Hi, try 6306 or 0306.....Hi, my battery was disconnected and now the stereo on my Micra 2008 is asking for the code. Can anyone help me recover it please? The serial number is BP5384 7 1214185. Thanks.
Hi, try 6138 or 0138....Disconnected my battery and now radio is asking for code, can anyone help?
BP538458814082
Thanks alot.
You have to remove the radio from the dashboard to find the BP number on it, either on a label or more often engraved on the side and/or back of the unit.... A Nissan dealer can give you the unlock code for the radio, using the cars VIN number (assuming the radio is the same one it left the factory with) BUT they will charge you for it (probably exorbitantly.....)Hi again John,
Unfortunately I cannot find the BPxxxx serial number of my audio. I tried to locate it on labels/stickers all over the car and still no result. Could you give me a hint what should I do next? Contact official Nissan dealer so they can give me the BPxxxx using the VIN? Any ideas?
Thx!
Rosi
Hi, try 2845 or 0845........Hello anyone can help me with radio code?
Nissan Micra 2005
7 643 349 318
BP3349 4 7320137
Hi, try 2212 or 0212......Hello John
I have replaced the battery on my Nissan Micra and need to enter the radio code, can you help please?
BP 53847 12118 43, part no. 76453 84318
Thank you
Hi, try 8507 or 0507....Hi, i need help with my radio code. My number is BP334958111094. Thanks
Hi, try 6321 or 0321......Hi John,
Please can you provide me a code. My number is BP536556020620.
Thanks in advance.
Hi, glad you posted on here, as I have stated previously I do not respond to PM's from anyone who has just joined the forum in order to get a free unlock code for their radio.....Hi john, can you provide me with the radio code, my serial number is BP536556445279. Many thanks
As stated many times before, I can only decode radios made by BlauPunkt, hence the need for the serial number starting with 'BP'..................Afternoon John, My 2008 nissan micra Bluetooth Radio serial number is PP3001MB 0056556. Could you possibly help me out with a radio code please?
ahh okay sorry, thank you anywaysAs stated many times before, I can only decode radios made by BlauPunkt, hence the need for the serial number starting with 'BP'..................
Hi, no problems, try 7256 or 1256......Hi John, can you please help me out with a radio code? My serial number is BP334947247836 .
Many thanks!
The first one worked, thank you!Hi, no problems, try 7256 or 1256......
Hi, try 4823 or 0823.......Hello. My battery was unfortunately disconnected when I had some work done on my micra recently and my radio was disconnected and has lost its code.
The serial numbers are BP538469505523.
Can anyone help? Thanks!
Hi, sometimes I think 'mug' is more appropriate,Hello Sir,
Cant believe how many people you have helped on here!!! You are a Knight!! haha
I have a Nissan Note that I require a radio code for.....Please could you help??
BP538769668722
7645387318
Kind regards
Simon
Will try tonight and report back. I really really appreciate it!! Nissan want £50!!!!Hi, sometimes I think 'mug' is more appropriate,, however thank you.
. 6892 or 0892 should solve your problem........
At least DickTurpin was honest enough to wear a mask! They don't call them 'Main Stealers' for nothingWill try tonight and report back. I really really appreciate it!! Nissan want £50!!!!
Thank you so much! It worked!Hi, try 4823 or 0823.......
edit:- Apparently the diminutive of 'Richard' is seen as an unacceptably rude word and is censored by the forum into four hash marks and only by leaving out the space between the '####' and 'Turpin' will it allow it......![]()
You beat me to it, I was going to suggest that oneOk, I just found a tutorial on youtube, its the up button on the RH white "knob", now its all working!
Sorry for being a dunce!
Apparently only one code possible for this one.....1269........Can you tell me the code for BP234732034280. Thanks
Another one with no alternative, this time the code is 1053.......Hi John, could you please help with a lost radio code?
it is BP53847 1200125
Thanks Simon
Hi, try 6771 or 0771......Hi John,
I have the exact same problem, could you please help me out?
BP538463842457
Thanks,
Ivo
