What failed on the engine Neil?
did you bust apart the other block neil ? to check the liner thickness
Bloody hell
That’s a bit better than me and a dremmel![]()
With router cnc it's alote better
Enviado do meu ONE E1003 através do Tapatalk
i would try 2 old gaskets and see how it ran i guess mate, and if the compressions are back to normal then decide which way to go
Doesn't necessarily mean the cylinders trashed. Could be a worn cam or a bad set of rings. Edit: or a leaking valve.Had a quick go before work.
All cylinders went to 7bar
Put a smidge of oil down there, and went right up
Cylinder 1- 10bar
2-3-4 - 12bar
What does this mean then?
Cylinder 1 is trashed.
Or is it because I’ve only done 15miles on this fresh pistons/rings
you hav,nt tried it without the decom plate neil ?
the overbore might have made them too thin maybe ? then they crack and leak compression into the crankcase
