My GSX
My '91 GSX - front strut brace
My old daily, the diseasel, was in the process of dying again.
Here's a nice pic of it by the harbourside:
So last Monday I started a casual search for a replacement daily.
I'd been feeling the Micra love again for a while and found a '91, 187k, red 4 door 998cc facelift K10 with MOT until December and tax to the end of the month, oh, and no 3rd gear, for £50 on freeads.
By 10.30pm I was driving home in it.
When I got home I had a quick look for a replacement gearbag on ebay, found one, same county as me and sent the guy a message.
On Tuesday I took it to work to get it on a ramp and have a look under it, I also wanted to try a wheel on it, just out of curiosity y'know.
BMW E30 14 x 6 1/2:
Shame the centrebores on them are to small and I've only got 3 of them.
Got home from work to a message from the guy with the gearbag, it was still on the car and he was also selling the car complete. A couple of messages later and I was on my way to look at it.
It'd had the cam snap between 3+4, he'd replaced the cam but couldn't get it to run right. He'd also sold the n/s mirror off it and removed the carb.
It had 3 weeks MOT, 1 1/2 months of tax, 86k, 5 100nx wheels, a 5 digit numberplate and a tow bar!
£75 later I was being towed home in it!
Wednesday evening was spent doing a little research, which is how I found this place(Y)
Thursday evening we did a compression test, discovered no compression on cylinder 4 and removed the head to find out why. This ended up taking rather longer than expected as the front centre 3 head bolts were a b'stard to get out. 1 of them rounded and I ended up having to weld a socket onto it!
Friday night we took the head off the 998 and stripped both of them down.
Bent inlet valve:
I spent Saturday morning putting a mates Transit through it's MOT but managed to pick up a headset, coolant, oil and filter, a set of 5mm spacers and got some new tyres in a more suitable size put onto the nx rims whilst on my travels.
Saturday lunchtime I finally got to get on with the head.
If you've got the head stripped bare already it'd be rude not to 'tidy up' the ports wouldn't it?
Valves back in
Spot the difference
That's right, when the cam snapped it took a chunk of the distributor body off. But where did it go?
Ah, there it is.
By 9pm and having drilled out and retapped the snapped exhaust manifold to downpipe bolts, it was all built back up and ready to go back on.
But I thought I'd leave that for daylight, so I went out and removed the rear lights, front indicator lenses and repeaters, took them into the garage and tinted them instead.
Sunday morning I treated myself to a lie in and then went out and got the head back on.
Having run it up to temperature, I did the timing and reset the valve clearances. Runs very sweetly too.(Y)
With all the stuff back under the bonnet I got onto the fun part.
Bolted the wheels and spacers on and measured how much slam I could get away with. Jacked it back up, took the wheels back off and removed the struts. Dismantled them and carefully cut off the spring platforms, moved them 2 1/2" down and welded them back on.
Reassembled, refitted and photo taken
Fitted my gearknob
Drove it properly for the first time Monday morning, the journey to work highlighted a couple of issues.
The tracking was a mile out, it had a little flat spot, the N/S/R shock mount had rusted out of the top of the turret and the towbar was tapping the rear beam over bumps.
I fabricated and welded in a new turrent top and sorted the tracking after work and swapped the carb over when I got home.
Here's what I discovered when I unbolted the towbar :eek:
Third time lucky getting the holes in the right place eh?
Then out for a bit of a bimble round and a couple of pics again
I'm really quite enjoying it.
if i know BiAS (and being on retro rides for a while now i think i do)... i'd say a few coils have been removed from the springs ;)
looks spot on chap now whack a 1.6 or a 2.0 in her and show these boys how its done ;)
liking the 100nx alloys too had those on my first k10 :D
no messing eh BiAS :cool: awesome mate
and he,s moved the spring platforms down speedle aint he ?
might have, i though maybe he's just chopped the springs ;)
just re-read the post your right Frank, thought he just did a chop spring special :p
Cheers dude,
As per usual the realization that RTTS show n shine is only a couple of weeks away starts a period of madness, ideas that would usually be thought through fully and planned in advance are instead acted upon straight away, thus it begins....
Thursday night I went out to the garage at 10.45 and angle ground the paint off the spare bonnet (everybody needs good neighbours :cool: )
so that I could take the bonnet to work on Friday and whack some white primer on the front
Friday night I masked it up and scribbled on it.....
cut it out
just enough red left from the Sierra of Doom to paint it
et voila, 1am:
I've lightly sanded it and salt watered it and put it outside, hopefully it'll be rusty by the 24th eh?
Saturday morning,
Load all the gear into the van, get to the car park at my old flat, where the diseasel and the other Micra have been hiding.
By 11am we had got the diseasel started, moved the cars into a suitable position and stripped the interior out.......
