lowered it again
How much drop?
lowered it again
Are you selling any?I love that centre caps are all the rage now!
SirChris said:I love that centre caps are all the rage now!
He is awaiting a set through the postI'm sure Dougie will be happy to hear he's missed yet another set
Sent from... My phone
Bout time i sold mine you mean?Bout time
No no, now douggy has got some, i can now sell mineI didn't realise they were yours he was getting.... I'll reserve judgment when I see how it looks after
odd_ball said:How do you buy them by "accident"?![]()
Cars running good now, the emanage is doing its job again.
Once setup properly (the tricky bit), it does look like you can remove the IAV without to many problems...theres a little hassle first thing but once the cars warmed up it looking like it couldnt care less.
Still need to alter the fuel maps scale as its apparent the bigger maf isnt going to get maxed out any time soon (obviously) so when normal driving the mafs reading lower than the current map allows making it too rich at cruise and leanish on boost. Easy enough tweaks though.
Your running emanage? Any trouble with mapping the cg?
which wire was it zspirit ?i have wired correctly my tachometer and now is work![]()
WDIDT ? bought another CGA3 ffsnote the casually placed widened steels and nearly finished axle
what was the problem with the lights?
to be honest im still not too sure, but i brought another new set of lights to see if changing them one by one and trying it did anything, and, once the driver-side brake and indicator had been changed the problem just vanished, nothing wrong with the bulb holder, earth or fuses etc but a new bulb in each slot did the trick, so I've now got a full set minus a brake and indicator sitting in the boot for the next time i get in the car at 2am to find i've got a bulb out![]()
some more pics here krisWill wait and see how the other bits come together![]()
hehehe, yeman, I did swop all of the bulbs, but i didnt think to do it one at a time checking after each change,did say it would be a bulb![]()
cheaper than a decat pipe aint they hoopdubgot a 1st box back exhaust off a k11c, looks like it may be the same length as a k11 one with the cat attached, so im going to replace the center box on the k11c one with a length of pipe, cut open the rear box and gut it a bit, see if i can get it to sound like the PLR one i had for a tenth the price![]()
piggybacked a 2nd coolant sensor to the white car too, it was still coldstart enriching for 1 mile, homeward bound at dinnertime in this weather (no wonder these cars flood so easy)
Its under the dash in the red car zed, i dont think the position is important, just the extra resistance to kick it out of coldstart enrichment and into closed loop quickerahh right in the bay does the trick to. is more to do with having the second sensor connected,any place cool ?
is this a comon fault frank?Its under the dash in the red car zed, i dont think the position is important, just the extra resistance to kick it out of coldstart enrichment and into closed loop quicker![]()
Dunno if it affects the facelift ones mate, but nissan used to sell a patch loom with a resistor in it to alleviate the problem.is this a comon fault frank?
no bother cheersDunno if it affects the facelift ones mate, but nissan used to sell a patch loom with a resistor in it to alleviate the problem.
With it fitted to the red car it was closed looping within half a mile, even in winter, but this white car was,nt closed looping till the temp gauge has started to rise (2 miles,ish)
Yes they are corsa shocks, just have to grind the sides of the bushes to make them fit in its mounting. Oh and replace bolts with m8'sLooks like you had some fun.... are those corsa shocks on the back? Look like the ones ive got waiting... if they are then did you have to work on them much to get them to fit? cheers.
Yes they are corsa shocks, just have to grind the sides of the bushes to make them fit in its mounting. Oh and replace bolts with m8's![]()
