and microsquirt, the ecu comes in around £300Cheers Frank appreciate your help with this.
I guess the ECU only sees the RPM so when i boot it at high speed, come off the throttle & back on again it doesnt see the difference between that & accelerating from a stop at idle so the ignition is way out when accelerating from lift.
A few tweeks to improve anything in the mean time would be great.
I've set my mind to the next setup now.. good by carbs & hello ITB / Aftermarket Management... if im going to do it i may as well do it properly & learn how this all works at the same time
this one shows the timing being pulled as i rev it harder paul, the paintmark darts to the left when gently revved, and stays pretty much at the base level when ragged eh.
but bear in mind mine is nistune-d tho eh (the lower turbo map here http://www.micra.org.uk/threads/apexi-s-afc.56206/ ) where the right hand (high load) columns are held at little or no advance, and the left hand column (off boost) has the normal advance curve.
yours should be more like the upper (n/a) map on that link eh
i should,ve done some more vids with the t/p/s and/or maf disconnected too eh paul
