Looks like you have lost a power feed, check that the connectors are firmly fitted in the back . If that doesn't cure the problem then probably a fuse blown.......Might be that someone replaced a fuse with a lower amperage one and it has failed?Hi John,
The number was correct and the radio has been unlocked, but few minutes later it gone out and when you press the on button nothing happens..may could be defected the radio?
Hi try 8792 or 0792.....
Hi Steven, no problems, only one possible for yours, 1797........Hi John,
Could you help me too please, I am looking for a 2003 Nissan Micra Radio Code.
BP234720857059
7642347318
Steven ;-)
Thank you very much John_D, the code worked!!Hi Steven, no problems, only one possible for yours, 1797........
Hi, only one possible for this, 1115..........Hi John, could you help me with my radio code? BP334947296905
7643349318
Many thanks,
Loren
Hi, try 9781 or 1781......Hi
can you help me with the radio bp538471212402 mmr cd-g 7645384318?
thank you
Hi, try 8693 or 0693.....Hi any chance I could get my radio code for my micra
Serial Number: BP738398852039
Part Number: 7 647 383 318
Hi, try 2233 or 0233.......Hi, Pls anyone kind enough to help me out with a code for my nissan micra III k12 radio
BP536258404534
Kind Regards,
Hi, try 6020 or 0020......Hello John!
I finally managed to get my audio details. Could you please help me out with my radio code?
BP 5362 5 8420751
7 645 362 318
Thanks in advance!
BR, Rositsa.
Hi again, I entered the codes but probably I am not aware how to confirm them... should I use the upper arrow ^ on the right-side button by pressing it or there is another way! My upper arrow ^ does not seem to do...
Hi, try 2209 or 0209......Hi,
Can you help me out please? The garage turned off my battery and now I don't have a radio!
BP5384 7 1217363
NISSAN MMR CD-G
7645 384 318
Thank you!
Naomi
Hi, only one possible for this, 0545.......Hi John,
Can you help me out as well please:
BP 5387 6 9668260
7 645 387 318
Thanks in advance![]()
Hi, try 8954 or 0954...........Hi can anyone help with my radio code. It is a blaupunkt BP234732020051. 7 642 347 318
Any help would be much appreciated.
Hi, try 7733 or 1733.....Hi John
Would you be able to help me get a radio code for my micra.
BP334958117374
Thank you
Hi John, thank you very much. I really appreciate that you took the time sirHi, try 7733 or 1733.....
Cheers John will give it a tryHi, try 8954 or 0954...........
Hi, try 8343 or 0343........Hello,
I have my battery disconnected and now need a code for my radio.
The S/N is BP5387 6113 0616
Will be happy if someone help.
Thanks, all work now ???Hi, try 8343 or 0343........
Once again cheers john, radio now working.Cheers John will give it a try
Right place, right timeHey!
Could you help me?
I have to replace my battery and now need a code for my radio.
The S/N is BP234631990708 , 7642 346 318
Thanks a lot!
Thanks bro very much! 9984 works! ?Right place, right time. Try 9984 or 1984, Big Brother is watching you!
Hi, try 8932 or 0932....just taken ownership of my aunties cherished 52 plate tempest, 1 owner from new, 42k and full history, even transport company shipping label...only thing missing is radio code (she's done without for over 4 years) so can anyone help me please
the serial number is BP634027936522 and its Blaupunkt 7646340318
many thanks
