lee k0011
I hate rust :(
Yer i do live in wrexham..Are you near Wrexham , pretty sure i have seen this car..
Thanx i was very pleased/surprised with the results lolExcellent job dude!
Started building up thin layers of color about 4 or 5 coats i think..
once i was happy with the color gave it a few coats of laker and then realize that i should of put some masking tape on the sill
Not bad for a first attempt i think and a definite improvement on a big rusty scab....
My sister is running round with that wheel on her micra ATM.It does stand out slightly lolNice work with the arch, but Ouch! poor wheel!
Been using highcoat paint for the color and laker,Used to get it for £2 a can where i used to workWhat aerosols do you use btw?
Looks good mate!... You got form!...I got a few hours to my self on Sunday, and it was sunnyso i managed to get my boot painted..
The finish ain't the best, but nothing a bit of wet and dry and the buffer cant sort out. Just glad to have it painted again....
Yep just used High Coat rattle cans..did you just use rattle cans on that wing? looks a good job
Where from?Yep just used High Coat rattle cans..
Where from?
Got them from motormania, not sure where els you can get them..Where from?
Interesting.Got them from motormania, not sure where els you can get them..
But they are a grate color match for my car..
Mine is TJ4 too. If you are near London there wont be any motormania's by you. But they sell it on line.Interesting.
I get TJ4 paint from some place in London, 6quid a can and it's small.
Your Micra looks same colour as mine TJ4 so i'll look into motormania
How many coils did you cut off the back ones???Cut the Teins in half mate then put them back on, thats what i did![]()
Just the rears is did anyway, the fronts are in storage as ive got the corsa coils onHow many coils did you cut off the back ones???
Think i will have to invest in some corsa rear shocks!!
I am thinking i wont to go lower, but will wait till i have got some wheels sorted first tho.. So no how far i need to go.Just the rears is did anyway, the fronts are in storage as ive got the corsa coils on
They are weller steel racing wheels.. So much poke for only 5.5" wide. Amazing what a difference the offset can make!Nice wheels Lee!... Are those BMW Mini wheels?
Just need to find another two with a lower offset now for the front..
Still not sure what to do yet.. Mite just Get a cheap tyre put on one and see what it looks like when it is down on the ground..What you doing about the poke? Can't really get much stretch on a 5.5J unless you want to run bicycle tyres.
heh mad negative offset. Is there any wheel space behind the centre?
Watch the wheel bearings collapse![]()
Managed to get the heat shield off the exhaust. It has been rattling for a couple of years now..
It put up one hell of a fight, but i won in the end..
