haha but it is far I have checked and I accept the excuseThats wasn't an offer of help that was an excuse for not helping lol
Sent from my iPhone using T
Yeh that's Polly's Micra I like the stunt brace my self looks goodPolly is that your car in the Vids you posted? if so where did you get the support bar from
OMP top strut brace from demontweeks
Got a few quid as well seen the price of them lol@pollyp you really are the most helpful and useful person I've ever met![]()
ahh not to bad really seen then 1 you have got thought it was the adjustable one, azzy just seen one on ebay by noddie any one used them? look pretty cool alsoGot a few quid as well seen the price of them lol
Seen wat mate ? On eBayahh not to bad really seen then 1 you have got thought it was the adjustable one, azzy just seen one on ebay by noddie any one used them? look pretty cool also
Strut brace budSeen wat mate ? On eBay
ohh yeh sorry try larkspeedStrut brace bud
Cant find a micra one, rather give my money to someone off here anywaysohh yeh sorry try larkspeed
Yeh that's better off will save u time and cheaper to getCant find a micra one, rather give my money to someone off here anyways![]()
No that was in my tool box when I got things out on the floor I used a breaker barPlease don't say your using a tourque wrench to lossen bolts ?
I thought I leave the gearbox and drive shafts in while am doing the engine ?you might be best to leave the driverside mount on while pulling the g/box off azzy
yeh, but while you,re pulling the box off the driverside mount will hold the engine in place mateI thought I leave the gearbox and drive shafts in while am doing the engine ?
Frank I don't get it? But my drive shafts are in the gearbox will that not affect it being tight ? Or bending shaftsyeh, but while you,re pulling the box off the driverside mount will hold the engine in place matethen once its free and secure you can remove the engine
nah, you twist the front of the g/box away from the engine mate, the shafts just hold the back of itFrank I don't get it? But my drive shafts are in the gearbox will that not affect it being tight ? Or bending shafts
Ok there is 3 bolts on the mounts for gearbox which one do I take off franknah, you twist the front of the g/box away from the engine mate, the shafts just hold the back of it
Page 14 ? I will just take 2 bolts out and check which way it comes outyou can see the angle of the g/box on this pic from page 14 mate, and remove all the bolts apart from that 1 i showed you
frank found this u send I know wat u mean by the bolts nowyou can see the angle of the g/box on this pic from page 14 mate, and remove all the bolts apart from that 1 i showed you
frank how long does it take u to take engine out and replace it ?you can see the angle of the g/box on this pic from page 14 mate, and remove all the bolts apart from that 1 i showed you
about 1 hr remove, and 2 to 3 refit azzy, but i cheat thofrank how long does it take u to take engine out and replace it ?
what u mean by taking the inlet off what will it do ? My rear mounts are off ?about 1 hr remove, and 2 to 3 refit azzy, but i cheat thothe bumper is held by only 2 easy nuts and 2 screws, and i always leave the 2 awkward bolts out (arrowed) and the steel bracket underneath it too
that way i can get the mani off in 2 mins, and dont have to crawl under the car to get the rear mount off
It's possible I took my sr engine off last time about 1.5 hour and that was taking everything off1 hour to remove an engine?
Respect!
Sent from my RM-892_eu_euro1_205 using Tapatalk
If you took the sr one out why were you so worried about taking this one out?It's possible I took my sr engine off last time about 1.5 hour and that was taking everything off
that's the Diffrents I took off gearbox and engine all out, drive shafts, I mean the lot, I wanted to know how frank took the engine out only with leaving the gearbox inIf you took the sr one out why were you so worried about taking this one out?
that's a good question but taking the inlet off don't I need to take the water pump pipe off what sits under inlet ?It gets it out of the way when your taking the engine out surely?
Water pump is on side. Maybe you mean power steering pump? And I don't tink inlet and p/s pump are connected. You will struggle to remove inlet without engine though if the bracket which frank mentioned is still attached. I think I'd remove it as one.that's a good question but taking the inlet off don't I need to take the water pump pipe off what sits under inlet ?
Yeh I will have to remove as one full unit coz the inlet bolts are hiddenWater pump is on side. Maybe you mean power steering pump? And I don't tink inlet and p/s pump are connected. You will struggle to remove inlet without engine though if the bracket which frank mentioned is still attached. I think I'd remove it as one.
I used one because it cost £5
I paid 30 pounds for mines I thought it's cheap and no leaks, also it's the sound I guessI used one because it cost £5(and did the same job as the £100 ones at low boost).
Sorry I don't buy fake u can tell it's genuine by looking on itIs it real hks? Plenty of fugasies around ...
Don't be sorry.Sorry I don't buy fake u can tell it's genuine by looking on it
haha yeh got it cheap and tested with no leaksDon't be sorry.
Guess you got it pretty cheap then![]()
