nah, they,re steel
i would never attempt to weld a fuelrail personally azzy, especially when the CGA topfeed rail is such an easy option
Are you sure you don't just want to pay someone to do the car for you?
I wana pay for the map and nistune, maybe injectors welded, rest will do it all my selfAre you sure you don't just want to pay someone to do the car for you?
Good question the garage is now closed due to moved on doing car audios esle where so no luckso just go to the place you got the last fuel rail welded I guess
Even I won't touch aluminium welding. You'll spend a lot of time with big pools of aluminium at your feet...
The aluminium burns/evaporates at the melting point of steel so you can probably guess...
Just looked I don't think it's aluminium frank might be right looks steelThe aluminium burns/evaporates at the melting point of steel so you can probably guess...
nah, they,re steel
Childs playnah they,re a mission to get a 70psi gastight seal azzy,,,,,,,,,,,good luck mig-ing one of them
Good thought I have 10mm tubings of both I'll try that it's easy and cheapGet some 10mmx0.5mm steel and aluminium tubing and try weld that. Better than cutting up fuel rails
Cap emHow will you pressure test them Azzy?
