Hi, try 8844 or 0844......Dear John!
I changed thermostat on my car, and remove the battery, unfortunately do not have the card for my radio, please help me.
Bp536258433118
Thank you!
Hi, 1587 should solve your problems.....Hi John!
We have a Nissan Micra (2006) on which the battery died recently and the previous owner lost the radio code and never wrote it down anywhere. Can you help me with what the code might be, please? Any help much appreciated! Cheers -- David
Radio Type: Nissan MMR CD-S (Blaupunkt)
Serial Number: BP538369451392
Part Number: 7 645 383 318
Thank you so much! I'll give it a go later today!Hi, 1587 should solve your problems.....![]()
Sorry I don't know the D changed to a smiley, is:Hi john new to forum, recently bought a Micra k13 with a Daewoo is corp radio CD player in it had to change battery and now its asking for a code which I don't have can you please help. Model number is : agc- 3220yf b and I think serial number isW47N02854093HN4B thanks you.
Hi, no worries (as yours is a BlauPunkt radio......unlike a lot of recent requests?)... 1610 would appear to solve your problem.......Hi, can someone help me with an unlock code?
BP334936367028
Thanks!
Awesome! Thank you so much! God bless you. You are very kind!Hi, no worries (as yours is a BlauPunkt radio......unlike a lot of recent requests?)... 1610 would appear to solve your problem.......![]()
Can anyone help?Hi. I need radio code for Nissan Micra 2016. The serial number is dw62n13244.
Kind regards
Hello, I have a Nissan Micra 1.4i 2009. I need a radio code because I had to remove the battery. Could you help me?Try 5202 or 1202.....
Hi. I need radio code for Nissan Micra 2016. The serial number is dw62n13244.Try 5202 or 1202.....
Ok thanks for your replyWould all people reading this thread in order to obtain a radio unlock code please note, if the radio serial number starts with ANYTHING other than 'BP' (PP, DW, CL etc) I CANNOT supply a code. I am only able to supply codes for radios made by 'BlauPunkt', where the serial number starts with 'BP' followed by 12 numbers (sometimes there is a letter replacing the 5th number). Here endeth the reading........
You may be able to find somone on ebay that will supply a code for non 'BP' radios, quite cheaply. Failing that you are sadly at the mercy of the Nissan 'Main Stealer' network, who can supply a code at a price.........Ok thanks for your reply
Hi, try 7479 or 1479....Hi john hope you can help too
I have a 56 plate Nissan not obvs no code,
it’s details are
BP5389 6 2398854
e1024173
7 645 389 318
Thanks in advance
Jason
THANK YOU SO MUCH!!!! 12months without a radioHi, try 7479 or 1479....
Read my third post up from this one...........Hi John, looking for the micra code for the following
serial 7478309
device 7612830091
date 11.10.17
thanks in advance
Hi, try 6773 or 0773.........hello john can you help me? i have a Nissan micra 2003 i need the unlock code of the car radio
bp234631999047
7642346318
Hey!
I’ve got the same problem after I replaced my battery.
Nissan Micra 2014
Serial#: DW3AN20529
Part#: 281853HN4B
Prod Date: 13 10 15
thank you so much my friends, appreciate it!
Sorry I didnt see your post.Read my February 19th post above.........![]()
Read my next post down on February 20th...........Sorry I didnt see your post.
So how can I get the code if my serial num stars with DW?
Assume this a 2009 SatNav unit? No part number starting with 'BP' and the only 12 digit number (starting with 'CM') on the Blaupunkt part of the unit starts with '00' so fairly sure that my software will not give the correct unlock code, but you can try 8038 or 0038 if you want, but don't think it will solve the problem.....Hello John!
I'm Attila from Hungary. After replacing the battery, the head unit requests a code. Unfortunately I bought it second-hand and it was not added. Can you help?
No problems, try 7511 or 1511 (possibly both will work).........Hi guys,
Any chance you can provide me with my radio code please ?
Serial is BP7383A9263222
Part No is 7647383318
Thank you in advance![]()
That's got to be one hour with the radio on and ignition on, go for a drive till the message changes to 'CODE'Thank you, i'll let you know shortly, I have to wait 1 hr ?
Only the code specific to your radio will unlock it, it is a waste of time trying other codes posted on here as they are all specific to the radios that they were posted for.......the unlock code for your radio will be 0381 ..............Hi Guys, going through hell since changing battery on my Micra 2005.
Can anyone please help with the radio code:
Serial BP3349 5 8115620
(the other number: 635 123 392 STSN)
I have over the last few weeks tried several of the codes from this forum without any luck, the one hour feature is driving me mad ;-(
THANK YOU ;-)
