Im gonna go 35mm over the almera gti alloys, size of tyre you on?not yet but theres a 30mm kit in the boot to go on dont think i could go any lower over the almera gti rims
Tchaaa said:WDID? Left the window open by accident on a rainy night and had a rather soggy drive to my nan's this morning.
Any tips for drying it out quickly?
Sit on the seat. Change your trousers. Sit on the seat. Change your trousers. Sit on the seat. Change your trousers. Sit on the seat. Change your trousers. Sit on the seat. Change your trousers. Sit on the seat. Change your trousers.
Repeat until dry.
Aye vaux, dub, etc are smaller bore ehI've been looking through a wheel pile and it's difficult to find alternative wheels that fit due to the large centre bore diameter, clearly those yaris ones won't go either.its.
you get any pics?WDID: trial fitted one of my compo's and they're nothing special just a set of wheels
Belly93 said:£20 lol
mines colour matched to the carrubbed down and put primer on my rocker cover not 100% what colour i will spray it
question frank when you remove the head how does the bottom chain not drop off the crankshaft cog?WDIDT ? fitted the re-pistoned 1367 into the red car, and made major progress on the custom axle too
The guides hold it in place matequestion frank when you remove the head how does the bottom chain not drop off the crankshaft cog?
yes the chains just sit there when you remove the head, and the upper chain will only dislodge if you unhook itso as long as i line the crank up with the timing mark for the cam and crank timing i should be able to remove the chain and remove the head with it in place
if you remove the sump and pickup pipe yehok thanksanother thing can the bottom casing be removed with the engine in the car?
yes the chains just sit there when you remove the head, and the upper chain will only dislodge if you unhook it![]()
I like gloss blackJust got some clio 14" steels, and fitted some good 165/60/14s to them, going to paint them over the weekend. half inch wider than micra ones and ET35 fill the arches about 15mm moregloss black im thinking and gloss black bonnet