11.44am
11.52am
12.00pm
12.08pm
12.33pm
1.18pm
1.56pm
2.17pm
2.33pm
3.23pm
3.29pm
3.54pm
We then concentrated on getting the rest of the of the Micra packed into the diseasel,
the lights wired up on trailer, original loom stripped of all the excess wires, taped up and connected straight into the trailer plug,
towbar modified to clear the rear beam,
towbar put back on,
towbar wiring modified to make the reverse lights work on the trailer,
and spring platforms moved to bring the ride height down to the same as the car.
no shocks or springs
lights work :D
ready for the frame
8.57pm welding the frame in by dusk
Got all the structural stuff done by which time it was dark, so we tidied up, hitched it up and towed it home.
Here it is, whilst we were dropping mates keys back to him, spot the sharp edges!
Sunday,
Let the neighbours have a lie in, it is Sunday after all.
Put a front on it
Close the front corners up
Bit of primer over the bare bits and hitch it back up ready to take to work tomorrow.
Hoping to get a ply floor and sides in it, cap the tops with chequerplate and maybe get the BBQ mounted in it after work.
The BBQ was the product of a previous weekend idea, made from old oven shelves, a gas bottle, some 1/4 plate and a lamp post (yes, seriously, and don't ask) Here's it cooking it's first fried egg. mmm
That is absolutely brilliant love the trailer and the BBQ, get it all together and it would be ace for the summer :D
As others have said theres no messing around with you lot is there :D
Would love a shot at doing something like this :p
great stuff
steve
14/05 Upate
Progress,
Took the trailer into work, could only find a small offcut of chequerplate and begrudge spending £70 for a whole sheet so I'm gonna have to do some filler work on the top edges as I welded the steel tops on with the sole intention of covering them :wasntme:
Got a front valance on to hide the ends of the sills and floor to bar join
Car-B-Q mounted and front and sides lined with wheezerboard (resin impregnated van floor ply)
Dave dropped the wheels off on his way back on Monday evening and my mate got the tyres taken off for me on Tuesday while I was at work.
Tuesday evening me and my mate who's a painter spent the evening with scotchbrite and TFR getting them ready to paint, here's how they looked by 11
What a horrid job! He said that next time he paints wheels for me they'd better be nice easy 3 spokes or softline 5 spokes!
Wednesday night I helped him tidy the (minor) kerbing and then he put the paint on them (Y)
So stoked with them
Meanwhile, with the assistance of salt, the bonnet is developing nicely. Why was I worried that it wouldn't rust in time?
Tonight I trimmed the return lip on the rear arches and folded the front ones up in readiness for getting the tyres swapped over and the wheels on.................
.........................and well, I couldn't help myself and had to see how they're gonna look :wow:
Can't wait til Saturday, I'm so excited!
wheels + bonnet
Saturday am, weighed in the diseasel
Bye bye dirty diseasel
Got the tyres swapped onto the Bimmer rims
Stance? I reckon
Wasn't going to put the bonnet on until next weekend but you know how it is..................
And the best part?
Bit of fabbing
gets me this
That bonnet would be insane without the rust :p Tag it up as Micra Sports Club and it will do the job. But some serious skills there, very impressed!
Bit of a newbie here when it comes to rat-rod/rust finishes, but...
Surely the rust would eventually eat the bonnet? Or have I missed something?
Looks awesome though! Great work with the rising sun!! :)
It will be laquered.
So it won't rust anymore...
I think.
I hate filler
Cheers for the replies folks,
Well chuffed with the stance/wheels.
The bonnet is a marmite thing, I've left the original bonnet catch in place so that I can swap back to the grey one if I change my mind after RTTS.
I desperately wanted to do the side opening but I didn't want to risk burning the paint on the grey bonnet with the welding because I really, really can't afford to have it re-painted. Rust is free!
The car and trailer as they stand owe me £450 including the cost of both Micras, a headset, oil and filter, 6 wheel spacers, an MOT and 6 tyres @ £35 a go. I am skinter than a skint thing with a very empty wallet............but I'm having a right laugh doing it (Y)
And that's the important thing eh?
nexxussteve + Littlewood - could laquer it but once the rust is in the steel it keeps eating and eventually the laquer would flake off. I've heard that anchor wax (?) works to slow it down but as I've no idea what it is or where you get it from so I've never tried it. The bonnet on the diseasel was rusting for about 12months and showed no signs whatsoever of going thin so I'm gonna leave it and see what happens.
I've spent the last 2 evenings doing the filler work on the trailer so it's ready to paint and reassemble before this Sunday. Last night it kept raining and I had to keep covering it up and working on the filler flap for the trailer
I hate filler, I find it annoying, put on, sand off, put on, sand off, repeat until your arms fall off or you die of boredom/old age
Did I mention that I hate filler?
