I'm wanting to sort out a few things the speaker is blowing on passenger's side.
Not sure if it's something else causing the sound or just need replacing I need to look at it soon.
Also I'm trying to figure out how one can hook up the steering wheel audio controls to work with the aftermarket radio.
Seems that I need to buy an adaptor and wire it into the loom some how.
This seems to be the only way it would be great if I had some guidance as to what adapter would work and how to wire such as a diagram basic for this project.
this one will work and is plug and play or least looks to be what is phone button tho ?
incartec.co.uk/product/Nissan-Micra-K12-Note-Audio-Steering-control
dynamicsounds.co.uk/connects2-ctsns007-2-nissan-micra-note-steering-wheel-control-stalk-adaptor.html
Edit:- had a look at the speaker it appear to be find visually no wire loose as far as I could see..
Tryed to rearrange the push clips amd deleted the old one that was probably an original that was no longer re-usable.
Door carde is now held firmly in position around the areas of the speaker leaving me one that needs replace down in the bottom middle.
Had another try and it sounds horrible not sure so much why other than maybe the magnet is wornout or my music quality is just crap.
Anyhow I think best to replace them as they don't really look that good anyways.
