You sir are a star! Missus has tunes again.Hi, just one possibility found for this one....1598
Thanks you
Hi, try 6114 or 0114.....Hello !! Just bought my girlfriend a used micra with locked radio ofcourse
Blaunkpunt
BP 234632514984
7 642 346 318
Any help with code will be appreciated!
Looks like it's your lucky day, try 2054 or 0054.....Hi John, got a 2009 Micra with a locked radio, could you help?
Blaupunkt
Serial number - BP7383 9 8444196
Model number - 7 647 383 318
It worked ! Thnx a lot !!!Hi, try 6114 or 0114.....
Hi, try 6172 or 0172.....Hello
I have locked radio in my micra. Please help.
Serial Number- BP536258426566
Model Number- 7645362318
Thanks in advance for your help.
Thank you very muchHi, try 6172 or 0172.....
Hi, try 5763 or 1763.....Helle there,
Could you help me out with my Micra please? Battery dead, no code
BP334936355400.
Thanks in advance.
John
Hi, try 9415 or 1415......Hi can I get an unlock code for radio bp538469466224.
Thanks.Hi, try 9415 or 1415......
Hi, try 8658, or if that doesn't work.
I need codes for bp538769673768
Can you please help
If it helps the Model is fdlalbak12egaa. Where can I find the number that starts with BP?Hi,
Can you please give me a radio code for 2001 Nissan Micra with Serial code sjnfcak12u3202938
I already locked it for an hour
You need to get the radio out. It's on top or the side of it.If it helps the Model is fdlalbak12egaa. Where can I find the number that starts with BP?
Hi, try 3080 or 1080.......Hallo there, i was wondering if i could get the radio code for my micra from 2001. Serial number is
MM CD-J
BP234720860814
7 642 347 318
Hi, first post here so hope I don't break any etiquette rules
My friend has a 2011 with Connect Nav, and has the pin issue after a battery swap.
Can we get the serial from the display (after inputting the wrong pin 3 times or something) or do we have to find the sticker on the back?
cheers
Sadly don 't recognise anything that I can use to generate a code, and from past experience, the BlauPunkt SatNav units that do have a 12 digit 'BP' number, that I've seen, start with'000' and my software doesn't recognise it. A Nissan 'Main Stealer' may be your only answer, but be prepared to get robbed over the price!slight update, a garage removed (or did something to half remove it) the radio for my friend and took two pictures of part numbers, also saying there was no BP number on it, can anything be done with the following numbers?
Bosch part number 7 612 830 031
Nissan part number 25915BH10A
Index: E
SW: 0225
MH: 009
HW: 031
Production Week: 430
theres also a long bar code:
9595556 25915BH10A E 0225 009 031 430
Sadly don 't recognise anything that I can use to generate a code, and from past experience, the BlauPunkt SatNav units that do have a 12 digit 'BP' number, that I've seen, start with'000' and my software doesn't recognise it. A Nissan 'Main Stealer' may be your only answer, but be prepared to get robbed over the price!![]()
Hi, probably not worth the hassle of removal as I don't think that any 'independent' could find you a code and you look to have all of the relevant information anyway... check out code providers on eBay, you may get lucky but a ' Main Stealer' may be the only answer, but I suspect that they will want about £60 for the informationthanks John for your consideration on this. I read earlier that the BP number may be "stamped" ...is this instead of a printed sticker?
What happens if you lock out the unit with incorrect PINs to get the serial displayed? Is this even a thing, and if so does this lock out the unit from being remedied by your PIN service?
thanks in advance.
P.S. is there a "donation jar" of any kind?
edit: I've just realised that you likely can't help because this is a Bosch.....or do you think it's worth the pain of convincing my friend I should remove the unit and have a thorough check? And yes...there will be pain![]()
3080 was the one! Thanks you.Hi, try 3080 or 1080.......
Hy
Can you please help me with my radio code
BP334936379101
Thanks you in advance
Hi, try 6499 or 0499......Hi I would be most grateful for a code for bp334958129315 thankyou
Hi, try 7240 or 1240......Got device number to if that help
764349318
BP334936379101
You appear to have left one number out of the serial number, there should be 12 numbers after 'BP', not 11........Hi.
Had to change my Micra's battery and now the radio is locked.
BP33493635344
7643349318
Would be amazing if I could get the code! Thanks!
Thanks that's brilliant 6499 workedHi, try 6499 or 0499......
You appear to have left one number out of the serial number, there should be 12 numbers after 'BP', not 11........![]()
That's betterOops!
BP334936354344
7643349318
Thanks a lot!
Hi, try 6464 or 0464......Hi, can you please help me with the radio code for my micra k12? serial number is BP234631996742. Thanks in advance
Thanks, i'll try them!Hi, try 6464 or 0464......
Thanks so much, the first one worked!That's better, try 7895 or 1895....
No problem, try 6909 or 0909.....Hi John,
Can you please help me with the code for my Nissan Micra 2006?
Radio Code is: BP538769666966
Thanks a LOT![]()
Wow 6909 works.No problem, try 6909 or 0909.....