Cheers dude! I've been looking for pictures of it from RTTS but haven't found any :(
Could you post it up for me please?
In the meantime have some pictures that our lot took.....
absolutely brilliant, my dream is to have a BBQ on my car bet you will get some use out of it in the summer :D
steve
This evening I decided that I fancied a strut brace so........
Stay on after work for an hour to roughly cut some plates out of 3mm scrap
to go here
and put a couple of bends in an offcut of tube, then home to ovalise it in the vice, trim the ends and tack onto the plates
then remove to the garage to weld up
make the plates a slightly nicer shape
knock up some braces out of 3mm scrap
bit of tweaking in the vice and buzz them on
Not the prettiest bit of welding I've ever done but good penetration so it'll do the job..................
and hey presto, a strut brace, for next to nothing :cool:
moddedmicra - nope, gonna leave it bare for a while, let it rust a bit (rat-look strut brace!) then maybe get it blasted and zinc plated somewhere down the line when I've got a bit more disposable income :)
Diskwiped - cheers dude
Hahaha this is absolutly amazing love it mate a think this has to be one of the best micra's ive ever seen its brilliant !!!!!!
Firstly a huge thanks to imp124 for coming up trumps with a cure for how the front of car looks(Y)
As promised steve,
Got home from work on Friday to a parcel containing a prefacelift grille and some other bits and bobs.
Saturday, I took the front bumper off to sort out my rounded out headlight adjuster (hooray I can see where I'm going again) and played about making brackets to put the grille on. The prefacelift nose is flatter than the later one and it took a while to get it the right shape. Stoked with it now:grinning:
Stiffened up the front shocks a bit, reduced the front ride height by about 10mm to tweak the stance and put some slightly taller bumpstops in the rear to stop the tyres touching the inner arch on big bumps:grinning:
Go to buy dice dust caps because the local kids had my own made ones off the car :suspect: and bump into a mate, take picture
Then extract the car-b-q from the back garden, tfr the bbq spatter off it, only to discover that tfr turns satin black to light grey, quick repaint of the top half and a lip welded on round the edge of the hotplate to stop fried eggs sliding off the sides.
Sunday took it to Southwestmotorshow, had the car-b-q fired up on the stand for breakfast and lunch, great day out, good weather, quite sunburnt
I've done a couple of other bits too, fitted spraybar windscreen washers that I had spare from the diseasel, shortened the throw on the gearstick and made a ridiculous extension piece that puts the gearknob at top of steering wheel height but I haven't taken any pictures. If anyone wants pics I'll take some.
great to see the grill on, looks mean now :D
wish the JAE BBQ was done on ur trailer :D that would be the dogs :)
Any other bits just let me know, i can get nearly anything for the k10 as our scrappys is full of them :D
nice work
cheers
Steve
I had the pleasure of sampling the delights of the car-b-que on Sunday, cheers for the egg, bacon and cheese roll Ian.
Some great ideas, inspirational and comic touches on the trailer.
The GSX looks even better in the flesh too. Great Work!
if u ever sell the trailer on its own (doubtful i know!) I WANT FIRST DIBS!!! lol :D
ace car really want to see it up close :D
cheers
Steve
Micra-mum - good to speak to you and your husband at retro-show and thanks for the pictures.
After a bit of track action at RetroRidesGathering...............
.........it had become apparent that the rack was moving about on it's mounts, which could well account for why the steering felt a little vague.
Tonight I finally got round to having a look at it, there was quite a lot of lateral movement. The rack is mounted in 2 rubber bushes, each with a strap securing it to the bulkhead. Only the o/s one has a rib either side on the rack to locate it, and this was where the movement was.
I kept the rack off the trailer as a spare and this still had the straps and the bushes on it. They weren't any better than the ones on the car and a search of ebay didn't reveal any new standard or poly ones so closer inspection ensued.
The strap is waisted and the sideways load is only on the 2 small wider sections at either end. This seems to wear the bush in this area only, so.......
Add in some extra metal and grind back to leave this, a more snug fitting strap
A bit of zinc spray and then put it on the car.
Result! No play!
I'll test drive it tomorrow on the way to work but even stationary the steering feels so much more direct.
Having just found this thread, I've just spent half an hour reading (when I should have been working!) this project. Utterly amazed at the thought and effort that's gone into this car! I take my hat off to you!
The BBQ looks brilliant too!
James :)
Yesterday was my 35th and I had a great birthday, I treated myself to a day off work and went and bought myself a birthday present..............
4.5 hrs work in my local (proper) scrapyard saw me and Jody turn this scrappage scheme Micra
into this
Meaning that this
should soon have these in it :D
Then all my mates came round in the evening, bringing me this
Which was double battenburg inside :D
After which much drinking of Southern Comfort and ginger beer was done :cool:
