Today I am taking a look at an idea for a permanent repair for the air intake breather.
My first thought was to buy all the parts and copy the improved air-intake.
That is shown here and others have already followed and gotten great results.
For me though I can see this as being costly for what it is.
However I do not doubt that it is improved.
And have even started listing all the parts I should require if my idea does not workout.
Anyhow this is what my idea is so far and its really simple.
Also it may be possible that it can be done for free if you have the parts laying around.
Now I have not tested it out or fitted it up to the air intake filter housing or pipe.
But this is the basic idea.
I'm going to try adding a rubber sleeve or hollowed out bung.
Fitting this over the intake and then hopefully as I usually say...
Mounting it to the filter box with clamps.
For me the clamps being the only item I would have to buy along with maybe some Adhesive glue to make the sleeve fit.
So here is an image of what I plan to test out. The sleeve measures 55mm inner diameter. Also quite Flexible and can easily be cut making it possible to fit onto the intake. Far enough to have good contact and not fall away with the engine movements. whilst in use.
So here is what I'm looking at for the time being. Should you have the same problem this may also work for you.
On the left is the one I'm working with. At the right is a flexible plastic that could prove useful. For air box spigot. Giving a little spring action to the intake although I doubt this will be needed.
The second image is something I plan to buy if the inner side of my item shown left doesn't seal or fit nicely.
In case you are wondering the first item in showing is from a stepper machine that was disassembled for parts. I have 4 of these rubber feet so can try again if it goes wrong.
And the other is from a computer swivel chair.
The other item I do not have yet. Will work better as there is no thread on the inside.
The threaded inner, Might not be ideal for this purpose.
My other solution is to buy a coolant hose and cut it to a desired size making a similar fit to what I'm trying to achieve here.
Sent from my ASUS_T00P using
Micra Sports Club mobile app
