Hi, try 3105 or 1105......Hello there.
Can you please help me retrieving the code for my Micra radio?
serial number is bp334947288647
Thanks,
Fabio
Thanks,
Fabio
You will need to get rid of the 'wait one hour' message before you can input a code. To do this you need to turn the radio on and either leave the car with the ignition turned till the message goes (about an hour) or just go for a drive, with the radio turned on, till the message changes to 'code'.Hi, could you help me? I have code straight from Nissan, but it is not working. My serial number is BP234631990977. I type code from Nissan, press tune up button, but after that there appears 'Wait 1 hour'. That is Micra from 2003 year.
Hi, try 3031 or 1031........Hi can anyone help me to get code for
BP334947298557 plz
Looks like 0204 will solve your problem......Hi guys,
Could someone please help me with a code?
BP538471207878
Many thanks in advance!
Thanks John. Very kind!Looks like 0204 will solve your problem......
Requests are acted on promptly, demands less so..........
Sorry for that I need to drive a lot but I don't have music now can you help me plaeceRequests are acted on promptly, demands less so..........![]()
Now that wan't difficult was it? Try 8808 or 0808, possibly both will work......Sorry for that I need to drive a lot but I don't have music now can you help me plaece
Thanks for the codeNow that wan't difficult was it? Try 8808 or 0808, possibly both will work......
Hi, try 7856 or 1856....Any help would be very much appreciated.
BP334936351894
SN:7643349318
Many Thanks
Many thanks I'll try tomorrow morningHi, try 7856 or 1856....
Sorry, not apparently a BlauPunkt made unit, so can't help....(if you do get it out of the dash and find a part number starting with 'BP' (as long as the first three digits aren't '000' ) then that is another matter...........Hi John,
Any idea on my one mate? Any help would be great
Thanks in advance
Hi, try 7056 or 1056.....Hello. Can i get a code for mine
BP 7383 9 8445263
7 647 383 318
Thank you!
7056 worked like a charm. Thank you very much!Hi, try 7056 or 1056.....
Hi, 1843 would appear to be the number that you require.......Hello, don't suppose you could help me please could you?
Im in need of a code for my radio..
BP 334958120869
7643349318
Thankyou in advance![]()
Thankyou John! Appreciate it!Hi, 1843 would appear to be the number that you require.......![]()
Hi, try 7846 or 1846........Hi,
Bought my '04 micra and the radio isn't working
Numbers from the back are
bp3349 4 7305138
7 643 349 318
Any help much appreciated, please and thank you![]()
Hi, just one possible code for this one, 1886 should get it going again....Hi,
sorry can I have the code for
BP538471207553
I really cannot stay without my radio
Thank you so muchHi, just one possible code for this one, 1886 should get it going again....![]()
Looks like 0232 is your lucky numberHello,
I have a micra from 2007.
But the radio code is gone.
Serial is BP5384 6 3844617
Thanks in advance, Eléonore
Looks like 0232 is your lucky number![]()
No sorry it appears that your radio is not one that I can decodeHi John, do you need the year of the car for mine? It's 2010 if that helps. Thank you
Robyn
No, I can only decode units made by BlauPunkt (12 digit serial number proceeded by BP), sadly yours does not fit this criteria.Hi John, not sure if this number is what you need instead??
CM0023 A 3131443
Right OK, thanks for getting back to me. Do you know where I will be able to get a code? It's strange as it definitely says it is BlauPunkt but for some reason the serial number starts with CM ?No, I can only decode units made by BlauPunkt (12 digit serial number proceeded by BP), sadly yours does not fit this criteria.
Hi, try 6614 or 0614.......Hy! Please Help Code!
BP538962406461
Nissan MMR CD-G
Thank you!
Thank you very much for your quick reply! try it!Hi, try 6614 or 0614.......
Hi, try 9204 or 1204.......Hi John,
Please could I have the code for my 53 plate micra radio:
BP3349 3 6370413
Many thanks in advance![]()
Hi, try 2519 or 0519....Hello everybody!
Could someone help me with my radio please? My numbers are BP234631967105 and the serial number is 7642346318.
Thanks a lot
