ok sounds like im stuffed then frank!!! one of those things you call "Suck It And See".............. loool
J
J
a bit pointless turboing your car to only run @ 100hp tbh mate, a hybrid friction plate is easy to assemble (covered in my blog)ok sounds like im stuffed then frank!!! one of those things you call "Suck It And See".............. loool
J
My apexi neo with additional wideband is working sweet. 5000 miles ish so far.My little piggy is still doing a good job as well, so a management of some sort is probably a good idea.
aye, here,s an HKS one, with parts that actually fit together, unlike that kit linked garrett T20 ? (must be some old stock )
chatter bolted ?No don't want that frank, what abt waste gate chatter bolted ? Is that possible ?
the wastegate wont make any noises mate the bov or compressor surge will thowhat difftents does it make frank? And does it sound loud ?
They are loud and they sound like massive boost leak if you vent it atmosphereI thought its waste gate what makes that chatter sound ? I mean a loud sound
Can feel the love there frankbell-end
nah, bov,s with a bell-end will be louderCan feel the love there frank
No further comments.... they wouldn't be constructivenah, bov,s with a bell-end will be louder
Be finethanks for info ? Can k11 pumps be ok for 140 bhp ?
Which engine of Frank's are we questioning?Haha frank the bov is nice sound, what bhp is ur micra frank
this one should be audible and about 125 at a guess mateHaha frank the bov is nice sound, what bhp is ur micra frank
that depends how much spark retard you run mate (and on what fueling measures you make), if you pull the dizzy back 20 deg you will probably get away with half a bar of boost for short bursts no probs, but the car will drive crap off boost tho (it,ll pull like a 1.0, crap mpg and high exh temps)yeh 130 bhp is ok for me. Do I need to map it for 130 ohh is it ok frank,
yes, i blew a few pistons before the remapFrank what can I do I have sr20det injectors and rail, td04l turbo and gona use 2.5inch piping, walbro pump, what do I do if I don't wana remap it ? Will it run daft or lumpy or blow pistons ? What psi will u say is ok ?
5 psi w/g actuator ? and toohow can I Lower the psi frank? Also frank do u do turbo conversion for anyone if I bring You everything and get u customers too
nah, the controller will only alter upwardsHaha that's ok frank, can't I leave my td04 on and use a boost controller to lower it so I can start from 10psi and lower it to 5 psi ?
needs to be TIG,ed, (professionally)Frank I cut the sr20 rail and fitted them on k11 inlet am scared to weld them can u help plz
