Mark's 1.0LX
I've been playing with Knobs. Its just something that I like. I had an idea a while ago that a dinky 150ml pop can would make a fun gear knob. I had an idea that I would open from the base, empty out the contents and fill with fiberglassing epoxy resin. My first go was not brilliantly sussesful.
I mixed the incorect ratios, I also think that the filler powder may have worked as a catalyst and set the reaction off quicker, because the second time I tried with simmilar ratios of resin/hardener but no filler it was fine.
Part of the can was left open as a shoud round the gearleaver shaft, and to set the height of the can down slightly. The hardened resin was drilled and tapped to suit my gearleaver shaft.
There it is in position, the Bitter Lemon was chosen to go with the girly turquoise car.
The can isn't particuarly comfortable so after the novelty has worn off I'll probably use the ally one.
What did you use to fill the can and what size tap is needed for a k11 gear stick?
Missed this completely.
Epoxy Resin to fill, then an M10x1.25 tap to cut the thread.
If you wanted to commission one.......
