Well that was 'interesting'.........
All in place and everything works......
BUT definitely NOT a straight swap over on a 2006 K12
I was comparing the 'Note' heater control, front panel donor unit, with the spare 'Micra' one I bought about 3 years ago, for the black knobs, and everything was identical and swapped over on the bench, however when I stripped down the dash on the car to fit the panel all was NOT the same
. It would appear that Nissan changed the units on the Micra K12, very subtly, sometime after 2006 when they fitted ones with black knobs to the K12 (they probably 'standardised' and fitted the same units as the Note ones) so my replacement is either from a very late K12 or a Note
I now understand your comments about the A/C and heated rear screen buttons being too long.
As a comparison, the Micra one is the top one.
The profile is also different, the Micra buttons having square flanges...
I decided that if I altered the profile of the Micra buttons to the rounded form, so that they would slide in the Note front panel, top one standard, lower one modified (craft knife and file)........
then 'all' I would need to do would be to shorten the button housings in the Note panel to the same length as the Micra ones....
Again junior hacksaw, craft knife and file, the one on the right is modified, with the modified Micra button fitted, and on the left unmodified, with Note button fitted....
These are the bits I cut off of the panel....
So there you have it, it is possible if you really try
